Question about Danfoss Sundstrand-sauer-danfoss Sundstrand Hydraulic Pump
I have a sundstrand pump, model 15-2078. It has 4 ports, I know the 2 that go to the hyd. motor. I am not sure which one is the suction and which one is the return
    Problem Solver:
  • 11 Answers
The suction is at the front of the pump by the input shaft. The inlet can be set up as RH or LH by simply moving the plug to the other side.
The case drain is at the back of the pump housing between the 2 ports on the end cap that go to the hydraulic motor. There are 2 case ports 180 degrees from each other.
Posted on Jul 02, 2010
Which connection is the suction and which is the discharge for this model pump?
Inlet/Suction is always the port that is Horizontal.
Discharge/Pressure is normally Vertical.
So to answer your question specifically about this pump: The answers are above.
For others that may have a pump body that rotates, the discharge/outlet/pressure can/may also by choice, be horizontally exiting. But the horizontal port for discharge will now be "Perpindicular" to the motor vs. "Parallel" with the motor.
A "Horizontal" port Parallel with the motor will always be "Suction/Inlet"
May 02, 2014 | Hayward SP3007 10AZ Super II Pump 1Horse...
Taylor fork lift
If your old pump was knackered then I would change your return and suction filters, the insides of the old pump will be choking them. Also check your suction hose (make sure its tight). When the pump was fitted did the engineer readjust the relief valve on the control valve? Is your hyd oil level ok if not top it up it could be drawing air. Your hyd system could also be air locked aswell so it may be a good idea to bleed the system.
Aug 19, 2013 | Heavy Machinery
Dear Sir, We have one Sundstrand Turolla-200 make Hydraulic Pump, Model: TFP-200/6D SC51 LAA/9B , which is not building up hyd. pressure more than 80 bar. We are also not getting source of supplier for...
First you need to find out if you have fluid in the cylinder,if low or empty it will not build up pressure.Hydraulics are famous for blowing seals and bleeding hydraulic fluid everywhere. If you have fluid its possible the switch valve is sticking to go up or down or not working. if that is working check the pump motor to see if the motor shaft is attatched to the pump
Feb 15, 2011 | Danfoss Sundstrand-sauer-danfoss...
Need hyd Motor hyd p/n 23-3802 pump hyd p/n 23-2058 mfg sundstrand explain me, how to order and where? thks
Call Nova Hydraulics 317-322-0242 x103.
You will need the last 6 letters of your motor code.
A correct code example 23-3802AN-JSBJ.
Jun 03, 2010 | Danfoss Sundstrand-sauer-danfoss...
Charge pressure drops to zero when hot and grouls.Where is the charge pressure set? Jack
What is the model number and brand of your pump? Your description is a classic statement when hydros (your pump and motor) are failing. You can try charge pressure adj to make it work better. Model number will tell me where to direct you.
Mar 18, 2010 | Danfoss Sundstrand-sauer-danfoss...
I have a 3 stacked sauer hyd pump 1st one a spn3/55 d sc47 19m 2nd a snp2/17 d 3rd tfp100/3.2 d sc06/96 i'm looking for info an the flow gpm and pressure for each pump
Call Nova Hydraulics 317-322-0242 x 103 and you will get your information. What is the input rpm turning the pumps? The flow will vary depending on the input rpm.
Mar 13, 2010 | Danfoss Sundstrand-sauer-danfoss...
We are using a4vg125....DA...EP2 series rexorth pump in our motor grader can we use your 90R series pump there than what are the possible changes we have to make for this arrangement.
I can possibly answer this question but I need the full model number of the rexroth pump. The a4g is a great pump. I have many years experience with the rexroth line. And possibly can help you.
Dec 10, 2009 | Danfoss Sundstrand-sauer-danfoss...
WE ARE USING DANFOSS HYDRO MOTOR MODEL NO :OMS160 ON OUR PLASTIC INJECTION MOULDING MACHINE , I WANT TO KNOW ,HOW DO WE RECOGNISE A WORN OUT HYDRO MOTOR ANY PARTICULAR TEST TO CHECK OUT THE MALFUNCTIONING
Limit the pressure supplied to the inlet of the motor, plug the return port. Place the case drain line into a bucket, or install a case drain line if not equiped and comparte the flow to the manufacturers specs. I don't know what they are off hand, but shouldn't be more than 1 gpm I wouldn't think. Another quick test is if you can turn the bare shaft easily with no resistance when both fluid ports are open, the geroller set has quite a bit of wear. This quick test doesn't work in some applications such as wheel motors as they are sometimes ordered as "free running" motors. They are the same motor, but with a looser fitting geroller set.
Please visit http://hansonhydraulics.blogspot.com for more information.
Mar 06, 2009 | Danfoss Sundstrand-sauer-danfoss...
Pressure setting of series 90 pumps
Yes 90 series pumps will run pretty close to 6000 psi. there are cross port reliefs built into the endcap of the pump and usually a POR valve as well. so the POR should be set at 3000, the cross ports in the pump should be set higher than this. There may also be a "transmission block" which is a seperate block with hot oil shuttle and cross port reliefs. Make sure these reliefs are also set higher than the POR valve in the pump. There may also be cross port reliefs in the motor. These too must be set higher than the POR valve in the pump. If you system overheats after increasing the pressure setting of the POR valve, you are probably loosing oil across one of the cross port relief valves.
Please visit http://hansonhydraulics.blogspot.com for more information. I** If am electric motor is being used to drive this pump, be sure you have sufficient horse power for this increased load. **
Jan 29, 2009 | Danfoss Sundstrand-sauer-danfoss...
Looking for specs
You can get from BJ Hydraulics 269-623-6743
Jan 07, 2009 | Danfoss Sundstrand-sauer-danfoss...
Danfoss Sundstrand-sauer-danfoss Sundstrand Hydraulic Pump Logo
469 people viewed this question
Top Danfoss Garden Experts
frankrome
Tom Chichester
Are you a Danfoss Garden Expert? Answer questions, earn points and help others
