Question about Acer Aspire One PC Notebook
Restore acer aspire to factory setting
Can't use alt + fn10 keys to activate the erecovery management. And no recovery disk. Please check and advice if there any other method that i can do to restore the original factory setting?
    Guru:
  • Acer Master
  • 468 Answers
For all Acer Netbooks try to initiate the recovery using Altgr key (righthand side of the space bar) and F10, ie Altgr+F10 as soon as the computer restarts. If the recovery partion is corrupted or do not have the CD. Try the below steps:
No Restore CD / eRecovery / password / ALT + F10 or F10
1 - Recovery of data on the hidden partition PQSERVICE for password
A - Installing the software R-Drive Image to create an image of this partition (this file has the extension. ARC)
B - Always with this software, create a virtual disk logic to see the files
C - From the desktop, go to the newly created virtual disk and find the file aimdrs.dat. The open with the notepad and get the password.
2 - Reactivating the ALT + F10
A - Always on the virtual disk created, find 2 files: mbrwrwin.exe and rtmbr.bin.
B - Copy these 2 files on drive C: \
C - Since the MS-DOS (Pocket PC) to C: \, type the following command: mbrwrwin install rtmbr.bin
D - The function has been reactivated.
3 - Start of Restoration
A - At the start of the PC, go to the set-up to check if the function is well on D2D enabled (normally it is a default setting ... but hey you never know.)
B - Once the audit and that the PC has restarted once the ACER logo appears, simultaneously press ALT + F10 to start the restore utility.
C - When it asks for the password, you need to type one found in the file aimdrs.dat. CAUTION: The keyboard is QWERTY mode so we thought enter his password, but as some letters are reversed, it does not work.
4 - Normally at this stage there ... everything works and restoration is smooth.
Note: If the operating system does not work, it is possible to do this from another PC by connecting the hard drive or USB slave
Posted on May 29, 2010
  • Acer Master
  • 4,924 Answers
If you can not use the f10 or f12 key ..it means that it do not have the boot menu there ...or it do not have a restore partition ...the F10 command is available in Hp laptops..with a recovery partition made on the hard disk ..
here you will need a installation cd of the operation system you want to install and the drivers from the acer support site..to suit it ..and just boot from cd by choosing that in the bios setting boot sequence ..and go for it
Im not sure for the model but if it do not have a optical drive ..than you will need to make a usb flash drive bootable with windows in it ,,and for that you need this kinda soft ..
http://wintoflash.com/download/en/
this is a tool that will take a windows from a disk and put it in a usb unit and make it boot-able ..
also here is a windows Xp..image that can be burn on a disk with nero in the background ..and after that boot-from cd and install it ..
http://thepiratebay.org/torrent/5388204/Windows_Xp_Genuine
download it with utorrent..than be sure you have nero installed.and just insert a blank cd-r and double click the image file to burn it on disk ..
after that insert it in the laptop ..and restart ...if teh boot order is ok ..it will prompt you to boot from cd ..and press any key to continue..if not..go to bios by pressing F2 ..and in there on boot sector ..select cd /dvd first boot device ..and than use F10 to confirm and save changes..and restart an go for it ..
Do not forget to rate me ..
Acer Aspire One D250-08K Need to restore to factory settings and i have no disc. Screen is black. On start up pressed ALT F10 then nothing happens
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Aug 29, 2011 | Acer Aspire One PC Notebook
I want to reset my acer laptop to factory settings. what do i do?
It either came with a recovery disk or has the recovery info on the hard drive. Boot up and hold F8 to see if there is a system recovery option or use the disk provided.
Jun 28, 2011 | Acer Aspire AS5734Z4836 T4500 Notebook
Factory reset for Aspire one without disk and alt + F10 doesnt work
The disk-to-disk recovery may be disabled preventing the Alt + F10 key sequence running eRecovery. To enable disk-to-disk recovery, you must do the following... (do not have an external monitor attached)
1. activate the BIOS utility by pressing F2 during Power On System Test (while Acer logo displayed)
2. select Main from the categories listed at the top of the screen
3. find D2D Recovery at the bottom of the screen and use F5 and F6 keys to set this value to Enabled
4. exit the BIOS utility and save changes.
The system will reboot.
5. while the Acer logo is showing, press the Alt key and the F10 key at the same time repeatedly
6. wait as Acer eRecovery starts up then follow onscreen instructions to perform system recovery.
Alternatively to the above, if Windows can be accessed, the recovery can be done by launching Acer eRecovery Management by running the program from the Acer Empowering Technology program group in the Start menu.
Mar 22, 2011 | Acer Aspire One PC Notebook
I want to reformat my acer 4720oz please send me bootable disk
The Acer Aspire 4720 Notebook has a hidden partition containing files to restore the system to its factory default. On powering up, press the Alt key and the F10 key together (at the same time) repeatedly and after a minute or so, Acer eRecovery Management should start up. Follow the on-screen directions to do a restore of the system to its factory default. The restoration process will reformat the partition that is the C: drive. After restore has completed, Acer eRecovery Management can be used to create a set of disks for a full back up of your system's factory default image.
Mar 18, 2011 | Acer Aspire 4720 Notebook
How can i make factory setting for Aspire 5610 without recovery disc and/or with recovery disc
You do not have to make factory setting, infact you can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+F10 (try both), it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Thanks and regards,
Anil.B.R
Aug 18, 2010 | Acer Aspire 5610 Notebook
Restore to factory default
Unlike other laptops, Acer notebook/laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer Aspire 4315 to factory setting.
Step 1: Before starting your Acer Aspire 4315 laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer one to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer Aspire 4315 is reset to factory settings.
Tips: You can also create a backup copy of your notebook data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you face any issue with your Acer Aspire 4315 Notebook/Laptops/Desktop, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Jul 26, 2010 | Acer Aspire 4315 Notebook
I want to reset my laptop to it's factory settings.
hello.push DEL or F2 immediately after powering on.
Than your are in the bios
push F5 confirm
push F10 confirm
restart the pc
try recovery again
Jun 30, 2010 | Acer Aspire One PC Notebook
Need erecovery for acer aspire 5610z
Thanks and regards,
Anil.B.R
Jan 27, 2010 | Acer Aspire 5610-4648 Notebook
Acer laptop restore factory settings?
If windows is running you can start it by going to Programs, Acer Empowering Technology and run the Acer eRecovery Management. Note that on the bottom of the eRecovery Management window are 3 choices, Backup, Burn Disk and Restore. Click on Restore. Here you have the choice of select Restore System to Factory Default.
If windows is not working but the system boots -
Reboot the system and when the Acer logo appears, hold down the ALT key and press F10. This starts the recovery process, just follow the instructions.
Oct 19, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire One  PC Notebook Logo
2,035 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
