Question about Toro Lawn Mower With Toro Power Tools
Toro 120 proline groundmaster keeps cuting off and blades stop after 30 minutes
2 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: My toro groundmaster 225 wont start.
Check for a loose ground on your battery and for a blown fuse in the electrical system
Posted on Sep 16, 2009
I need a diagram for toro deck 30753
Hi
I have located both the owners manual and a parts manual with breakdowns of all the components of your Toro 52" Groundsmaster mowing deck.
Both can be downloaded from Toro directly at the following link;
Toro 52" side discharge mower, Groundmaster 120 Toro Direct link.
I hope this helps you and if you have any further needs, please feel free to ask.
Jul 11, 2014 | Toro Garden
Toro groundmaster 325d wont turn off and belt keeps coming off
The won't shut off has to be a faulty ignition switch. The belts coming off indicate a problem the belt pulleys.The bearings may be bad and freezing up, this will cause the belt to smoke and tear up as well as make the pulley wobble . Does it smell like burning rubber ?? If not then you have a pulley out of line and or a pulley that's cracked or broken. Also check and make sure the deck pins are all in place and the locks are down on the quick release on front and side of deck. While the blades are disengaged turn all the blade hubs and pulleys to see if the turn fairly easy. Check for play or wobble in the pulleys and blade hubs(bearings and blade shaft, also known as the"spindle assembly") attach to these pulleys. Also check the idler pulley(also called the tensioner pulley for wear and check to see that they are in alignment with each other).
Apr 28, 2014 | Toro Garden
Toro Proline 400 blades fall out of engage
if your unit desengages have the clutch gap checked. also you should check for shorts in your safty wiring. the other would be a bad switch. finely your under warranty this my be warranted.take it to a toro dealer or call one to make sure
Sep 07, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Groundsmaster 72
Have a toro groundmaster 72 that the spline went out in the power drive adaptor. the part is not avaible from toro.21-2260
Aug 30, 2008 | Garden
Toro Lawn Mower With Toro Power Tools Logo
114 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
