Question about Dell (27HRF) Motherboard
The motherboard 27HRF can work with my dell
The problem is that the clock dosent keep the hour,date and sometimes the year goes to1610 all the computer works fine and ok, i have already checked the coin battery and its okay thats why i think its the motherboard i found the folowing motherboard the motherboard 27HRF can work with my dell XPS1330??
    President:
  • 1,768 Answers
You should replace this board it may an internal issue such as a shorted trace of surface mounted component. Not worth the effort to do board level troubleshooting and there are replacement board that will fit the Dell cabinet you have. Call Dell support to make sure that you can use a #rd party board substitution.
I hope this helps. Have a great holiday weekend.
Posted on May 29, 2010
My DSC Wt5500 Alexor Wireless keypad not keeping correct time even after changing batteries. Is there something in the programming I need to do to get it right? Thanks!
I am assuming that the keypad was successfully enrolled? Try to reprogram time. Time should be coming from the main unit and not the keypad itself.
*6
Master Code
24 hour time (ie 2pm= 1400)
Date Format mm/dd/yy
Keypad should confirm successful entry by beeping rapidly three times
press # a couple times to get out of programming
After exiting programming the display should come up within 30 seconds or so displaying the date and time before it goes back to sleep.
Apr 12, 2015 | DSC Wt5500 - Alexor 2-way Wireless Lcd...
Every time i boot up my brand new dell vostro i get an error: 00c08270 real time clock error - check time and date settings. I have been continuously updating the time and date but the error message keeps...
Meaning the RTC battery needs to be replaced.
The Real Time Clock battery is the CMOS battery.
http://support.dell.com/support/edocs/systems/vosA860/en/sm/index.htm
Coin-Cell Battery
The laptop has to be completely disassembled down to the motherboard (System Board) in your hand.
On the bottom of the motherboard is the RTC Battery.
Since the laptop is brand new this falls on the place where you purchased it, or Dell.
It is still under warranty as far as replacing the RTC Battery. (It came with a bad battery. They need to replace it, not you)
Regards,
joecoolvette
Jul 09, 2011 | Dell Vostro A860 Notebook
How do you change the clock on a 2009 Chevy cobalt.
Setting the Clock Without Date Display AM/FM Base Radio with a Single CD Player
To set the time:
  1. Turn the ignition key to ACC/ACCESSORY or ON/RUN. Press to turn the radio on.
  2. Press until the hour begins flashing on the display. Press a second time and the minute begins flashing on the display.
  3. While either the hour or the minute numbers are flashing, turn to increase or decrease the time.
  4. Press again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing stops after five seconds and the current time displayed is automatically set.
To change the time default setting from 12 hour to 24 hour, press the button until 12H or 24H is displayed. Once 12H or 24H is displayed, turn the knob to the desired option to select the setting. Press the button again to apply the setting, or let the screen time out.
With Date Display Radio with CD (MP3) and USB Port, and Radio with Single CD (MP3) Player
To set the time and date:
  2. Press and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) displays.
  3. Press the softkey located below any one of the tabs that you want to change.
  4. To increase the time or date do one of the following: • Press the softkey located below the selected tab. • Press SEEK, or FWD. • Turn clockwise.
  5. To decrease the time or date do one of the following: • Press SEEK or REV. • Turn counterclockwise.
The date does not automatically display. To see the date press while the radio is on. The date with display times out after a few seconds and goes back to the normal radio and time display.
To change the time default setting from 12 hour to 24 hour or to change the date default setting from month/day/year to day/month/year:
  1. Press and then the softkey located below the forward arrow label. Once the time 12H and 24H, and the date MM/DD/YYYY (month, day, and year) and DD/MM/YYYY (day, month, and year) displays.
  2. Press the softkey located below the desired option.
  3. Press again to apply the selected default, or let the screen time out.
Nov 21, 2010 | 2009 Chevrolet Cobalt
My latptop's internal clock getting problem after some days its reset to year 2002.
The CMOS battery is responsible for the internal clock. If it automatically resets itself to 2002 (motherboard manufacturing date) then you need to have it replaced (it's really cheap to have it replaced).
Jun 14, 2010 | Dell Latitude D510 Notebook
Need number part dell motherboard XPS1330
Intel Integrated Video GM848
nVidia GeForce 8400M CX062
May 29, 2010 | Dell (27HRF) Motherboard
Clock dont keep the right hour, date and sometimes year
Hi. Try updating the BIOS first by downloading it from support.dell.com.
^_^
May 29, 2010 | Dell XPS M1330 13.3" Tuxedo Black Laptop...
Dell Inspiron 531 (desktop) won?t turn on/boot
You've either got a bad motherboard or a bad processor (I'd lean to the motherboard being bad). I would honestly take this into a computer repair shop and have them check both.
Oct 22, 2009 | Dell Computers & Internet
Inspiron laptop clock incorrect
Go into the BIOS by turning on the laptop and pressing F2. In there i believe on the main screen you can change the time and date. Do that, save changes and exit and then go into windows and see if it keeps the right time and date.
Let me know how it goes.
May 12, 2009 | Dell Inspiron 1525 Laptop
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
848P-A mother Board P4FSB 800 INTEL CPU PENTIUM 4 PROCESSOR
If by "Reboot" you mean turn-off and restart, your CMOS battery is probably bad and not able to supply enough power to the bios to retain your time settings. Replace the CMOS battery.
Many web sites require the proper date and time on the surfer's PC. For example, Microsoft Update will not allow downloads if the surfer's PC date and time are far out of syncwith the real time. Ironically, even the Update Time function on the surfer's PC will not work if it is too far out of sync.
Oct 31, 2008 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Dell (27HRF) Motherboard Logo
mukhtar21 shaikh
mukhtar21 shaikh
