Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Profile TBX 22 PI: Ice maker underfills, jams
GE Profile TBX 22 PI: Ice maker underfills (so all pieces are small), frequently jams when the farthest piece does not fully discharge (then makes no more ice till the piece is dislodged). Wife wants it fixed. What should I do? Thanks! Bob
Joe_Rex
  • 114 Answers
SOURCE: Ice Maker Won't Stop Making Ice
There is an adjustment for the "harvest" bar (The bar you lifted up). That bar you are lifting up tells the ice-maker that the cubes have fallen into the ice storage and starts the ice-making cycle over. It is also the Limit switch for the ice level in the storage container ... if it stays up for preset time determined by the manufacturer it stops making ice... most all ice-machines use the same devices. they vary little in design. Sometimes you can just gently bend the bar down to the point where it turns-off the machine at the level you want ... unless you can get to the adjustment hinge you can adust it there. For the fact it goes off when you lift it all the way up tells me the harvest switch is turning the ice-maker off.
Posted on Apr 29, 2007
watugot
  • 290 Answers
SOURCE: GE Icemaker flap door won't open causes ice jam in chute
There is an electric solenoid that opens the door. If you look up inside the dispenser you can see the solenoid. Either the solenoid is bad or the dispenser module that puts power to it is out. You will need to remove dispenser front and check for voltage to solenoid. If you have power from module, replace solenoid, if no power, replace both parts. It is common for solenoid to short out and damage the module so that both must be replaced. If solenoid is shorted and you replace module, new part will fry.
Posted on Oct 02, 2007
SOURCE: GE top freezer ice maker leak
I have the same problem -
Posted on Aug 11, 2008
SOURCE: ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Posted on Nov 09, 2008
aasc
  • 1606 Answers
SOURCE: I need to know how to change the door opening. What do I do with the wires in the hinge?
Since the wires come up thru thr hinge , you cannot reverse the doors .
Posted on Sep 23, 2009
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
No water entering ice maker.
Replace the solenoid valve , the piece the wall water line connects to , on the refrig . With both ice maker AND valve replaced , that is the complete ice production new .
Jan 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Turned ice maker off prior to a ten day vacation. Upon return, it would make thin shelled ice cubes and finally stopped altogether. Could the water line be frozen How does one de-ice?
Fastest way is to remove the ice maker tray so that you have an open area where the ice maker filling tube is, then cover your food with a towel or something to help prevent it from thawing while you let refrigerator defrost for about 20 to 30 minutes with a hair drier on warm or a small fan blowing directly on ice maker where the water fill tube or opening is. I does not need to be right next to the ice maker just an unrestricted open area to let it warm sufficiently to thaw it out without thawing out your food in the freezer. A small piece of ice can stop the valve from opening and this can happen if it is not used regularly.
Oct 08, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
GE Profile stopped making ice. 2 yrs old
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath freezer needs to be 0 degree F to start ice maker
Aug 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker does not make any ice green light flashing in freezer
There was a small piece of ice stuck in the back prongs. Removed stuck ice (very small but enough not to make it work). Now it works GREAT!
May 15, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice maker not ejecting ice and then tries to fill tray and leaks
The Ice Maker Tray had a small plastic piece break off. This piece aids the tray in bending to dislodge the ice from the tray. Bosch does not just sell the tray, you will have to buy the whole ice maker assembly. You will need to order Part # 0422 from Bosch. I was not very happy about having to spend $112.00 for this whole assembly when all I really needed was a simple ice cube tray.
Save the $112 and remove the ice maker. Buy Ice at the grocery store.
Mar 31, 2009 | Bosch Evolution 500 B20CS50SNS
GE profile refrigerator model # TBX25PR
See if ice is jammed up in the tunnel the ice is pushed through.
Will the motor turn the auger with all the ice removed.
Jan 25, 2008 | Refrigerators
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
314 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
