Question about Proscan 32LB45Q 32 in. TV
My Proscan tv turns on by itself. I see the on/off tv indicator on the TV flashing on from red to blue constantly.
  • Proscan Master
  • 12,061 Answers
Http://www.retrevo.com/support/Proscan-32LB45Q-TVs-manual/id/23606ag500/t/2/
Above is your user manual, below is your service and repair manual. http://www.eserviceinfo.com/index.php?what=search2&searchstring=proscan
www.ehow.com › ElectronicsTVsOther TVs -
www.ehow.com/how_6081492_fix-proscan-hdtv.html - United States -
Above 2 self help repair sites.
Posted on May 29, 2010
Proscan tv. blue indicator light is on no pic and no sound. can not turn tv off.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory ResetF (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jul 22, 2016 | Proscan 32LB45Q 32 in. TV
I tried to program a universal remote to my Led Proscan tv and now it just flashes different colors. How do I get it to stop?
hi,
I think some how you have gone into service mode on the tv.
you may need to take it into a repair shop so the can re-set it back.
sounds like it to me.
hope this helps
May 21, 2014 | Proscan PLED5529A 55" LED TV 1920x1080,...
My proscan 42la45h wont get power. no red or blue light
U check the power source like the power a/c outlet?Yes?Tries tv unplug,replug it back like about an hour later.The tv should resetting itself back to the tv factory setting,tv now should have power again.Not.The tv have a power supply board problems and the causes.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Sep 06, 2011 | Proscan 42LA45H 42 in. LCD TV
Tv coddetv #19la20qw
Hello
Setup codes for proscan TV are:
0031 0107 0015 0000 0162 0163
Three digit codes are:
000/ 031/ 107/ 181
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Jul 28, 2011 | Proscan 19LA20Q LCD TV
I ned new remoute i boght 4 non of them works pleas help
Hello
Just buy one Philips Universal Remote control [MODEL NUMBER CL 034]. Your proscan TV is listed in its codes. Codes are:
0704 0312 0103
Direct Code Entry
1. Press and hold the CODE SEARCH
on, then release the CODE SEARCH
button.
flashes.
You will get its manual also with it, describes all the proceedings and codes for different set to which it can be used. OK.
Feb 23, 2011 | Proscan 19LA20Q LCD TV
I had water damage in my wall an my power strip got wet. Now my Tv shuts itself off after I turn it on before the unit ever comes on. Then the blue led power indicator light flashes.... U hope this is a...
Does it flash in a pattern or does it constantly flash - like 7 flashes then pause then 7 flashes? Or is it constant without pauses? Are you using a new power strip? It could be two things 1. Power supply or 2. Main board. is my initial thoughts. Have you opened it up to check the fuses, caps etc? If the power suply voltages look good its probably the main board.
Thanks,
michael
Feb 06, 2011 | JVC LT-52X579 52 in. LCD TV
Ok, so I got a RCA remote from 1800-remotes for $40.00 that they said is guaranteed to work with the Proscan but do I need to reprogram the remote because it is not working.
Hello
Just try with these four digit codes. Proceedings are given below.
Direct Code Entry
NOTE: Switch OFF and switch ON the tv with its front panel power control switch [NOT BY REMOTE CONTROL HANSET] before each try.
Dec 24, 2010 | Proscan PS32500 32" TV
Hi, We have a 42" hslc10668phz
generally when you get a constant green light all is ok. these different lights indicate different problems within the tv. so the pattern of lights you mention suggests there is a fault of some kind (is there a troubleshooting section in your manual)? either way it needs to be looked at.
Nov 28, 2010 | Hisense Televison & Video
Sony Projection Stand by indicator flashing red
Ur FBT,Fly Back Transformer high voltage is dead, the black block of plastic with a red wire with cap hook to a CRT(Tv Tube).
Sep 14, 2009 | Sony KP-46S25 TV
Proscan 32LB45Q 32 in. TV Logo
883 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
