Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door only opens 1/3 of the way
We have a one piece garage door. We replaced the springs recently and it was working fine. Now it stops after going up 1/3 of the way. We have a Sears 3/4hp opener. I've lubricated the hinges and the tension is set to max. It stops in the same place every time.
  • 504 Answers
DOES THE UNIT STILL RUN WHEN THE DOOR STOPS - YOU MAY HAVE STRIPPED THE GEARS IN YOUR OPENER.
UNPLUG THE UNIT - TAKE OFF THE COVER AND LOOK FOR WHITE SHVINGS INSIDE. IF YOU FIND THEM BUY THE GEAR AND SROCKET KIT.
FOLLOW THE INSTRUCTIONS VERY CAREFULLY STEP BY STEP.
THIS IS NOT A REPAIR YOU CAN DO BY LOOKING AT THE PICTURES (DARN !).
HOPE THIS HELPS
Posted on May 29, 2010
Garage door moves few inches and stops, springs are fine, sensros are fine.
If it is not blinking when it stops, then the capacitor is blown. Replace the capacitor and it should resolve the problem.
Aug 09, 2014 | Craftsman Garage Door Opener 1/2 HP Chain...
Hello we have a Chamberlin 2265R 1/2 HP gargare door opener. There are two issues. 1) recently when we press the remote to open the garage door the door will travel a short distance then stop press it...
I have recently had the same problem. I found one of the brackets on the garage door was broken. The broken piece which was hanging may have been interfeering with the traveling of the door. It was a diamond shapped bracket labeled N1. the door opens and closes, plus putting stress on the dootr. works fine now, i am in the process as we speak to find a replacement bracket. It was driving me crazy. The door would open fine, but when closing it would stop then go back up, the light would flash. Check all yhe brackets on the garage door itself.
Nov 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Have 1/2hp garage door opener that will not open the door. If the remote pad battery is dead will the opener stop working? if I press the remote opener the door move about an inch stops and the light...
Dead batteries will not cause your problem. If it is the main light flashing 10 times when you try to close the door it is a door sensor problem. Make sure the small light on each sensor is lit and not flickering. Tweak them a bit to make sure.
Jun 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens about one foot and remains there.
Check the door springs. You could have a broken spring. Also remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It is possibly stripped. This is a good time to release the door from the opener and operate it by hand to see just how heavy it has become.
Jun 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door openly opens 5-6 in, then stops.
If the door isn't unusually heavy when you open it manually then maybe an adjustment will help. On the back of the motor unit you will find the 'up force' control. Increase it 1/4 turn and try.
Jun 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberline 1/2 hp belt drive opener that stops opening
It sure sounds like a broken spring. Sometimes the break can be difficult to see. How heavy is the door to lift manually. This will give you a good idea.
Jun 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Cant get wireless Keypad to Link to new Garage Door Opener
The radio frequency has changed and the old keypad will not work with the new opener.
Mar 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote Garage Door Openers won't work
Does your wall console have a LOCK or VACATION setting. Turn off.
Dec 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
