Question about Sony DSLR-A100 K Digital SLRCamera Digital Camera with 18-70 mm & 75-300 mm Two Zoom Lens Outfit
Sony dslr a100 is making a loud humming sound for a few seconds after turning on and the shutter seems to be sluggish.
4 Suggested Answers
SOURCE: Sony DSLR-A100, error code 0x5b
Same here. My camera gives me the same error code unless I shoot with the largest aperture/smallest F-number.
Posted on Aug 30, 2008
  • 9 Answers
SOURCE: MY MEMORY CARDS NO LONGER
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.
Best regards - Michael
Posted on Feb 16, 2009
robmcd27
  • 423 Answers
SOURCE: I have a sony dslr a100 and when I hook up the
Was your camera off when you connected it to the pc? It has to be off in order to work. Also, Does your camera require drivers? You might have to have the driver installed in your pc order to work.
Also, did you plug in your camera to your pc and go to my computer to see if it's listed there as a drive?
Rob
Posted on Mar 05, 2009
Sony a100 wont turn on
If the battery is charged, try replacing the battery first. Also try turning on the camera with the charger plugged in. If neither helps, you will probably need to have the camera sent for repairs, but you can still try checking out the user manual for helpful information:
Sony Alpha DSLR A100 manual
Nov 11, 2013 | Sony Alpha DSLR-A100 Digital Camera
My Sony a200 DSLR is vibrating and making a loud noise HELP!
Sounds like the shutter is jammed. I would get it serviced at a Sony Service Centre.
May 28, 2017 | Cameras
Take apart sony alpha a100
Before attempting to take the camera apart, make sure to refer to the user manual. It will contain diagrams and schematics for the device:
Jan 05, 2012 | Sony Alpha DSLR-A100 Digital Camera
Hello, I'm having troubles with my camera, a sony alpha 580 dslr. I try to take a picture and the shutter stays down a few seconds when I don't have it set to that and it is making these awful grinding...
sounds like the shutter chain is slipping, or shutter is sticking, this does not look good. you may need to have the body replaced, usually camera shops will tell you that the repair costs more than the replacement.
i would take to a sony dealer for further advice, I assume you are still under garantee you should be ok. as this model only came onto the market last august. and usually has 24 months cover on parts.
I hope this was useful.
Jan 23, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Mi camara da herror de las Naciones Unidas Herror code = 0x59
On my Sony Alpha 100 I keep getting this error 0x59 when I press the shutter button. It takes the picture but I have to turn the camera off and then back on to use it again
Oct 23, 2010 | Sony Alpha DSLR-A100 Digital Camera
I cannot figure out how to use the timer setting on my Sony DSLR a100. HELP
Press the Drive button (marked with a one-handed clock). Use left/right to select the one-handed clock. Use up/down to select the delay, then press the OK in the middle of the cursor pad. Start the self-timer by pressing the shutter release button.
May 22, 2010 | Sony Alpha DSLR-A100 Digital Camera
SONY A350 when turned on and off makes loud vibrating sound
Hi, I have exactly the same problem. The vibrating sound happens when the camera is turned-on or off. It looks like the camera is auto-deploying the anti-dust functionality and the vibration tries to shake-off the dust on the sensor. But I tried cleaning up the insides.. no luck. Would appreciate any tips on resolving this issue.. thanks, KP
Jul 09, 2009 | Sony Alpha DSLR-A350K Digital Camera
Sony Alpha A100 shakes when I turn it on
It's actually, believe it or not, an anti-dust mechanism. All Sony Alpha A100's (mine included) do a little shake/vibration to help keep the dust off. It's nothing to worry about unless it lasts for more than a second.
May 14, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony a100...Freezing up
I am a pro photographer and one of my cameras is an A100. I have noticed this same problem and sometimes when I am shooting fast the shutter delays. I found the problem in my card. My wife bought me a card based on price.  I sugest you use a card that reads faster than the camera can write. You can get the specs on the Sony Camera Site.
Dec 20, 2008 | Sony Alpha DSLR-A100 Digital Camera
ERROR CODE 0x5b
This error message is an indication that a problem may have occurred with the aperture assembly in the camera. To resolve this issue, service will be required.
Feb 03, 2008 | Sony Alpha DSLR-A100 Digital Camera
Sony DSLR-A100 K Digital SLRCamera Digital Camera with 18-70 mm & 75-300 mm Two Zoom Lens Outfit Logo
75 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
