Question about Riso RZ220 Duplicator
Riso rz 220 falla a 16 525 - Riso RZ220 Duplicator
    New Friend:
  • 34 Answers
Remove the master that is on the drum and press reset. You may have to press start if you see - - - - on the display.
Posted on Jul 17, 2010
Riso RZ 220 UI The master drum will not come out and the green light is not on.
This is for master drawer not responding to green light to be released question. Try turning ON machine (turn off first) while holding down the reset button. Also a mechanical way is a small hole to insert a pencil, eraser end first, just below green latch area. Just insert hold in while squeezing release latch. to drawer.
Sep 09, 2013 | Riso RZ390 Duplicator
How do I print two 8 1/2x11 sheets of paper on a 11x17 sheet on the riso 220? It keeps cutting my originals off.
RZ 220s have a smaller print area on the drum. I think around 9x14. Although the 220s can take 11x17 paper they cannot print over the entire area. (This is why I personally went with a RZ390. It has the 11x17 print area) Sorry, you're out of luck pal.
Oct 25, 2012 | Riso RZ220 Duplicator
Somebody that speak Spanish? Riso RZ 220 UI have a code that say P18 531. What is the problem?
P18-531 means: Print drum lock sensor is still ON even after 100 milliseconds after the print drum lock solenoid is activated.
Mar 16, 2011 | Riso RZ220 Duplicator
How do I make riso RZ 220 can print image area B4?
only solution is to buy a B4 drum, to costly and involved to modify A4 or other drum and will create many problems in paper transport timing.
Jan 05, 2011 | Riso RZ220 Duplicator
I have a problem error fo115 of riso rz-220
F01-115 means no master on drum at start of printing. Make sure you make a master before trying to print.
Jan 20, 2010 | Riso RZ220 Duplicator
F0115 riso rz-220
The code means there is no master on the print drum.
Jan 19, 2010 | Riso RZ220 Duplicator
Riso Rz 220 copies are coming out to light.
1)You can set the dencity of the riso on the controll panel before you do your masters.
2)Always use original ink.
3)If you are a bit technical you can remove the pressure roller and strip all old ink buildup from it.was it with water ann soap.
If you open the drum and take it out completely,the pressure roller is the black roller inside the machine that put directly pressure on the drum.There is only one screw to loosen and then it hooked out,but it can be tricky to hook it back if you not doing it every day.
Oct 29, 2008 | Riso RZ220 Duplicator
Riso RZ 220UI
1-need to find out if image is on the drum, make a copy and stop it open and look is there toner on the drum itself? yes then the problem is with the Seperation
2-No, then the problem is with the Transfer
Sep 05, 2008 | Riso RZ220 Duplicator
RZ-220 Error Code P04-513
that is the ink overflow sensor.
Jun 20, 2008 | Riso RZ220 Duplicator
1,050 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
