Question about XM Radio (XMP6000)
Signal drifts in and out - XM Radio (XMP6000)
  • 1,305 Answers
Make sure that your Xm antenna has a clear view of the sky. If your antenna cable is ok, and the antenna is in a clear location, and the antenna cable is properly plugged into the unit,
Also, if you're in an area with alot of tress, mountains, tall buildings etc... this can cause the signal to fade in and out.
Posted on May 30, 2010
Why does the signal go bad intermittently during a tv program?
Local interference or a drifting signal caused by being in a fringe area, receiving an additional signal from a reflecting source intermittently (such as when a train goes past nearby, a low flying aircraft or even a large truck) or a number of other possibilities.
Even a strong wind deflecting an aerial a little can be the guilty party.
Too much signal can be as bad for digital reception as insufficient signal.
A signal strength meter can be an inexpensive way to detect the source of your trouble.
Feb 17, 2015 | Digi Zinwell ZAT-970A tal TV Converter Box
My bobcat 743 drifts forward and bucket drifts back down,could this be slow leak noted in rear of cyclinder arm connection or other problem?
It maybe a adjustment that is incorrect on the valve bank the leak on the cylinder must be repaired soon can be connected with the bucket that is drifting down the drifting foward can also be a valve that is passing by
Aug 14, 2014 | Garden
My rg 66 signal meater dont work and no sound till it worms up whats wrong
frequency drifting on last number really doesn't make much difference. Lets say you are on CH 1 26.965 and the counter says the frequency is 26.9648 . Its not right but it close enough that its not going to make a whole lot of difference .Signal meter not working is not a problem either . You have to check the schematic for what voltage operates the meter,check to make sure that voltage is there. If it is then you should change the meter., if no voltage then you should check for the solution as to how to get it back. When the radio warms up and you hear people talking take some freeze spray and give the audio IC a shot to see if it still works or not .
Nov 17, 2012 | Ranger RCI-6900F-150 CB Radio
Codes P700,P1121 and P0122
Trouble Code: P0122
Are you sure on p1121 or was it po121 because there is no p1121?
Throttle Position Sensor 'A' Circuit Low Input
Possible Causes:
TP sensor signal circuit is shorted to ground TP sensor VREF circuit is open or shorted to ground
Trouble Code: P0700
TCU Request For MIL -ON-
Possible Causes:
poor connection TCM
Trouble Code: P0121
Throttle Position Sensor Performance
Possible Causes:
MAF sensor or TP sensor ground circuit has high resistance MAF sensor has drifted out of calibration TP sensor has drifted out of calibration TP sensor is damaged or has failed PCM/ECMTP sensor is damaged or has failed PCM has failed
Jun 08, 2012 | 2003 Kia Sorento
1977 chevreolet silverado 1500 Trying to remove ignition switch its stuck removed steering wheel and the blinker stuff ect. but the thing will NOT come out Any help thanks!!!
  1. Place lock cylinder in RUN position.
Do not remove the ignition key buzzer.
  1. Insert a small drift pin into the turn signal housing slot. Keeping the drift pin to the right side of the slot, break the housing flash loose and depress the spring latch at the lower end of the lock cylinder. Remove the lock cylinder.
WARNING Considerable force may be necessary to break this casting flash, but be careful not to damage any other parts. When ordering a new lock cylinder, specify a cylinder assembly. This will save assembling the cylinder, washer, sleeve and adapter.
Nov 30, 2010 | 1977 Chevrolet Silverado 2500
Tuning drifts
It sounds like the tuner is out of alignment. A number of things can cause this kind of problem. However, a realignment is a very costly proposition, especially when considering the used value of the Proton 320. If you really like this radio, you might want to try buying a used example off of eBay. They come up very frequently. Only... be selective. Don't pick anything from a seller without a lot of good feedback. And don't overpay ($50 tops).
May 08, 2010 | Proton R5A Clock Radio
I have a 2003 MPV and getting a troble code PO111. Just wondering what it is? Thank you.
Intake Air Temperature Sensor Circuit Range/Performance
Possible Causes:
IAT sensor signal circuit has high resistance IAT sensor has drifted out of calibration IAT sensor is damaged or has failed PCM has failed
Sep 28, 2009 | 2003 Mazda MPV
Cursor when using Logitech Trackball sometimes drifts up or down
I finally just was able to solve this problem! I saw somewhere that someone had made sure their primary mouse was selected under hardware, which got me thinking. I thought I had seen a second mouse option somewhere. So, I went into my Control Panel > System > Device Manager and click the arrow next to Mice and other pointing devices. Sure enough, there were two listed. A seemingly generic one and my Logitech I've been using. I right clicked on the generic one and chose disable and the drifting IMMEDIATELY stopped. I went so far as to re-enable that generic to see if it was a fluke because it had stopped drifting on its own yesterday, nope as soon as I enabled the generic device, drifting started again. So Happy!!!
Jun 11, 2009 | Logitech Trackman Marble FX Trackball
Satellite dish receiver error LNB Drift detected
that's not true i work for dish network if u have an LNB drift of -8 or +8 you can get a free lnb service call and they can come out n fix at no charge
Apr 22, 2008 | DISH Network 301 DTV Receiver
Car Audio & Video Logo
359 people viewed this question
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
Electro Med Services...
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
