Question about Ricoh Aficio 1515MF All-In-One Laser Printer
I was printing several pages today. A piece of paper got stock. I follow all the instruction. But the print bottom is still half green and half red. Why?
  • 903 Answers
Did you open both the front and side doors? Often, if you don't open both doors, the jam will not clear. Also take out the paper tray and make sure there is no paper jammed in there.
Posted on May 29, 2010
The printer is not printing all of the page. The first page usually prints nearly all of the page, subsequent pages less so. The paper is not being scrunched up, it's just not printing lines in the...
when you press ctrl+p for print there is a setting there by the bottom left which says "Print:" beside it check the check the list if it says "all pages in range"if not press it and then press the word
Nov 28, 2010 | Canon PIXMA iP1200 Photo Printer
Blank page feeding during print job
Please adjust paper size in printer properties.
Oct 09, 2008 | HP Deskjet 6940 InkJet Printer
My printer is only printing half of the page
half page? just half top page (top-bottom), or left and right. If just left half page, set page setup as actually paper wide that inserted. because, if actually paper wide is smaller than page setup, some epson printer jsut print half. before starting printing, the paper sensor measure paper wide first.
Jun 08, 2009 | Epson Stylus Photo 925 InkJet Printer
Epson R260. Brand new. Green light blinks, red stays on.
https://www.manualslib.com/manual/357821/Epson-Stylus-Photo-R260.html?page=55#manual says Epson's manual thinks Red
paper out light ) is on and green P power light flashes means
If you're printing on paper, your paper ran out or multiple
pages have fed at once. Make sure you push the tray lever
up to set the front tray to the paper (lower) position. Then,
load more paper and press the ) paper button to resume printing.
If you're printing on a CD or DVD, the CD/DVD tray is not
inserted. Follow the instructions beginning on page 27 to
insert the tray, then press the ) paper button.
Nov 06, 2017 | Epson Stylus Photo R260 InkJet Printer
AUTOMATIC ORIGINALS FEEDER
I'm trying to print/fax several pages but the feeder doesn't "grab" the paper--basically nothing happens...BTW, mine is the HP Officejet Pro L7780 All-In-One.
Sep 10, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Jun 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Kodak 5100 only prints half the page
My Kodak Easy Share 500 decided to only print 1/2 the photo today.  For over 1 year it has worked just fine.  Any ideas?
Apr 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Paper jams
Hi conniebrown you may be using a card that is too heavy for the machine check the specifications that you card is within the recommended guidelines of not use a lower weight card. Also make sure that you are putting the card through the tray 1 unit and that on the driver properties you have selected card stock. Try this I hope it works for you.
Hi Guest you may have a piece of paper stuck under that registration unit open front cover remove the transfer unit and also remove the toner cartridges. Once this is done at the bottom you will see where the paper guides through (Black unit with green piece in the middle) close the front door half way then you will be able to lift that unit up and check underneath it. There is normally a small piece of paper there causing your jam.
Hope this helps
Thanks J
Nov 05, 2007 | HP Color LaserJet 3500 Printer
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
Black line prints on back of paper
I have the same problem and I have not found any fix yet.
Oct 03, 2007 | Canon Pixma MP500 All-In-One InkJet...
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
