Question about Echo Garden
My primer bulb on my echo weedeater has a hole in it, how do I fix this?
4 Suggested Answers
SOURCE: broken primer bulb
home depot has a fuel system rebuild kit that includes bulb, filter, hoses all for less than 7 bucks.
Posted on May 06, 2010
emonse
  • 5 Answers
SOURCE: primer bulb on weedeater won't prime
Try reversing the 2 fuel lines going to the back of the primer bulb,it sounds like they may have got installed wrong.
Thanks
Posted on Jun 17, 2009
#1 Taper
  • 1040 Answers
SOURCE: craftsman 28cc gas weedeater gas line connections
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
Poulan P2500 weedeater want start
change over the fuel lines on the carby
Mar 24, 2016 | Poulan P2500 17" Gas Trimmer
Tip
Easy way to install fuel line and primer bulb return line into gas tank
Chainsaw fuel lines enter the gas tank from holes in top of tank. They are sized for a tight fit to prevent leakage. Make it easy on yourself when pushing the line through the tank by cutting a long lengthwise taper cut with razor knife 3 inches or longer to easily feed through that tight hole. Once started you will then have to grab it through the gas cap hole with needle nose pliers, then cut the tapered end flush and add fuel filter. Readjust inside length by pulling from above, then cut to length to upper carb fitting. If connecting to primer bulb a filter is not required and make sure the line goes to fitting on primer bulb marked tank.
on Nov 17, 2015 | Fuel Line & Primer Bulb Repair Kits 2...
Why no gas going into primer bulb
There is a hole some where check prime bubble
May 14, 2014 | Echo Hedge Trimmer Throttle Cable...
I have a problem with an Echo-SRM 310
wrong primer bulb installed have to get right one this one not letting fuel come in
Nov 10, 2012 | Echo Garden
Where can i find a primer bulb for my weed eater ght-17...it's split. Do i need another part or can I just get the primer bulb?
You can get a primer bulb at any local lawnmower repair shop. These are less than 5.00 and very easy to install. the bulb primer is sold by it's self.
Best of it
Gary @ Fix Ya
Sep 06, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
How do I change the primer bulb on my Echo CS-3000 chain saw
The IPL for an Echo CS-3000 is here:
http://www.echo-usa.com/pdf/documentation/CS3000T1T1E_081303.pdf
See page 8. There is no shop manual offered, you will need to interpret the pictures. Didn't look to difficult. GL
Lou
Sep 06, 2009 | Echo Garden
Have an Echo Weedeater GT2000; just cganged the
check fuel hoses for tears as you prime make sure two screws are tight that holds the primer bulb
Aug 19, 2009 | Garden
Featherweight weedeater primer bulb repair?
featherweight weedeater - runs rough and has no power
Jul 03, 2009 | Garden
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Garden Logo
490 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
