Question about HP DeskJet 5150 InkJet Printer
Keep getting error The Print Cartridge Cradle Cannot move. I have taken all taken all the paper out, there is no jam. I have disconnected the printer and computer at all connections. Still happens. When I try and print I can hear the cradle try to move but it remains on the right. I have taken out and re-installed both cartridges. Pressing all the reset buttons on the left does not work. I cannot turn off the printer by hitting the power button. Only way now is to disconnect it. Or....is it just dead. A.D.
  • HP Master
  • 4,924 Answers
No.is not ...probably it is something wrong with the cartridges ..either damaged or the cradle is stuck for some reason ...take them out again ..and check with care and see what can be wrong ...pay attention on the mounting in back ...and try again ...I suspect that the alignment of the cradle was not in the right place ..and thats why it is stuck...just try to get it out ..or move it from a side...a little..
Anyway after that if it has reset for drumm in the menu ..make all the resets available ...even for counter ..and see if it work s....
if it is not ...probably the cartridges are damaged...if you just refilled them and not used a new ones it may happen during the process..
Posted on May 29, 2010
I keep getting an error message about a paper jam for my printer but there is absolutely no paper jammed anywhere in the machine.
Have you tried a new toner cartridge, The toner cartridge has moving parts, and of the cartridge gets stuck, the printer may indicate a paper jam.
Also paper often tears when clearing jams, and the little shreds of paper can stay in the rollers of the printer and keep it jammed. Make sure to inspect all the rollers to make sure they move freely, and do not have anything stuck in them.
Aug 21, 2014 | D-Link D LINK DELL B1260DN MONO LASER...
My printer keeps saying print cartridge cradle is stuck clear jam then press ok, but there is no paper jam
Because it's NOT a paper jam, but a cartridge cradle jam, I suppose it's an ink jet printer??? if so, check for debrie arround the cradle shaft that could prevent the printing cradle to move from left to wright... you could also lubricate the shaft by rubbing a little bit of grease on it with the tip of your finger (verry thin layer), as ink sometimes gets on it and tends to become sticky with time...
Aug 10, 2011 | HP Office Equipment & Supplies
Message shows 'clear paper jam then press check mark....no paper jammed in printer but it will not reset.
message keeps showing print cartridge cradle cannot move, I have check everything, no paper jams nothing under printer, I am turned off printed but keep getting same message.
Sep 17, 2009 | Lexmark X4530 InkJet Printer
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
Cartridge cradle can't move, says paper is empty when it's not
OK....try removing the carts, close the printer, turn off, then disconnect...alot of the problems with the newer HP printers has to do with their ROM memory....if that doesn't work, then there is defintely something in the paper path, no matter how small. Try to eliminate the copy function....does the error happen as soon as the printer is finished powering up??
Jul 23, 2009 | HP Deskjet F2210 InkJet Printer
Print cartridge cradle cannot move & theirs no paper jam.
Kindly check inside if there are mechanical problems. Something stuff that blocks the cartridge...dirt for example...
May 12, 2009 | Office Equipment & Supplies
Error Message: "The print cartridge cradle cannot move"
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | HP PhotoSmart C4280 Laser Printer
The print cartridge cradle cannot move.
"The print cartridge cradle cannot move."
I fixed this problem by disconnecting the power cord from the power-strip and connecting it directly into the wall. My printer was not getting enough voltage from the power-strip. I hope this helps.
Nov 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
Print cartridge cradle is stuck ican't find where it is jammed
This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
Apr 16, 2008 | HP Office Equipment & Supplies
HP DeskJet 5150 InkJet Printer Logo
130 people viewed this question
Seeker5211
Seeker5211
