Question about Samsung ML 2010 Laser Printer
Offline problem on Samsung ML-2010
I have installed the drivers correctly on the computer (and re-installed them again and again just in case) But whenever I press print, the printer just sorta flashes a bit and seems to think about it, then goes to offline status
SOURCE: blinking lights & offline-use printer offline
hi! how can i align my printer cartridge?
Posted on May 30, 2008
Riztech
  • 731 Answers
SOURCE: Can't print because of Error-offline status.
Hi
To fix the problem permanently try the below solution, you will not experience this anymore.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for what location says, Eg -LOCATION : HP photosmart C6100
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Thanks
Riz
Posted on Jan 11, 2009
SOURCE: samsung ML-2570 series printer says
I encountered the same problem. I have several computeres at my home. While others print well, one computer (WinXP) could not. The error message tells me to plug the printer into network, but since other computers print well, this is certainly a mis-leading. I guessed it should be a firewall issue.
I then called Samsung at 1-800-samsung, but the guy over there only keeped saying this was not their printer problem, and I had to contact my firewall software provider and they will walk me through what ports are using the printer. This was not useful at all.
I use ZoneLab as my firewall tool and I then compared the Firewall Program control parts of two computers, where one works and another one doesn't in printing. When I enabled both 'SPanel' and 'Spooler Subsystem' for trusted network, it printed!
I hope this solution is helpful to someone who has the same problem by the same or similar reason.
Posted on Feb 14, 2009
SOURCE: i have lost my samsung priter driver cd
Have you tried going on to samsung website and seeing if you can download the driver there. Failing that google samsung 2010 printer driver and it may give you other places to download from..... I have a scanner but no driver and this is how i solved my problem :0)
Posted on Mar 13, 2009
SOURCE: printer status offline needs to be online
Do you mean it says "offline" under the printer icon in your PC's printer dialog box?
Right click it , then select "use printer online".
Please let me know
Posted on Apr 04, 2009
Since upgrading OSX Lion my Samsung ML 2010 returns a job message: /library/printers/samsung/ML-2010/rastertosec failed
I resolved this problem by re-installing the 2.00 driver from http://www.samsung.com/us/support/downloads/ML-2010.
Jul 30, 2011 | Samsung ML 2010 Laser Printer
I have a samsung ML 2010 printer. I want to install it in my computer but does not have a disc.Wher edo I get the disc?
In case the Driver CD is missing, you can download the Driver from the Internet and Install them. (You may also store the Drivers on CD for future use)
Drivers for Samsung ML-2010 are available here
Select the drivers according to the operating system you have on your PC
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 06, 2011 | Samsung ML 2010 Laser Printer
How to install my samsung ML-2010 mono laser printer to my USB without driver? I need free solution
you can download driver on this page:
http://www.samsung.com/ro/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=1704&prd_mdl_cd=ML-2010%2FSEE&prd_mdl_name=ML-2010&srchword=ML-2010
Mar 06, 2011 | Computers & Internet
I installed Windows 7 (32 bit , Professional edition) on my desktop. I have difficulty in installing the Samsung ML 2010 printer driver
try on this page
download driver and user guide
Feb 19, 2011 | Samsung ML 2010 Laser Printer
ML 2010 Laser Printer: have aquired a samsung ml-2010, have installed dri...
have you tried replace a new toner. If new toner also giving out noise. it is most likely the main drive issue.
May 17, 2010 | Samsung ML 2010 Laser Printer
PRINTER IS NOT WORKING
So, your saying you haven't installed the software? That would be the problem.
Copy and paste the following link into your address bar. Download the appropriate print driver. (save the file to your desktop). Run the installation program:
http://www.samsung.com/us/support/download/supportDown.do?group=&type=&subtype=&model_nm=ML-2010R&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010400&disp_nm=ML-2010R&model_cd=ML-2010/XAA&menu=download
* please rate me ;)
Mar 17, 2009 | Samsung ML 2010 Laser Printer
Sumsung ML-2010 Series
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
Jan 25, 2009 | Samsung ML 2010 Laser Printer
How do I install my printer with out the disc?
u cant install a printer without any drivers u need them to send the spooler and other functions to the printer so it can work fine without any problems
go here and download the latest drivers install them than follow the driver instructions
http://www.samsung.com/uk/support/download/supportDown.do?group=print%20solutions&type=print%20solutions&subtype=mono%20printers&model_nm=ML-2010&disp_nm=ML-2010&language=&cate_type=all&dType=D&mType=DR&vType=L&prd_ia_cd=06010400
Jan 04, 2009 | Samsung ML 2010 Laser Printer
Samsung ml 2010
i want driver of ml2010
Jun 16, 2008 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser Printer Logo
151 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
