Question about Frigidaire Affinity ATF7000E Front Load Washer
CLOTHES STINK LIKE MILDEW
WE HAVE CLEANED OUT THE TUB NUMEROUS AMOUNTS OF TIMES WITH BLEACH AND FRONT LOAD WASHER CLEANERS AND OUR CLOTHES STILL STINK. CAN ANYONE TELL US IF THERE IS A DRAIN ON THIS MACHINE THAT WE ARE MISSING OR WHAT DID THEY DO TO CORRECT THIS PROBLEM
    President:
  • Frigidaire Master
  • 662 Answers
Plug off the mains. You have to look for screws below the front kick-panel, you can raise the machine a bit to gain access to the screws, the panel comes down & out. You may find a drain hose here, on left, drain off the excess water. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. You can pass it into a large plastic bag. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
You can give me a very helpful rating for the free help, can't you. Thanks.
Posted on Jun 09, 2010
  • prem mathew Jun 10, 2010
    You can use Affresh to clean your front loader. Deposits
    of soap and other such things can be
    stuck around the inside tub of your washer. Try this product, it works
    great on
    all front loaders. Use very hot water with the Affresh pellet with no clothes
    and
    run the machine through a cycle. Also
    helps with any stagnant water smells. Have you cleaned out your pump
    lately. Put the Affresh pellet inside the
    machine, not in the soap dispenser.
I also have had that trouble and was told by repair man to use alot less soap and set machine for extra rinse.COLD water. Another thing that helps is a small amount of vinegar in bleach dispenser. Hope this helps.
Posted on May 29, 2010
Mildew odor in the machine....can't get rid of it and makes clothes STINK!
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
Oct 21, 2012 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Mildew smell
All front loaders have to be run thru a clean cycle with no clothes or soap atleast Twice a month. You can use bleach or buy one of the special cleaners they have for washers.
Jul 01, 2010 | General Electric WBVH6240HWW Front Load...
Our 5 yr. old LTF2940ES0 reaks of mildew and is covered and stained with mildew on the inside rubber ring. It does not drain all the way after a cylcle, either. I have scrubbed and washed it with bleach...
The problem is the big round gray rubber seal and the ridges. I have this exact washer and had the exact problem. It stunk. There is a replacement gasket for $100+ that I purchased. (It's what the new ones come with.) It has no ridges and more holes to drain the water out of. It was a pain to replace it but it was well worth it. It is like having a new washer. We tried all of the bleaching, special powders, etc and none of that worked.
Jan 16, 2010 | Frigidaire GLTF2940ES Front Load Washer
Why does it makes my clothes stink like mildew?
The odor is caused by bacteria in the draining path. Run an empty clothes load with lemon bleach to get rid of the smell.
Jan 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Stale odor in machine and on towels and clothes. I have used the affresh, Bleach, baking soda, use powder HE detergent, no liquid fab softner, I am at the end of my rope with this stinking machine ready to...
Towel mildew smell is being transferred from the washer. The washer must be cleaned first. The problem is not "brand specific" all clothes washers have mold growth to a certain degree. Bleach or vinegar will kill the mold inside your washer but won't remove it or the residue it grows on thereby making the situation worse because it leaves a "base" for more detergent to collect on and more mold will grow.
Washing machine mold / mildew odor is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My GE Adora front loader- our clothes stink!
Clothes washing rules for mildew stink: 1) never leave clothes in machine for more than a few hours 2) never add too many detergent or clothes 3) clean the machine itself. Also if your fabric softener port is gummy there is a good chance you got some funk from that so clean all places where you have fabric softener contact. After all that, if this doesn't help you may need to run an empty load of strong hot bleach water and follow it with a hot empty rinse then a load of whites
to becareful not to ruin your colored clothes
Aug 09, 2009 | GE WSXH208A Front Load Washer
Laundry smells like mildew after washing
Front load washers retain water that you cant see or get to. There are cleaners for washing machines available. I clean mine every month with alot of bleach , try pouring a half gallon of bleach in the soap insert on a normal wash cycle and an extra rinse would not hurt no clothes of course.
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Super Capacity Washer - Mildew smell
run the washer, with no clothes,
and 2 cups of bleach instead of detergent.
kills any mould in the washer
at least until you find the original cause, it wont stink
Oct 13, 2008 | Kenmore 3.2 cu. ft. Top Load Washer
Stinky clothes
The big door seal is probably the problem. Put on gloves and using a solution of Laundry detregent and hot water and rags, carefully wipe clean all the folds of the seal. It will be icky. Next run a cycle with some detergent and oxyclean or bleach if you have it.
Especially during warm weather, damp clothing left in a front loader mildew slightly very quickly- you can't really see much but you can smell it! So get the clothes in to the dryer immediately. You'll want to relaunder the smelly clothing after you have cleaned the washer.
Good luck to you and Thank You using FiX YA!
Aug 17, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
152 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
