Question about Samsung SyncMaster 2253LW Monitor
My screen has horizontal lines apprearing in gray on a black back it has started after 6 months of use... and its has become anoying... could it be the wire?
    President:
  • 1,768 Answers
Yes
1. this may be a internal loose ribbon cable or the VGA cable it self.
In any case you will have to have it looked at.
2. Check the pins on the connector end of the monitor. make sure none are bent or broken or loose.
Make sure the cable is secured to the video card.
4. Make sure you have the video card settings to the proper resolution. They could have changed.
If the monitor is 3 yrs old or more and it may need driver updates. check the manufacturers site to see. Via model number.
Posted on May 29, 2010
Getting 3, 2" wide gray/black lines in screen.
Please answer the questions in video to yourself and then give a more detailed description, as there are many reasons depending on what exactly is happening. TV Repair Help for Vertical Horizontal Lines on Your TV Screen...
Nov 28, 2015 | Proscan 32LB30QD 32 in. LCD TV
Displays horizontal black lines
It looks like you may have a screen fault which will need replacing
Mar 09, 2015 | Televison & Video
Panasonic CT-27L8SG displays gray screen and white hoizontal line
Is it still under warranty?
If not I would find a good TV Service Shop and have them check out the power supply as there more than likely a 'Capacitor' much like a battery that is going bad.
Blessings,
A/V Media Guy
Nov 22, 2009 | Panasonic CT-27SL14 27" TV
Front panel blocked or locked
RCA Entertainment Series 32" Plus Gold, GEMSTAR, xbox ready has been in the shop twice so far. Transformer replaced and 6 months later the picture suddenly had horizontal white lines that gradually spaced apart more from top to bottom and it had a gray hue and fuzzy, but I still watched it for 3 months that way. Today I turned it on and about a minute later I heard a loud crackling sound coming from the back and the picture disappeared, screen went black. Is it worth fixing again? Please contact me at ninalashua@yahoo.com
Jul 09, 2009 | RCA 32F531T 32" TV
When first turns on, large black horizontal lines make picture unwatchable.
from possltd@hotmail.com the problem is the 3 thin ribbon wires that go to the lcd have become lose,or something else open top cover 6 screws 4 on the sides 2 on top must remove dark gray plastic piece have pic if needed Oct 4th 09
May 30, 2009 | Sony VPL VW10HT Multimedia Projector
A horizontal (2mm wide gray line) appears along my screen steady.
try plugging into an external monitor.. if the screen looks ok then it is most likely the laptop LCD screen is bad.. had the same thing on a HP laptop .. replaced the screen and all was well again with the world...
Dec 23, 2008 | Computers & Internet
Black horizontal lines
Sounds as if you have a bad capacitor in the horizontal deflection or video circuitry. You can spot a bad capacitor in circuit with a ESR meter.Hope this helps.
Jan 16, 2008 | Mitsubishi TS-5545 55" Rear Projection...
Screen not displaying whole letters because of horizontal and vertical lines
I've had the same problem. A temporary fix that I have found is to turn up the contrast all the way (press [2nd] then hold down the up arrow) until the screen becomes mostly black. Then turn the contrast back down (press [2nd] then hold down the down arrow) until it is at a normal level. If you can get rid of all the white lines when you turn up the contrast the screen will be back to normal. Unfortunately this does not permanently fix the problem because I cannot get rid of all the lines and it seems to be getting progressively worse each time it start up the calculator.
Oct 24, 2007 | Texas Instruments TI-83 Plus Calculator
Wide Horizontal lines on playback
Wide bands in the playback video indicate a clogged or defective video head assembly. If your cleaning tape appears to resolve the problem, the heads are getting contaminated. I would not use the same tape in this unit. Try cleaning the heads and then use a brand new tape to avoid clogging the drum assy again. If this does not resolve the problem, the drum assembly will have to be replaced. Hope this helps. Joe Weibel customelectronics.org
Feb 19, 2007 | Sony DCR-HC26 Mini DV Digital Camcorder
Philips monitor problem
Check that the pc to monitor vga lead is not loose at both ends, check your graphics drivers are upto date, although it could well be a monitor fault and replacment required, as don't think they are worth reparing these days
Nov 02, 2006 | Philips Business 104B Monitor
Samsung SyncMaster 2253LW  Monitor Logo
169 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
