Question about Craftsman Single Speed Rotary Tool
Crafatsman Rotary Tool Single speed - chuck has no power - that is motor will run smoothly - - chuck will turn - but your finger can stop it - it is free wheeling on it's own even while the motor is running - there is no friction what so ever between the chuck and the motor. the chuck holding switch will hold the chuck still. you can turn the chuck by hand - but the cooling fan as seen through the side is not turning
  • 2,100 Answers
These are fairly easy to disassemble and get back together, take it apart and find out what got stripped, It might be an easy fix, then again, it might be going back to sears. They will take it back no matter what. Hope this helps.
Posted on May 29, 2010
Dremel rotary tool variable speed, low speed speeds up after short use. Will brush replacement solve this issue?
How stable is your line voltage? The SCR phase control used for speed control is more sensitive to line voltage changes at low speeds than at high speeds. Brushes should be changed when they are worn down to about 1/2 of their original length. Much more than this and they don't have enough tension to properly contact the commutator ring. Check with power off when the tool is cold and slowly turn the chuck by hand to feel the resistance. Run it a while and let the bearings warm up. Turn off power and turn by hand again. If it feels looser when warm (which would cause it to speed up at slow speeds), the tool might need to be disassembled and bearings oiled. I use Dexron automatic transmission fluid to lube most motors. Wipe down any excess.
Nov 14, 2014 | Dremel Variable - Speed Multipro Rotary...
I can't get the small sanding disc out of the tool.
Undo the chuck nut and then knock the spindle shaft of the sanding disc in lightly. This should release the collet's grip on the shaft. If the shaft has been pushed all the way into the chuck, remove the collets and nut and try separate the collet segments to release it from the shaft.
Aug 11, 2011 | Craftsman Single Speed Rotary Tool
Motor runs but shaft stopped turning.Would the 'connector' be stripped?
that would be the first place I would look. For replacement parts contact them at dremel.com and they can help if you can't find them locally.
Apr 13, 2011 | Dremel 100N7 Single Speed Rotary Tool Kit
How do i insert a bit? I've done it before, but so long ago I forgot and can't find the instruction booklet.
press and hold the small silver button near the front/end of the tool. This keeps the chuck/motor from moving. Use your wrench to then open the chuck and insert your desired bit. Tighten while still holding the button.
Sep 03, 2010 | Dremel Variable - Speed Multipro Rotary...
I have a rotary tool single speed chuck does not
Common issue with these, the plastic flex coupling is broken-
Replacement available for $2.57 from
http://www.searspartsdirect.com
Number: 2615294309
Category: Hardware and Tools
Weight: 0.18
Disassembly on my model involved the following:
Remove the four Torx screws on the body, then unscrew the front end cap at the front of the tool to expose two more screws. Separate the two halves of the body to see the brittle and broken yellow coupling.
Replace with the new white coupling and reassemble. Buy spare couplings as they don't seem to last all that long.
Mar 16, 2010 | Craftsman Single Speed Rotary Tool
My craftman single sped rotart tool the chuck with
Do you have any kind of a clutch on this drive ? I may be in bewteen settings.
Please let me know
Feb 06, 2010 | Craftsman Single Speed Rotary Tool
Coupler between motor and chuck disintegrated, where can I get a replacement coupler for a craftsman rotary tool model# 572.610011? Thx
As of 5-18-2010
The following is available from http://www.searspartsdirect.com
Flex coupling
Part Number: 2615294309
Weight: 0.18
$2.57 In stock
Sep 09, 2009 | Craftsman Single Speed Rotary Tool
I have a Dremel Single Speed Model 275 that belonged to my Dad. It suddenly won't turn on the end even though the motor is running at full speed. When I take my fingers and twist the end, it starts to turn...
The Dremel 275 (and other series) have a plastic coupler and spline that connect the motor shaft to the collet shaft (where the tools attach). The plastic fatigues and disintegrates, causing the collet shaft to stop, even if the motor is still running. The fix is about $5.00 --- two parts from Dremel. The 275 case is a **** shell that opens with the removal of six T-10 Torx screws.
Mar 28, 2009 | Dremel Tools & Hardware - Others
Open Questions:
Craftsman Single Speed Rotary Tool Logo
144 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Dusty Ryan
Level 1 Expert
Mike
John Trevino
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
