Question about Dell Inspiron 1525 Notebook
My dell inspiron is dead...Nothing happens when the start button pushed....No response at all....Tried with the battery in and also without the battery...
  • Dell Expert
  • 393 Answers
I have exprince about this problem and i solve many times only u need to update bios... how its diffcult ...coz u need to open laptop and remove ic then u have a programmer for reprogramming ... bios file i can send u that's if u send some 1 they will cahrge u for mainboard price... but this way is very cheap... my email is sim4182@yahoo.com
Posted on Sep 15, 2010
    Problem Solver:
  • 11 Answers
Does any of the lights come on? Because Dell Inspirons have a bad habit of the AC input breaking. this means that the pc will not be recieving any power from the cord, and if the battery is completely dead the computer will seem dead too. try using your battery/cord in another simalar laptop and see if it work there. if so then you will need to get a professional to inspect you motherboard.
Posted on May 29, 2010
3 Suggested Answers
  • 163 Answers
SOURCE: My Dell Inspiron 1150 PC Notebook Won't Turn On
Norm.. Suffice to say these are a problem. Is it a P35 Adapter? If so look for a replacement and retry. If this does not help Check the CMOS battery voltage as crazy as it may seem but the Dell adapters are a little more complicated than a standard 2 wire output adapter. They have a 19V Feeder or main supply, The Negative or Ground as some people/techs call it as well as a 3.3V data circuit thats related to the Embedded controller chipset, BIOS and other circuits on the board. Also see if you can find a friend local with a known good working battery/adapter if you cannot afford or dont want to spend money on it. If all else fails yell back weve repaired a ton of these and they should have been included in the 5150/5160 Dell Class settlement in my opinion as they have a ton of similar components/issues..
Good Luck! Ken
www.ikenfixit.com
Posted on Jan 15, 2008
SOURCE: Dell Latitude D600 won't power up
Dell power jacks are notorious for losing the solder connections. If all else fails remove the motherboard, use a solder wick and remove the old solder and resolder the connections. There are four pins that are close together so you need to make certain you do not over solder. Hope this helps
Posted on Apr 11, 2008
Dell inspiron mini wont start when pressing the start button the optical mouse light up laptop wont start I tried the static charge but nothing happens pls help,
If the computer is under warranty you should take it to Dell. If not you can try removing the battery and try to turn it on. If that does not work then you might have to open it up and remove hard drive and memories to see if that helps turning on. My best advice is take it to a service center.
Oct 04, 2014 | Dell Inspiron Computers & Internet
Can't get my dell Inspiron 1525 to work. Tried all the obvious . It simply won't load anything. It freezes just when you think something is happening. Please help
Try to "Cold-Start"your laptop: 1) unplug from AC outlet, 2) remove battery,3) hold on/off button for 10 seconds, 4) replace battery 5) plug into AC outlet, 6) try to boot normaly. let me know what happens.If it fails repeat process and when you push the on/off button REPEATEDLY TAP THE F-8 KEY until you get a response. let me know what happens.
Nov 01, 2012 | Computers & Internet
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
My dell mini inspiron doesn't work when i turn it on; it starts but then nothing, it is obvious that it is on but it is only a black display on the monitor. What could be the problem?
You can switch it OFF and remove the battery.
Wait for 5mins, Connect the battery again, Also connect the Power Cable to the Laptop.
Try to switch it ON, It should work.
With regards
FIXYA team
**Please post your feedback and Vote if the problem resolved as per your satisfaction**
Oct 08, 2010 | Dell Inspiron Mini 10 Notebook
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Inspiron 1501 won't turn on
It sounds like you tried all possible solutions. The only thing left is to remove the hard drive. Also try disconnecting the LCD display by unplugging the LCD connector from the motherboard. If the laptop still doesn’t power on then your motherboard is probably defective and needs to be replaced. If it’s still under warranty Dell will replace it.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 06, 2008 | Dell Inspiron® 1501 (N11157) PC Notebook
Dell Inspiron 9200 stopped working does not power on
This is a very useful post from LapTopReapir-101
Laptop is DEAD. How do your troubleshoot the problem?
In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
Let’s take a look at two different scenarios.
Example 1. The laptop is absolutely dead.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
What you can do in this case?...
For more in this article please click on the link below.
if you have other questions just lemme know
Sep 19, 2008 | Dell Inspiron 9200 Notebook
Powers on immediately powers off
ok well there is somwhere to start i would see if you can get it to take a charge ok and if it does than try to start it without the ac power on and see what it does if it wont take a charge your battery may be bad or your charging circuit may not be connected correctly ok lrt me know best regards mike
Aug 27, 2008 | Dell Inspiron 5160 Notebook
Not starting
Just to sum it up, are we talking about the Dell Inspiron 1750 or a Dell Inspiron 6000? Seeing two different things here. With the regards to the ac adapter, How "Warm"are we talking about here. 1 to 10. "1" 100 below 0 or "10" Nuclear Reactor Hot? Any adapters can get warm to the touch without overheating and frying. Was there a blackout or power outages in your area or T-Storm on the day you left. Take off the battery from the laptop. Check the battery lights. Do they flash or do they all light up when you press the button. With the laptop not working, lets hope the battery didnt fry the mainboard. Have you try to fire it up again after the adapter has a chance to cool down. By now, it should be fine, if you haven't use it.
Let me know
comier957
Aug 10, 2008 | Dell Inspiron 6000 Notebook
Dell inspiron 6000
On ac power when you hit the power button, if there are no lights, it could be the power supply. If there are lights, try starting it without the battery, ac only. If there are lights and it still doesn't start after removing the battery, try a different memory chip. On Dell machines the battery can acquire a dead short causing it to not start. Also if the memory chip/chips have gone out it will cause it not to start. If it still will not start after these three it's a motherboard problem and will most likely have to be replaced.
Jun 15, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 1525 Notebook Logo
133 people viewed this question
Alun Cox
