Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Mtf 2155 gr refrigerator
Makes the same sound and leaks water
2 Suggested Answers
SOURCE: My Kenmore refrigerator is making dripping sound
Mine does same, there is no water on floor or around base of machine in back or sides. Most modern refrigerators have a cycle which uses a heating element to thaw out the coils and the water drips into a pan and naturally evaporates with or without a fan. That is how a defrostless refrigerator works. If the sound is continuous I suspect that there might be an "ice dam" buildup which could be approached by unplugging the machine long enough to allow it to melt or perhaps the heat element might be inadequate.
Posted on Apr 06, 2011
Lg fridge GR-B3993LQ is not cooling
Make sure that the thermostat is working and that the compressor and associated fans are working (getting Power).
If both units are working and still no cooling your evaporator could be frozen because the defrost timer/element is not working. Worst case scenario is that you may have developed a small leak and lost refrigerant.
Mar 11, 2015 | LG Refrigerators
My refrigerator is leaking water making noise and not making ice
It sounds like you have a leak (dry rot plastic tubing) on the ice maker water line. The leaking water is being picked up by you condenser fan near the water valves and probably causing the noise.
First, turn the water shut off valve to the refrigerator off.
You have a dangerous situation here. You need to stop the water leak. If the water leak gets to the electrical components of your unit, well it is dangerous!
You will be safe for now if you shut off the water.
You need a skilled technician to fix the problem. Just shut the water supply to the refrigerator off.
My name is Peter, retired Sears Service Refrigeration Technician. Pull the unit out so you can remove the lower back cover behind the refrigerator.
Oct 13, 2014 | Frigidaire Refrigerators
How do i remove drawers from bottom of maytag refrigerator model mff2258vew2
http://www.searspartsdirect.com/partsdirect/user-manuals/2155/MFF2258VEW2-Maytag-Parts-REFRIGERATOR-manual
Open this site and go to page 10, it has detailed instructions on removing the bottom drawer.
Jan 21, 2013 | Refrigerators
When ice maker draws water the supply line leaks from where it enters the refrigerator and makes a hissing sound. What is your take on this? it just started and the unit has not been moved in some time.
more than likely you have a friction leak in the water line the hissing sound is the actual water stream
hitting the wall,
the friction leak is common from the hose jumping when water pressure is first applied
a simple water union can fix this quickly and cheaply
Oct 03, 2009 | Maytag MTF2156GEW Top Freezer Refrigerator
LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Apr 08, 2009 | LG Refrigerators
Water is leaking from water dispenser
sound like the solinoids in the back oif your refrigerator may be leaking thru the valve causing the water the coutinue to come out and making a mess.
Feb 22, 2009 | Whirlpool GD2SHGX Refrigerator
Program mode
MTF stands for "Modulation Transfer Function" ... It's a somewhat arcane name for one type of testing methodology used in modern lens analysis. The *ist D's MTF priority program mode sets the "best" aperture to use for a given ISO setting and meter reading based upon lens information encoded in the latest FA series lenses. Earlier series lenses do not include MTF information in their communication with the camera so I suspect it defaults to Normal program mode when non-FA lenses are used.
Sep 08, 2005 | Pentax *ist D Digital Camera
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
54 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
