Question about Maytag Neptune MAH5500B Front Load Washer
Will not fill with water
Washer runs but willnot fill with water
  • 10,319 Answers
HERE IS A TROUBLE CHART FOR YOU WASHER
The codes displayed will refer which direction to repair
DOWN
LOAD
THIS
WEBSITE
http://www.applianceaid.com/neptune8.html
Posted on May 29, 2010
Drum willnot move on start.it just thumps
If the washer won't agitate the stator assembly at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects.
Sep 28, 2014 | LG WM2487H Front Load Washer
Zenith,water doesnot fill thetank
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 01, 2011 | Dehumidifiers
My dehumidifier is running but no water is collecting and the bucket usually fills in a few hours, what can be the trouble I cleaned the screen.
heatman101
Feb 15, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Ihave the dehumidifier turned on in my basement...fan runs....displays show the humidity, and temperature...but the tray does not fill up with water at all. Is there a specific setting for the humidity..I...
heatman101
Nov 13, 2010 | Fedders A7DH45B2A Dehumidifier
Water willnot shut off keeps filling
Where you connect the hoses on the back are solenoid valves, electrically operated. One of these could be bad (staying open) or the controller is bad and holding power on all the time. If it fills while the machine is unplugged, it's probably a bad valve.
Feb 27, 2010 | Washing Machines
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Washer is a top load set it hot water and starts with hot and then will go cold willnot stay on hot G E Profile ,model wwa8350g
most new washers sense water temp and will try to adj final tub water temp by alternately running cold or hot as needed ..most hot settings are not faucet temp but a predetermined temp so if your hot water is 140 degrees coming in the control will switch the cold on to bring final tub water temp down to preset ..which could be as low as 100 degrees the industry's way of energy conservation
Sep 23, 2008 | GE Washing Machines
Kenmore heavy duty 70 series washer
The washer starts on a fill cycle. If it's not getting any water check the screens in the valve where the water line hooks to the back. If it is getting water but not filling up pull up on the drain hose. If it is to far down the drain it can **** the water right out of the unit.
Apr 23, 2008 | Kenmore 24032\24036 Top Load Washer
Washer constantly fills with hot water even when turned off.
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
Jan 03, 2008 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
60 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
