Question about Frigidaire FER641FS Electric Dryer
In changing the dryer exhaust hose today a piece of the hose connected with the 220 plug --sparks flew-blew the braker and now the dryer will not work. Is the problem w/ the 220 plug or the dryer? Yes the braker is reset to "on"
  • marksfitz May 29, 2010
    of course the plug has burn marks but so far so good with the other stuff---Thanks!
    President:
  • 1,902 Answers
The problem is with the dryer. Check from the plug all the way to the back of the unit, remove the back panel and look for burn marks. Also make sure that you check the control board as that will keep the unit from being able to work also. You are going to need to check everything thoroughly with your eyes to make sure that everything is working and nothing has burn marks or been knocked out of its place. First thing is that you will need to replace the 220 cord.
Posted on May 28, 2010
We changed plug ins for our cookstove cause the other one went bad. When we pluged our stove back in and flipped the breaker back on sparks flew from the plug in. What could be wrong
You may have somehow shorted the circuit by leaving a loose wire not connected tight enough or it came loose and grounded against another wire? worse yet u misconnected the wrong wires incorrectly? lastly both ur ovens work on the same voltage? 220 vrs 110
Apr 22, 2015 | Whirlpool RBS275PD Electric Single Oven
The cord at the plug in is burnt but didn't trip the braker and the dryer is not working
Sounds like a loose connection in the plug causing arcing (sparking) cut back the lead and re connect to plug, if not confident ask someone preferably someone electrically minded. Good luck.
Mar 13, 2015 | LG Tromm Electric Dryer
Kenmore stacked laundry unit. when it was plugged in sparks flew and small parts of the heating element fell and the power cord is ow black. can we replace cord and be ok
Heating element must be replacedas well as the cord. Make sure the drum screws were not screwed into anything electrical.
May 18, 2013 | Kenmore Dryers
When turning on the dryer noting happens.
Seems your not getting power to the dryer, First check for blown fuse or reset the Braker for the dryer.thats 220 double braker. second make sure no one unpluged the dryer by mistake
If that don't help get back to me Good luck
Feb 20, 2011 | Whirlpool Dryers
Maytag Dryer sparks when connecting foil exhaust hose to vent
You have a bare wire inside the dryer laying on a metal part of the vent system. FIRE HAZARD
Mar 04, 2010 | Maytag Dryers
My 2002 Ford Explorer wont crank!
I'm assuming the coilpack got wet!! Check if there is any power to the coil before changing. If thats fine, replace the coil. If there is no power, check your electrical circuit for the coil. Hopefully this helps
Jul 23, 2009 | 2005 Ford Explorer
How do i connect my whirlpool
Connect dryer vent in rear of machine as per instructions. Make sure no kinks are present in exhaust hose as you move dryer into position. Insure proper outside vent is correct for your unit. Plug into 220 volt electrical outlet.
Jul 07, 2009 | Dryers
Whirlpool electric dryer
either you are pushing the dryer back to far and crushing the exhaust vent hose .your exhaust vent going outside is stopped up , or your low temp thermo will not let the dryer cycle and it is over heating.
Feb 27, 2008 | Dryers
Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
call bosch. they are having problems with one of the sensor in that dryer. they try to fix it but in my experiance they end up having to swap out the dryer
Nov 20, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Frigidaire FER641FS Electric Dryer Logo
16 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
