Question about Sony Playstation 3 (PS3) Console
When my ps3 is on 720p or 1080i there is this white fuzzy line that oulines certain images on the tv such a faces and clouds and such.. but when its on 480p its fine.. i bought a new HDMI cable thinking it was that but no it wasnt.. and its not the tv because i can watch TV in 720p without the problem... what is the problem
  • Ron Dufek
    Ron Dufek May 29, 2010
    Is this when playing games or DVDs? Have you tryed Blue ray disks??
This happens when using hdmi for me, free to air digital tv is fine, but playing games has the exact same problems as you describe, and even dvd's etc do it, but not very noticeable at all, needs to be slow paced with a high contrast in in the picture usually.
Posted on Jun 02, 2010
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
Green lines down length of screen on my samsung 40 inch LE40F8
The reason for the green lines are the resolution. I'm assuming you're TV is set at 1080i, not 720p or 1080p correct? What happens is the "i" stands for interlaced, meaning, your TV displays your images with scan-lines. The "p" stands for progressive, meaning, TV displays picture as a whole. You can not visibly see the scan lines when seeing 1080i, but certain TV programs are not outputting their show to the resolution you're at, which will cause you to have the green line up at the top of your TV. SOME TVs might let you adjust the settings to rid yourself of the scanline, but most consumer TVs will not let you without the maintenance code to protect your unit from over calibrating and braking your television. Hope this helps.
Mar 20, 2010 | Samsung LTN1535 15 in. HD-Ready LCD...
Magnavox 42"
You are correct=====Return it ! It's new, you should not have to have it repaired this soon.
Sep 23, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
I get a thin line of distortion on my sony xbr 42in
Your format is wrong. Make sure that your tv is in full mode and your direct tv is in 1080i stretch mode. This should correct the problem. Also, WB is having problems. This is common on their channel. If it is happening on any other channel, try the above. Hope this helps. JOHN
Feb 27, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
I have a 37 inch 1080p lg tv which i have just connected to a ht503ph via the hdmi cable. when i am watching the dvd it starts to flicker then the screen goes all white an fuzzy (like the tuning on an old...
Hi elcrozier.Try changing the resolution from 1080p to 1080i in the system setting on the ht503ph. I had the same problem and that fixed it. good luck
Dec 21, 2008 | Audio Players & Recorders
VCR/DVD combo connecting to HD TV
if the DVD player or HD tv doesnt upconvert to 1080i, then you are stuck with the native resolution.
Nov 12, 2008 | Vizio L37 Television
HD tv with the mitsu
Well if your refering to the right tv (check your model number) then this tv only supports 480i, 480p and 1080i. Ive never seen anywhere that it supports 720i.
The component wires should include three lines for each corresponding color, red green and blue, and finally white and red for left and right audio. I think that is what your refering to.
If everything is right, it should work, the fact your seeing green could be a number of issues... maybe its a direct tv box issue?
Apr 03, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Interlaced comes in fuzzy & with lines
you need to check if the dvd or games are doing the same thing on different inputs. if they have the same problems you might be looking at the single board or the focus block.
Dec 01, 2007 | Akai PT5598HD 55" Rear Projection...
I need the correct Settings for Samsung LNT4665FX to view the best picture
these sets are designed for a digital input source, so if you are on an antenna or analog cable it will not look as clear..also if you can set the source for 720p instead of 1080i..it sounds like a lower resolution but 1080i scans 540 lines 2 times to get 1080i and 720p scans 720 line each time,,
Nov 25, 2007 | Samsung LN-T4665F 46 in. LCD Television
Sony Playstation 3 (PS3) Console Logo
57 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
