Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Making a noise and it's not cleaning the dishes
  • Frigidaire Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 27, 2011
Kenmore dishwasher whinning noise
seems your motor is making that sound try first lubricating it
Mar 15, 2008 | Dishwashers
Dishwasher LED not lighting and dishes not cleaned
If it's making a sound, that means you have power. You may need a control board or a console or both. Check the ribbon cable between the console and the control board for any loose connections. If everything is fine, replace the parts.
Mar 12, 2014 | Bosch SHU33A05UC Stainless Steel...
Amana dishwasher makes noise
something is probably down in the drain dish washer has a disposal like system at the drain
Sep 03, 2013 | Dishwashers
Makes noise during wash cicles and dishes are not cleaned
Hi Kenneth Cho - I will suggest verifying that there is enough water pressure coming into the unit. Is the unit making a grinding noise? If it is, then the dishwasher seems to have a defective drain motor. When was the last time the filter was cleaned? Do you noticed if the spray arm will rotate freely or if it is damaged? If so, you might have to remove and replace the spray arm assemblies. If any proves to be ineffective, it could possibly have a communication problem coming from the main control board, I would suggest contacting a professional technician to diagnose the unit accurately.
Nov 24, 2012 | Frigidaire FGHD2433KF Builtin Dishwasher
Making loud noises when washing, nothing is obstructing the top and bottom wash arms and the dishes are clean when the cycle is over.
Is there a chance the dishes are moving when the machine is on? Cound the water jets(spraying the door and sides) be the cause of the noise. Is the sound insulating blanket on the outside of the machine? Try running empty on a shor cycle to help diagnose the problem.
Nov 12, 2009 | Samsung 24 in. DB5710DT Stainless Steel...
How do you fix a noisy whirlpool dish washer DU1100XTP(Q) ?
A hard object has entered the wash module (on some models).
When the object is ground up, the sound should stop. If the
noise persists after a complete cycle, call for service.
Mar 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
49 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
