How do I clear and fix the error message "Wrong Disc" on my just purchased Mustek PL 510 portable DVD player? I believe I am proving Einstein correct on his definition of insanity! Could someone please help me with this problem? Thank you very much for whatever help you can offer before this DVD player imitates a rectangular, shiny, sliver frisbee.
  • smilodon1943 Apr 22, 2008
    Thanks for your suggestion. I was hopeful that you had the answer, but unfortunately the Lil Mustek PL-150 did not respond to the alcohol Q-Tip tickle method or the Menu "Ten Step."
    So, I'm still sitting here in Humidston, Texas with a recalcitrant Mustek PL-150 and the continually repeating "Wrong Disc" which is becoming as annoying as "Nevermore."
    Thank you for your help anyway.
    Smilodon
  • smilodon1943 May 10, 2008
    Well, okay, I have tried all the suggestions that all you kind people suggested, save boiling the darn Mustek PL510 in boiling oil. Nothing has worked and naturally I cannot find my receipt for purchasing this frustrating technical marble (and it doesn't even roll!). I have been informed that I cannot return the item without the receipt (I guess Mustek doesn't want the problem either). Mustek's attitude seems to be that I purchased the unit, therefore, it is my problem. C'est la guerre! To add a further insult, everytime I open the local paper to place it in the bottom of the bird cage, I see a lot of adverts for this vary same portable DVD player in many of the "Big Box Store" advertisements.
    Does anyone out there in cyber "FixYa-land" have any other solutions to this my original problem? I have already thought of the solutions involving explosives and the careful application of firearms, but I'm afraid the noise would disturb my neighbors and create a canine commotion.
    So I thank you all for any more suggestions that you might be able to send my way.
    Cheers from the old fossil,
    Smilodon
    Genius:
  • 1,665 Answers
  • 13,433 Answers
Seems to be a brand new unit, do you still need assistance with this one?
If its brand new Im sure you could get it replaced by another one from the shop if isnt working properly.
Posted on Apr 22, 2008
  • Ekse Apr 22, 2008
    The useable forms in your device are
    DVD, VCD, CD, MP3, CD-R, CD-RW, SD card, MMC card
    Heres a few things to check
    Make sure the disc format is supported by the player, its DVD? should work
    Check if the disc is defective by tryung another disc.
    Check the region code (local and disc)
    its possible that the disc you are trying to use is ment for another region.
  • 3,037 Answers
I love the Einstein comment, I've had plenty of those times
The first think I would try is to clean the laser lens with a soft cloth or a q-tip with a little Isopropyl alcohol
or you can try the following
Without a model number it's hard to tell but maybe it's set tot he wrong region. Try this to unlock it to be region-free:
1) make sure you don´t have any DVD inserted and have Door Closed
2) IN remote control :
3) press SETUP
4) IN the Front Panel :
5) press NEXT
6) press STOP
7) press PAUSE/STEP
8) press PREV
9) press NEXT
You should now see a new MENU. Go to Select Region and make your choice:
- region 1
- region 2
- region 3
- region 4
- region 5
- region 6
- By Pass
Select ByPass and you're sweet. Not sure if it'll work with yours but it's worth a go.
Let me know what happens, good luck and have a good day
Posted on Apr 08, 2008
  • Benjamin Patri
    Benjamin Patri Apr 22, 2008
    you could try leaving it unplugged for 5 minutes and see if it resets or anything
    If you get this working, please let me know what you did, thanks
    what did it do when you tried the region steps?
    Did you also try each individual region?
  • Benjamin Patri
    Benjamin Patri May 10, 2008
    If you really want to return it, may I give you the option of buying another one and returning this one with the new receipt (Use the new box). Of course, I would buy it from the same store and you shouldn't have to worry any more about this.
    How do you feel about this. Some people may not be comfortable with doing this but I see nothing wrong in it as long as you tried going the right way around the first time and the same company still is conducting all of the business with you.
  • 552 Answers
Here is a link to reviews on your unit.
There is one person who had to return his/hers for a new one twice because of this error.
  • Hjalmer Lamminen
    Hjalmer Lamminen Apr 22, 2008
    I purchased a cd player from an auction, and it was new.
    The auction got it from finger hut surplus.
    It did the same thing for me.
    I opened it up and found a circular magnet inside holing the laser in place during shipment.
    I was able to put a cd in it but it could not read the disc.
    When I removed the magnet it worked fine.
    I don't know if you have the same problem, but this is one suggestion.
    Genius:
  • 3,422 Answers
You can do a hard reset buy unpluging all the cords from the back of the player for 30min and then plug it back.
Goodluck..
  • 19,396 Answers
Disconnect from power, connect it back, when is restarting press eject
  • 2 more comments
  • Ginko
    Ginko Apr 08, 2008
    Yoy can access service mode doing the following:
    With no disk inside
    Press "SET-UP".
    Press “Next” & then “Prev”.
    using “Next” & then “Prev”. see if you find any reset procedure
  • Ginko
    Ginko Apr 22, 2008
    If cleaning the head with acohol did not solve the problem, then you have a defective lens. You need to call a service centre and eventually have the lens pickup replaced. Once the device is opend it must also be checked hat the motor is spinning and the belt in place. If is not lens or motor check control board elements for continuity.
    Here is how inside looks like
  • Ginko
    Ginko Apr 22, 2008
    Particularly, if you get wrond disk, It should be the lenst, try repeating the cleaning it, if it does not work it is likely to be an opaque/scratched lens in need of replacement.
  • Ginko
    Ginko May 10, 2008
    If you could not fix it by cleaning the lens , you should first ensure the motor is running (you can hear it), if the motor is fine, but the lens does not read cd track then you need to replace whole lens pickup, buying replacement from Mustek.
Não consigo carregar a bateria PL 510 DVD Portatil
Minha bateria veio com defeito, preciso comprar outra. O problema é que o aparelho é novinho, tem só uma semana de compra e a bateria veio com defeito (não carrega)..... estou no Brasil e acho que mais barato eu comprar outra do que ir até Orlando (EUA) pra efetuar a troca.
grato
May 14, 2009 | Mustek PL-510 Portable DVD Player
Battery charge
Simply plug the included power cord into the power input on the DVD player. Leave the unit "off". Allow to build a charge. The included power supply items are:
Flexible power supply: up to 2.5 hours rechargeable Li-ion battery,
12volt car cigarette lighter adapter and AC/DC power adapter
Jan 08, 2008 | Mustek PL-510 Portable DVD Player
Problem loading dvd
replace the lens of your dvd your problems solve
Sep 18, 2007 | Mustek PL-407H Portable DVD Player with...
PORTABLE DVD CANNOT PLAY
wifi password hack v2.1 activation code please give me code
Sep 10, 2007 | Mustek PL-510 Portable DVD Player
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
