Question about Apple iPhone Smartphone
I cant put music in my iphone
I am traying to put music in my unlooked iphone version 1.0 i am using itunes 7.2 but the itunes is not recognizing the phone when i plug the phone in the upload picture box is coming up, i tried downloading itunes again and now the computer is not recognizing the phone what should i do
  • 265 Answers
Your phone will need to be restored. Un-locked phones are often rejected by iTunes.
Posted on May 28, 2008
Same issue here
Posted on Apr 11, 2008
My apple ihone is disabled connectto itunes
There are many reasons why iTunes will not recognize your iPhone, whether it's dust or dirt blocking your dock connector or a system setting gone wrong. No matter what model iPhone you have, here are a few suggestions for helping the problem of iTunes not recognizing iPhone:
1. Generally speaking, when iTunes does not recognize iPhone, it may have something to do with the version of iTunes. If you are using an old version of iTunes on your computer, it may not be capable of recognizing your iOS devices. So updating iTunes to the latest version is a fastest way to get the problem solved.
2. If you are running iTunes in the latest version, but still can't get your iPhone recognized, you may want to take a look at your computer, sometimes if your computer lacks necessary software, it might lead to the malfunction of iTunes.
3. USB port on your computer can be another reason why iPhone not recognized by iTunes. So you can try more than one USB port to see whether the USB port works well.
4. Of course, your iPhone may also be the cause of iTunes not recognizing iPhone. At this moment, you can restart your iPhone by holding the Sleep/Wake button and Home button at the same time until you see the Apple logo, then connect iPhone to computer with USB cable again.
5. You should also make sure your iPhone trusts your computer, because after changing a new system on computer, your iPhone will regard it as a new computer. What's more, you should check out whether Apple Mobile Device Support is installed on computer.
6. After checking out all the aspects mentioned above, you can try to connect iPhone to computer with the USB cable again.
If none of these methods work out, you may want to try set your iPhone up as new after iTunes not recognizing iPhone. You only need to tap General > Settings > Reset > Erase All Content and Settings, and then choose Set Up as New. When you have set iPhone up as a new device, you are able to connect iPhone to computer with USB cable. But before erasing all contents on your iPhone, you may want to back up iPhone files to computer to keep them safe.
http://www.leawo.org/tutorial/what-to-do-when-itunes-not-recognizing-iphone.html
Feb 07, 2017 | Apple iPhone Cell Phones
I pod is disabled
1. Manual reset by Home key + Down Volume key, this can fix many general iPod problems.
2. You may try this iTunes alternative, I always use it to upload music and video to my iPod once my iTunes can't recognize my iPod, my friends recommend it to me, it's safe and works pretty well, you can also use it to copy music and video from ipod to computer for backup, it's useful when you lost your iTunes library.
http://www.ipod-transfer-copy.com/ipod-iphone-to-computer-transfer-cucusoft.html
3. Update your iTunes to the latest version. Plug in your iPod. If iTunes can't recognize it, then in iTunes in the top left corner click help> run diagnostics. On the box that comes up, check the last two things. Click next and it should identify your iPod. I got this method from Apple technical support. Hope it helps. Contact me if you have any other question. 4. Take the iPod to Apple store, the technical support will help you fix the problem.
Nov 29, 2013 | Apple iPod Touch 4 Metallic Zebra Hard...
I cant upload music to my iphone 4 pls help
You can only upload music to your iPhone via iTunes.
First, open iTunes, go to File menu and click on "Add file to library", find the song you want to add and click "ok"
Now the song will show in iTunes. Do this for all the songs you want on your iPhone.
Once you are done, connect your iPhone to your computer. iTunes will recognize your iPhone. Click on iPhone, on the left hand side of iTunes. On the main screen you'll have tabs for your iPhone such as "Information" "Music" "Applications". Click on the Music tab.
Select "Syncronize all music" in the Music tab.
Now on the right hand side in iTunes, you'll see a button "Apply"
Wait for your iPhone to syncronize with your iTunes.
Done!
Apr 24, 2011 | Apple For iPhone 4/8GB LCD Screen...
I Tryed To Connect It Too ITunes. And , It's Not Popping Up Nothing ; It's Just A Black Screen . What Do You Think Is Wrong With It ?
1. Try another USB cord or USB cable. 2. Restrart your computer for a try.
3. Reset or restore your iPhone for a try, this way can fix many general iPhone problems. 4. Update your iTunes to the latest version. Plug in your iPhone . If iTunes can't recognize it, then in iTunes in the top left corner click help> run diagnostics. On the box that comes up, check the last two things. Click next and it should identify your iPhone .
5. You may try this iPhone transfer, it's a nice iTunes alternative that can help you upload music and video to iPhone , I always use it to sync my iPhone when my iTunes can't recognize my iPhone , it's easy to use and works pretty well. If you have any other questions, feel free to email me.
Mar 24, 2011 | Apple iPhone Smartphone
I cant get my music of my ipod nano onto my new netbook? i HAVE A NEW NETBOOK WHICH IS WINDOWS 7 AND I CANT TRANSFER MY MUSIC OFF MY IPOD NANO 4GB ONTO MY NETBOOK?
iDevices (iPod, iPhone, etc) usually can only be managed through iTunes. So the first thing you should do is install iTunes (you can download it off Apple's website).
After installing iTunes and connecting your iPod, you must open My Computer then double click your iPod's icon. Then, click on Tools, Options, and in the View tab check the "Show hidden files and folders" option. You should then see an "iPod_Control" folder. Inside it there'll be a "Music" folder, with all your songs. Just drag them back to your computer.
But remember: you can only manage your iPod's music through iTunes. If you add or change songs on your iPod without using iTunes, these songs won't be recognized.
Mar 22, 2011 | Apple iPod nano
Hi currently i have an iphone 3GS, i want to download itunes,, how to go about it?? thx
1- Download the latest version of iTune on your computer and open the program
2- Import your mp3 (music files) to iTunes
3-Plug your phone into the computer via the sync cable
iTunes should recognize your phone and sync the files to your phone
Dec 24, 2010 | Apple iPhone 3G 3Gs White Bulk
How do i transfer musics from pc to iphone? i failed to transfer it by using itunes lol. it says sync failed
I know a software Syncios is much more better than iTunes, which not only supports transferring music between PC and iPhone/iPad/iPod Touch, but also transferring other data, like photos, videos, movies, contacts, messages, podcasts, ebooks, apps, notes and bookmarks.
http://www.syncios.com/pc-to-ipad-air-video-photo-transfer.html
Oct 24, 2009 | Apple iPhone 3G
I cant send any music from itunes to iphone how do i set it up to send muic to the phone i have opened up iphone
1. Download iTunes.
2. Connect your iPhone to the computer.
3. On iTunes, you should see your iPhone listed under Devices.
4. Click on your iPhone.
5. Go to the Music, Applications, TV Shows, and all those other tabs and set your preferences.
6. Click Sync.
Now you can send music from iTunes to iPhone.
Sep 26, 2009 | Apple iPhone Smartphone
I have an unlocked iphone version 1.0,
Jailbroken?
Sounds bricked to me. Apple store for you, my friend. http://www.apple.com/retail/geniusbar
Apr 07, 2008 | Apple iPhone Smartphone
MUSIC !
You must have iTunes which probably came with it, Install iTunes connect your iPhone using the cable provided and it should recognize it.
Feb 08, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
132 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
