Question about Sta Rite STA-RITE CONTROL BOARD KIT - 42001-0096S
Sta-rite pool heater won't fire...
My led says 126 then 125 and then back to 126...back and forth...heater will not fire!
  • nomoneytom May 29, 2010
    I do not understand your answer.. I have read the manuel and there isn't anything about "125 or 125".... help!
Nomoneytom did you find solution if so let me know I have same issues. Thanks
Posted on Jun 06, 2010
  • 12,061 Answers
Www.cheappoolproducts.com/.../Max-E-Therm-manual.pdf - United States
https://www.gpspool.com/.../Sta-Rite/Tech%20-STA-%20Servicing%20the%20Heater%20Control%20Board%20%u2013...
Those manual should sort you out.
Posted on May 29, 2010
Heater run hot then cold
check gas pressure if ok check flame sensor if ok check high limits
Mar 30, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Impeller won't turn after long winter.
TAKE THE SS BAND OFF PULL PUMP MOTOR BACK FROM PLUMBING , TAKE DIFFUSER OFF AND GENTLY TURN IMPELLER BACK AND FORTH. IF THIS DOESN'T WORK HAVE A PRO DO IT !! HERE IS A LINK ON HOW TO REMOVE YOUR AND OTHER TYPES OF PUMPS CLICK HERE
VOTE YES IF I WAS OF HELP THNX JAY THE POOL PUMP REPAIR GUY IN SUNNY FLORIDA
May 29, 2011 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Why my sta-rite pool heater temp wont rise above 78 with no service light on top display also where is my led display lights manuale said look on back of board please help thanks
The Led's are on the back of the display panel itself. You have to take apart the heater to see them. The most likely culprits are either a bad thermostat or bypass valve.
Apr 17, 2011 | Sta Rite Pool & Spa
Sta rite heater won't fire. Control board only shows green LED lights. Prior to not firing water temp was 120 degrees. Almost burnt my foot off. Next day heater did not fire at all. Where can I go to...
Could be your heat sensor has gone bad. follow the wires for the sensor from the board to the water manifold. Then simply unscrew the old one and put a new one in. Do this with the system off, good luck.
Sep 17, 2010 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Sta-Rite Max-e-Therm pool heater -- cycling and HLS
make sure that you have adequate water flow going through the heater and that your water chemistry is balanced.
Jan 09, 2010 | Sta Rite Sr333na Max E Therm Pool & Spa...
Sta rite heater won't start
TURN THE BREAKERS OFF FO R 20 SEC IF PROBLEMS PERSIST SEE CODE A POST
Dec 06, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
R8 Error
dont know what heater yuo got may be a board or temp sensor also post if automatic control
Sep 13, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Sta Rite STA-RITE CONTROL BOARD KIT - 42001-0096S Logo
957 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
