Question about Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit
Sirius radio with xm antenna
I have switched from a xm myfi radio to a sirius sportster 5 radio in my truck, the antenna plugs look identical, can i use the installed xm antenna with the new sirius radio?
  • Sirius Expert
  • 473 Answers
Not the best plan, but it will work for a little while. The new "SXM" will work, but when the companies were separate the XM and the Sirius antennas were designed to work only on their half of the bandwidth, so sensitivity would be lower and they used different phantom voltages for the amplifier built into the antenna. That being said, I've seen it done.
Posted on Feb 27, 2013
  • 20 Answers
Not advised. They have different resistance and are set up for different Sat signals. Chances are you will decrease the life of your radio if you get a signal at all.
Posted on Apr 27, 2008
I have a 2014 dodge ram pickup with xm version of sirius xm. In northern canada xm signal is horrible bit sirius works flawlessly. Is there a upgrade to switch to sirius signal without adding a stand alone...
The 2012 Dodge Caliber had a Sirius radio instead of XM - BUT - you will have to check if it has a "FAST" or a "SLOW" "BUSS SPEED" - that is very important that the radio you replace it with has the correct buss speed. Sirius will only work a little while longer as they are eventually going to phase out their overhead satellites for a geostationary satellite like XM. XM has the better sound than Sirius - if you can receive them. If you can't find a factory replacement from 2012, then BestBuy still sells a Stratus Sirius radio - and you can probably even fish-out the antenna wire that you already have for use with the plug and play add-on Status. Good luck - let me know if you have more questions.
Jul 17, 2014 | Audio Players & Recorders
Sirius radio problems
I would do the following, hoping one of them works.
1) DISCONNECT the power to the radio and SiriusXM unit to "clear" it. Then reconnect and ask Sirius to resend signat.
2) Ask Sirius to UNSUBCRIBE that radio so it is deactivated. Then, have them reactivate and resend programing signal.
3) Be sure your car is outside under clear sky when Sirius sends the program signal.
4) It is possible the antenna cable to your unit is loose at the connections and/or damaged. A weaker signal may get your stations, but may prevent the additional Navigational signals. Have the antenna checked thoroughly and tested. If car is still under warranty, this should be a covered diagnostic/repair.
5) Finally, be sure the correct Radio Serial Number is being activated. If your radio works, that is one service. But maybe they are putting a wrong number by some chance into the system to fix this one? For example, you have TWO radios in TWO cars. Are they sending the turn on signal to the WRONG radio? Not as farfetched as you might think.
Jun 19, 2014 | Delphi Roady XT XM Radio Receiver
Why can't i get oprah on my sirius radio natalieromyn@shaw.ca
On Sirius radios, some programs require a subscription to the "Best of XM" and on some XM radios, you need a subscription to the "Best of Sirius" to get their programs. Call XM/Sirius and ask them, but I think that you have to pay extra for the "B.O.XM".
Jan 18, 2011 | Sirius Sportster 5 Satellite Radio...
My sirius portable radio keeps displaying "no antenna detected" but it's plugged in.
Several possiblities: one: antenna really is bad - borrow a friends Sirius or XM antenna and plug it into the base and see if the message goes away -if it does, replace antenna; if not, then your 'dock' or base could be bad - try removing and reinstalling the radio or try another base. If another base and antenna don't solve it, then the radio is shot and it's time for a new one. Customer service will ususally give you a great deal on a new XM radio IF you agree to keep it for 1 year. Let me know how it goes.
Jan 12, 2010 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Same problems here also, had sp-1 for 4 yrs no probs at all! I even have a brand new antenna, needed to be replaced any way, thought that would fix problem (ACQUIRING SIGNAL) No luck ,why does everything...
Go to XM, I did. But first, call Sirius and ask them to 'refresh' your receiver. Leave unit on channel 1 for 30 minutes and see if problem go away. Make sure to turn off and on with pushbutton on unit - not remote, and do not just diesconnect power..
Dec 28, 2009 | Sirius Satellite Radio Sirius Sportster...
Can't get XM channels
Goto sirius.com. You will need to access you account and find out if your radio is upgradeable for XM channels. You can find that out once you try to add xm to your account.
If it isn't you can get a free or a discounted radio from them to do it by calling customer service up. They do that for existing customers.
Jan 17, 2009 | Sirius Satellite Radio Sirius Sportster...
Sirius vs. XM
Hello pdweidner,
The CN-NVD905U is fully satellite ready and is compatible with both Sirius and XM. To change services you will need to purchase and install a XM compatible tuner and antenna to replace the Sirius tuner and subscribe to XM service.
Best regards,
Ken
Go Ahead. Use Us.
May 13, 2008 | Panasonic Strada CN-NVD905U GPS Receiver
Power supply to Sirius Radio
yes, some sirius radios work on 5 volts, and some work on 12 volts. Your sportster replay is a 5 volt unit. If you trace that wire back, you will find a cigarette lighter plug with a transformer built into it, with either wires soldered to the terminals, or a female cig plug wired up behind the dash. Whatever sirius unit you plan on hooking up, I strongly reccommend using the transformer that it came with......however if you're willing to take a chance, it's most likely 5 volts.
Aug 18, 2007 | JVC KT-SR1000 SIRIUS Radio Receiver
SIRUIUS SPORTSTER
Satellite radio antennas do tend to fail sometimes. In the early days of Sirius/XM they were made a lot better, but now I've had problems with them a lot more frequently. If the antenna is plugged in securely and it still shows the 'antenna' error code, you most likely need to replace your antenna. It is possible that something else along the antenna signal path is causing your problem - Sometimes the antenna connections in the dock or the receiver itself can cause the issue, but most likely it is the antenna.
Feb 25, 2007 | Sirius Satellite Radio Sirius Sportster...
Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit Logo
320 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Iron
Iron
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
