Question about Whirlpool LGR3624JQ Gas Dryer
DRYER RUNS BUT NO HEAT BELEIVE IT TO BE HEATING ELEMENT
RUNS BUT NO HEAT BELEIVE IT TO BE HEATING ELEMENT BUT NOT SURE WHAT IT LOOKS LIKE OR WHERE IT IS
    Novelist:
  • 77 Answers
With the gas machine you won't actually have a heating element. What you will have is a burner assembly. There are a few common things that can cause a gas dryer to stop heating.
The dryers have a square cap on the front near the bottom. Remove this with a knife or small object. Looking through this hole you are face to face with the burner assembly. Turn the machine on, if after 10-15 seconds you see a glow and the flame starts, you probably have a bad set of coils. Coils can allow the dryer to start, but after the flame goes off, they have problems starting it again. So, when you come back and find damp laundry, it may actually be heating, just not very well. IF there is no glow when you look through the peep hole, keep reading.
The most common part is a thermal fuse. This fuse is located on the back of the dryer. Simply unplug the dryer, pull it out, and remove the back (Eight 1/4 screws). The fuse looks like this http://www.appliancepartscompany.com/xcart/images/D/3392519.JPG it will be on the lower left hand side. If you do not have a multimeter to check continuity you cannot be for sure. This is a cheap start to figuring out your problem.
If you have a multimeter simply check the two terminals where the wires were plugged in for continuity. It should read about .1. This fuse goes bad when it gets to hot. There are few reasons this happens, but the #1 reason is that the vent to the dryer is clogged in some form or fashion. Outside the house where the vent exits should have a strong air flow while the dryer is on. If it is clogged by any means, the hot air cannot escape the dryer and the fuse will blow.
Two of the other commonly replaced parts are inside the dryer, accessible from the front. These parts are the ignitor and the coils.
Posted on May 29, 2010
Dryer runs but will not heat i checked thermistor and the thermostat and the heating element
Either the heating element is open or it is not getting power. It is one of the two!!!!!!!!!!!!!!!!!
Jun 14, 2017 | Dryers
Kenmore dryer dont heat
In most cases it's not a bad heating element there are a few checks you need to make before buying a new heating element, you can follow this guide to make the repairs:
Electric Dryer Runs But Dont Heat
Feb 11, 2014 | Kenmore 63942 Dryer
My Kenmore Elite H3 dryer check the lint screen comes on when I try to dry my clothes but the dryer does not produce any heat help me
You should check for continuity on the heating element. If you have continuity there, be sure you have voltage to the element. You have 2 (I beleive) temp sensors in line also. Check them, one may have a reset button (not sure). Make sure your exaust duct is clear to prevent thermo sensor burn out in the future.
May 16, 2011 | Kenmore 82822 Electric Dryer
Dryer runs but their is no heat the element looks good could it be the limit switchsafmac3@yahoo.com
Use an ohm meter to verify the heating element has not failed. If you read infinity on the meter then you need a new element. This would be a good place to start. The alternative is to verify you are getting voltage to the element. Also be sure to check the thermal fuse if one is present.
Feb 19, 2011 | Kenmore 62602 Electric Dryer
Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Jun 20, 2009 | Dryers
Dryer gets hot for the first few minutes only
first check your venting. if you have backed up lint then it will not heat as well. if it's not your venting i would check to see if your heating element is broken and shorted to the casing..some times it will still heat if the coils weld themselves to the casing...if the heating element looks good then i would turn to your electrical.
Jun 16, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
My maytag electric dryer will not heat up. it's a de107
Have someone check to be sure you have 240 volts to the plug. The dryer will run on 120 volts but must have 240 volts to the heating unit. If you 240 volts you probably need a heating element or control.
Apr 06, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Kenmore electric dryer no heat. heating element? or temp. dial? timer goes to 0 dryer still runs
SOUNDS LIKE HEATING ELEMENT NEEDS REPLACED BUT BEFOR YOU DO THAT TRY CLEANNING YOUR OLD ONE WITH STILL WOOL FIRST THEN RUNNING THE DRYER
Mar 09, 2009 | Dryers
No heat from dryer
is it 220 volt dryer,if so check the plug at the wall and make sure you have 220,the plug runs off 2 circuit breakers at your electric panel,1 breaker may be no good so your only getting 110 volts to the dryer which will run the dryer but not the heating element
Jul 08, 2008 | Dryers
Whirlpool LGR3624JQ Gas Dryer Logo
152 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
