Question about Campbell Hausfeld 28 - Gallon Air Compressor
I have an FP205100 2gallon max rated 135PSI portable air compressor - it won't hold more than 40 psi no matter how long I leave it on and it doesn't seem to pump up my tires.
Check valve on top of tank
Posted on Jun 01, 2010
My sears air compressor model 919.156781 will not pump up past 40 psi , then motor then compressor stalls and motor gets hot , have to unplug . I have had the motor checked
When it gets to 40 psi turn it off and see if you hear air leaking down from somewhere....if so listen and feel around the edges of the compressor head. If you hear or feel air leaking there you may need to replace a head gasket.
Jun 13, 2014 | Craftsman 20 Gallon Portable Horizontal...
How to get more hp out of a honda 5.5hp engine
Your compressor was designed to produce 11.8 acfm at 90 psi turning neer max rpm (depending on pully combination between 800 ~1100 rpm ) with max pressure of 135psi. At 3600rpm the engine is producing max hp of 5 to 5.5. More power would not really produce more air without potentially destroying the compressor pump by over-reving. If your compressor is not functioning properly you will not get good air flow. Check instruction manual for time period to fill tank from empty. Could be 2 ~3 min. It is takes longer then problems. You can tell how your pump is doing by periodocally checking the length of time to fill tank. The next size range of gas compressor is about 8~9 hp with four cylinder pump and will deliver about 17 cfm.
Mar 15, 2011 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Looking for SCFM rating for a Mastercraft Model # 820218 air compressor
I have a Mastercraft 820218.
Specs are: 2 peak HP 5 Gallon tank 5.0 cfl @ 40 psi 4.0 cfm @90 psi max pressure 125 psi
Jan 23, 2011 | Garden
Max pressure 40 psi
i would say rings r gone on piston if u take out oil filler bung to see if it blowing air dat will tell the tale
Jul 28, 2010 | Campbell Hausfeld 26 Gallon Low Rider...
Compressor fills,drains off a little but won't
sounds like the pressure switch is fused shut, more than likely it needs to be replaced, most single stage pumps should shut off at 125 psi max.
Jan 21, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Need Manual for Husky Model 41214 Air Compressor
You can get the manual for model 41214 from my dropbox area:
http://dl.dropbox.com/u/54567653/husky_aircompressor_model_41214.pdf
BTW, if you find this manual helpful consider installing dropbox using this link (full disclosure -- I do get about 0.2 GB freespace from dropbox if you install using this link):
http://db.tt/vQycqXIW
Thanks,K
Dec 20, 2009 | Air Tools & Compressors
Howdy, I just acquired an air compressor, ''Westinghouse Air Brake Co., Type Y 3YC, SN 136848. I am wondering about parts motor config, cfm output, psi, etc. It appears to be a 2 stage & I'm thinking...
We have a Westinghouse 3YC air compressor. The safety relief valve in the line between the two compressors started "popping off" recently. The compressor seems to be working fine. Is this a problem only with the relief valve or could there be a symptom of a more serious condition that we should be attending to? The valve is stamped 60 max which I assume is 60 psi. Is this the correct size. The tank pressure is set for125 psi. The tank relief valve is marked 250 max.
Sep 12, 2009 | Air Tools & Compressors
Campbell Hausfeld 28 - Gallon  Air Compressor Logo
248 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
