Question about Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet is giving me a dl error or F11. The door will not unlock and my clothes are stuck in the washer.
  • 135 Answers
F11 is a communications error between the main control board and the motor control board. You can first try to unplug the washer for a few minutes. Plug it back in and see if it will reset. If not one of the two control boards may be bad. Another thing you can try is to unplug all the wiring harnesses on both boards and plug them back in. It could just be a loose harness. The main control board is under the top panel in the back. The motor control board is behind the bottom panel on the left.
Posted on Apr 08, 2008
SOURCE:
Duet Sport HT WFW8400TE Washer: hello i have a whirlpool duet we originally had an...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Below I give you some solutions picked from this site. There are five down para-wise You may find some very useful:
I had same error code F11 and DL.....I sprayed the door lock (inside) with WD40......so far works OK
I had the same F11/DL problem. I tighten the two screws on the door latch and it's working great. for now
Just some part numbers to help if you need to order parts. For the GHW9200LWO Washer (Sanitary Cycle Model)- the part number for the CCU (Microcomputer or main computer) is 8181924. The part number for the Motor Control Unit (MCU) is 8182706. I did a search for the part numbers and found the CCU for $79.90 shipping included - the same part from Whirlpool was $190 plus with shipping included. I put the CCU on and my washer works perfectly again. Hope this helps someone since I had such a hard time finding out the correct part numbers. Whirlpool first sent me the MCU even though I specifically told them it was not that part but the CCU.
DL is a door lock error. This is usually an indication of a bad door latch. F11 is a serial communications error from the Central Control Unit CCU (which is your main computer). If the door latch is defective it could be generating the communications error code as well. A defective CCU can also give the same symptoms, though. Before replacing any parts, however, double check all you connections to make sure you don't have any loose wires. The least expensive of the two possible solutions would be to replace the door latch (about $50). The CCU can run between $150 and $250. Hope this leads you in the right direction.
I wanna thank all of you for your input. I had the "DL F-11" code also. My washer would run 12 minutes and then stop with the annoying beep and error codes. After learning that the "DL" was the door lock, I decided to order the part online for 50 bucks. After I placed the order I decided to take this $50 thing apart and give it a look-see. (Boys like to tear things apart!)
There is a solenoid inside that actuates the lock. My finding was that there was some hardened goo that seeped out of the solenoid. It didn't look good! I believe this to have caused an electrical imbalance that the computer didn't like, thus sending it into error mode.
Removal and installation was a snap. First I took the top off. Then to make room for my arm to get to the door-lock, I pushed the drum all the way back and held it in place by wedging a shoe in the front end. Then I pushed the drum to the side, opposite the door-lock, and wedged it with another shoe. This gave me plenty of room to reach the door-lock. Unplug the three connectors and remove the three screws from the front side of the door-lock. (Inside door at 2:00.)
Reverse order for the install!
Thanks again for your posts which led me in the right direction!
May 16, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
F11 and/or dl code on a whirlpool duet front load washer
F11 is:
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Check for:
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
Check the above link for a detailed article about the f11 error code.
Courtesy:JSrock
Apr 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer displays error f did what the manual says but still same problem
it shows f11,also DL,
I did change the door lock,
same alarms.
it's fine for few wash but when it happens again it just stop and show
F11.
Mar 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer has error code f dl. there is a buzzing sound and the washer won't drain nor spin.
Hi there
I hope this helps you.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Ty for writing to fix ya.
Best regards Richard
Dec 08, 2009 | Whirlpool GHW9150 Duet Washer
I have the F11 and dL code. There is water and
Hi
Error F11 means Serial Communication Error i.e. communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. You need to:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
  • Error code dl is a Door Lock Error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error. You need to check:
  • Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    Jul 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    F dL symbol on Whirlpool duet HT
    It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
    Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
    Duet GHW9160PW0 F11 Issue
    not related to shake, issue, but hte f111 and dl issue def sounds as if the connection between the 2 has been compromisdd, in my experience it has been a faulty CCU, losing communitcationsd with the door latch thus the f11
    Dec 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet Washer GHW9150PWO Have F11 and DL errors. Have replaced the door lock 2 x and still have same error messages.
    Well du is a door lock error but it can also mean an error with communication to the main control board or ccu. f11 is also a communication error in either the ccu or the mcu ( motor control board)......easiest thing to try is to unplug all your connections to the ccu and plug them back in and try it again.....sometimes a wire harness just may be loose....if that dosent work I would look at replacing the ccu ( central control unit )
    Jul 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpoo? duet displays F11 and F dl alternatively
    F11 IS A COMMUNICATION ERROR BETWEEN THE DOOR LOCK ASSEMBLY AND THE MAIN PROCESSING BOARD THIS HAS BECOME A COMMON ISSUES WITH THE DUET WM THAT WERE MADE BETWEEN 2003 TO 2006. THERE IS A HAIR LINE CRACK IN THE MAIN BOARD THAT IS CAUSING THIS ISSUE. MFG SUGGEST CHANGING THE MAIN BOARD AND THE DOOR LOCK ASSEMBLY
    If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
    May 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Dl error message on front loader
    This is the info from the error code for your washer DL/F
    Door Unlock Error
    A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the
    door 6 times before displaying the error.
    Potential Causes
    • Door Lock Mechanism broken.
    • Check Door Lock/Switch Assembly for foreign objects
    • Check Wire Harness connections to the Door Lock/Switch Assembly and Central
    Control Unit (CCU)
    Note: The Door Lock/Switch Assembly can be manually unlocked. See Section
    Seven, TECH TIPS
    Mar 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    200 people viewed this question
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
    jimorris77
