Question about AT&T E5939B Trio Cordless Phone
Speaker is very weak on answering machine at full volume
    President:
  • 1,070 Answers
Speaker of your Phone Usually have Good Sound.If you are Facing this Problem of Very Low Sound/bad or Noise in Sound recently ,then you may need to Change it's Buzzer(Speaker).Carefully Unscrew the Phone.There you will see Buzzer and Change it Using a Soldering iron or Something like that.
  • Note:Only do This thing if you are familiar with this Repair/you are Confident to do it your Self.And also make Sure Speaker Sound is very low other than same Model Phone -before you do Repair/Unscrew the Phone.Make Sure Volume is High/Full level [to Confirm Buzzer is damaged and need to be change].
Thanks for Contacting FixYa....
Posted on May 29, 2010
The speakers do not produce high volume. I turn it up to 40 to hear at a decent level. I turn down to 10 and its like its at 0 (no volume at all).
What is 40? Full throttle? What equipment do you have besides the speakers?
Does the problem apply to both/all speakers?
It can be many reasons why the volume is low. First we need to know what drives the speakers, what the audio source is etc. In general the whole package of equipment, their settings, filters etc. in order to answer the question.
May 24, 2016 | Audio Players & Recorders
The radio in my 1995 jeep grand cherokee plays full volume on the right channel when turned on.
  1. bad radio amp
  2. bad wiring to speakers.
  3. or bad speakers.
the tests are easy, ask.
my guess is the weak side is bad, the load side is ok.
you can turn the volume down on the load side using volumn control
if yes that side is ok, fix weak side.
ask how, but make sure the wiring in all 4 corners are not damage
and at both ends of harness.
Feb 27, 2015 | 1995 Jeep Grand Cherokee
How can I reset the volume control? All of a sudden, I can barely hear with the volume set at max.
You do not mention the type of Motorola radio so this answer will be general. You may have a problem with your volume potentiometer, Receive (Rx) sensitivity, or a speaker problem.
The volume pot on a 2-way radio is a common failure item, and will after repeated use possibly fail, or get dead spots. Try backing off your volume to 75% and see if it is louder at this setting. If so, you have a bad volume pot.
Rx sensitivity can be caused by various internal problems with the radio,and some models are more prone to this than others. Operating your radio at full volume most of the time can bring this issue to the forefront. (Tip: Try running your radios at 80-90% volume vs. full volume to alleviate this problem.) If this is your issue, your effected radios are in need of repair. Most repair facilities (including ours) can correct Rx sensitivity in most models during a repair.
Speaker problems: If you work in an environment where dirt, debris or metal shavings can get inside the speaker, your speaker may fail over time. Or if you run your radio at full volume the majority of the time it can cause your speaker to fail.
Best regards.
Oct 13, 2014 | Motorola Walkie Talkies 2-Way Radio
How do I record music on my OGM
Sounds like you may have the volume too high on your music. Try moving away from the speaker and lowering the volume.
Apr 09, 2014 | AT&T 1717 Digital Answering Machine
I have a Vtech answering machine, MI6896, I need to lower the volume of the ringer without changing the volume of outgoing and incoming message.
With the handset in idle mode, press MENU then use up/down-arrow to select "RINGER VOLUME." Use up/down-arrow to change the ringer volume. See full details on page 30 of the manual.
Jul 29, 2012 | Vtech Lands Phones
I need another corded handset. Mine has no volume. I can call out using the speaker phone, but am unable to used the corded handset.
Please check the CORD to the handset , this can be replaced and is available in all stores. Also the earpiece speaker or the microphone can be weak and can be replaced which can solve this issue..
Jul 08, 2011 | Panasonic KX-TG2770 Phone System w/...
My Nokia 5230's volume suddenly went very low. Either I've made a call or receive a call, the volume when answering the phone is very low. I've increased the handset volume to maximum but it's still low....
Please see if there is dirt clogging on the earpiece that would have reduced the volume from the speaker. If so use a pin and soft cotton to clean or you must open the cover and use a brush and air jet.
Secondly the possible weakness of the speaker/earpiece or the weakness of the low power output amplifier is another possibility.
Feb 18, 2011 | Nokia 5230 Cell Phone
Sony AV Recever STR DE 675 weak right channel
What' are the answers to these 2 questions:
How does it sound when you run through the speaker setup routines? Page 19 - 21 in the manual.
Do all sources do it?
Feb 21, 2010 | Sony A/V Receiver
Is it safe to turn the volume up all the way without risking damage to the speakers for prolonged periods of time?
no - the resistance in the tiny voicecoil will heat up rapidly, and blow.
3/4 gain is the approximate "safe zone" for any speaker at "full volume"
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 17, 2009 | Sony BRAVIA KDL-46V3000 Television
Possible blown speakers
I have experience with that model of speakers. When they give up the ghost, the volume is VERY low. But just to be on the safe side, check the volume properties to make sure nothing is set too low. Start>Control Panel>Sounds and Audio Devices. Check the slider bars here, check in the Advanced area as well to make sure nothing is low and check the Speaker Volume as well. If all the bars are set to their maximum, it's time for some new speakers.
Thanks for using fixya.com. If you like my answer, please help me out and rate me accordingly.
Jan 11, 2009 | Dell A215 Computer Speakers
AT&T E5939B Trio Cordless Phone Logo
37 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
