Question about Kitchen Ranges
I have a Inglis smooth top stove, model IME 8230. One of the front has a dial for single/dual --for quick heat up. It was working fine, til couple of days ago, it suddenly went haywire. When I turned it on to low or just #2 (meaning should be low heat),either way to the single or dual , it just heats up realy high(hot), like it 's turned to 8/max for high heat. Normally the element will come on and off when set at any setting(the setting on the dial from low to max); now, it won't go on and off, the element stays on and turns on really hot even set at low. What can be wrong with it??? Would the glass top be able to withstand the high temp. of the element if it does not go on and off periodically????
  • Anonymous Mar 16, 2014
    the top heating elements stays on high, even after cutting it down to lowest number
    the top heating elements stays on high, even when cut down to the lowest number
  • 135 Answers
The swich for the burner is bad and needs to be replaced. The glass will be fine, but unless your just boiling water you wont be abe to use it until you replace the switch.
Posted on Apr 08, 2008
On the stove each eye has to settings you can either turn on single high medium or low or dual high medium or low I don't own the front I don't understand what that means what does that mean
It has two sets of elements, a single one in the middle if you a cooking a small item, or dual elements that cover a larger area for cooking large items. This works for the top hobs, and also for grills/broilers in many stoves. If save electricity, and also having heat outside the base of a small pan. I see yours says 'Accusimmer', so it is a Whirlpool and it is the top hob.
If you Google
make model manual
You will probably find it online. Here is some information
whirlpool accusimmer manual Google Search
Feb 21, 2018 | Kitchen Ranges
I have KitcheAid KERS 807, electric stove/oven range. Left lower part of ceramic stove top that has single/dual heater sizes is malfunctioning. Single one is still working but from recent dual does not.I...
Either the knob has gone out or the burner element. I would test the knob first to see if there is current when turned to the large zone. If the knob is working, next would be to test the burner to see if the outer ring has burned out. I would guess more likely the control has gone out. Burners have less failure (typically).
Apr 14, 2014 | KitchenAid KERS807SSS Electric Kitchen...
Whirlpool electric oven not heating (has a functional stove top)
Hello Daniellel583! We are terribly sorry to hear of your concern with your Whirlpool Range. Please respond back to this email address with your name, reviewer name (Daniellel583), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool RF111PXS Electric Range
My oven wont heat up at all. gets no gas. the top
your glow coil is wron out , need to replace it, you may see it glowing in there but it isnt getting hot enough, usually you can switch out the broil one for a quick fix to get you outta truoble. easy do it yourself problem
Feb 05, 2010 | Frigidaire FEB27S5A Electric Single Oven
Surface burner on electric smooth top range not heating. When turned on, the left rear burner does not light up at the dial or on the surface. How can we determine if replacement is necessary or there is a...
I have a GE Spectra smooth stove top and it has two burners in one, The problem is that the inside burner is not working. I need to find out how I can get into the stove to see how to fix it. Does anyone else have this problem and how did you fix it?
Jan 24, 2010 | Kenmore Kitchen Ranges
Code : E3 -F1-
I have an Inglis electric stove with a self cleaning oven We turned the left dial to "CLEAN" and when turned the right dial to clean, a buzzer went off. Can you give me any advise?
Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
My right front burner will not turn off on my electric stove top.
Its probably the switch for that element, the contacts are fused. If this is a smooth top ceramic stove then the control relay board relay for that element is stuck.
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Thermador range electric model ref 30
in pre heating the oven it does not go beyond 250 degrees. what could be the problem. I have a thermador 30 inch dual-fuel range (rdf30).
Feb 16, 2008 | Thermador RDF30 Dual Fuel (Electric and...
JBP84TOHWW GE Electric Range Large Dual Element Not Working
similar problem after a power outage. Display would be blank until I turned ON an element (after which display would light, but no power to the respective element. No elements would heat even thought the dial shows power). Turning OFF the element would blank the display. I reseated the power cord and cycled the 50a basement breaker for 5 mins. Everything now works, but not sure for how long.
Dec 23, 2007 | GE Spectra JBP84 Electric Kitchen Range
Kitchen Ranges Logo
367 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
