Question about Welding Tools
I reloaded it with wire and now it wont stop feeding wire.I have a lincoln handy mig.Any help would be appreciated.
    Problem Solver:
  • 17 Answers
Is your trigger sticking or gummed up on your mig gun! Contacts may be loose also! Good luck!
Posted on May 30, 2010
My Lincoln 120 mig wont weld just sparks it feeds the wire n gas but wont weld wat can be wrong wot my weldi g mechien
look for a bad ground wire connection ---in the plug , clamp, position of the ground clamp surface,cleanliness( paint, rust etc) place the ground clamp as close as practicable to the welding point
Apr 03, 2016 | Lincoln Welding Tools
Wire feed have erratic speed when welding.
adjust your speed either up or down to match the amps required to weld
Jun 08, 2015 | Lincoln Electric Handy MIG K21851 Welder
My wire feed welder wont slow down. I was welding some thick galvanized pipe and went to turn the wire feed down and it didn't work
the speed feed rheostat(control) is shorted or you've got a short on the board if it has one. Hopefully just your switch. Check for a short from the switch to the drive motor. Remember, electricity can and will kill you. Be safe
Bryan
Nov 04, 2013 | Lincoln Electric Lincoln Easy MIG 140...
Porblem with lincoln mig welder 135
Use a voltage tester to make certain you have current at the steel roller assembly that the wire feeds through. Check the diameter of the wire also, to assure contact at the feed rollers.
Mar 18, 2012 | Lincoln Electric Welding Tools
Wire is broken off inside wire feed tube and wont pull through tube either
Hi:
You need to replace the gun's liner. To avoid this problem you must decrease the voltage or increase your wire speed.
A new liner will cost you around 20 buck at your nearest Praxair welding store.
If this was useful to you please vote. Thanks
Apr 15, 2011 | Lincoln Electric Handy MIG K21851 Welder
Turns on has good feed gas is turned on using .035 wire ( not flux core) and I get no spark
sounds like mabe a bad or dirty cennection check fuses and breakers if all that comes out good it is definitly an internal issue
Feb 28, 2011 | Lincoln Electric Handy MIG K21851 Welder
Hi I have a Lincoln Handy Mig I am running 0.30 wire welding a roll cage on a race car the welder keeps overheating {light keeps coming on} wont weld just sputters keeps kicking the breaker {20 amp}...
check to see if the cooling fan is working. put a box fan behind the welder so it will blow threw the vents on the rear, or better yet remove the side cover and let the fan blow into the side of the welder.if this works replace the cooling can......GOOD LUCK
Jan 29, 2011 | Lincoln Welding Tools
Century mig welder. The wire speed is spinning at max speed as soon as the machine is turned ON. Will only stop when machine is OFF.
My Century 225 mig has lost its power ...with adjustments to max it leaves a high weld deposit and low penertration.
What is the fix ?
Aug 14, 2009 | Lincoln Electric LE 83180 Century...
Welding Tools Logo
67 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
