Question about Craftsman Garden
How to install pull rope on Craftsman 917.37717 lawn mower
  • 61 Answers
First, this is best done with two people, unless you have 4 hands. Second, with rope pull cover off the mower and laying on table with rope pulley up so you can see it, remove all the old rope. Next, measure 8 foot of new rope.
Now, line up the holes where rope will go thru the cover and into pulley, now with someone holding the cover, rotate rope pulley 6 complete turns, now hold pulley there, while putting new rope thru the rope openings in rope pulley and outer cover. Tie knot on end by rope pulley and have who ever was holding cover and other end of rope, slowly release the rope so it rewinds, install rope handle and walla, your done. 5 minute job, depending on how much coffee you drink. Hope this helped you.
Posted on May 29, 2010
Starter rope won't pull on my Craftsman rotary mower model 917.4787A.
the cable may be stuck or you may have to take the top off and rewind the rope.
Nov 05, 2016 | Garden
How do i rewind the recoil spring on my craftsman lawn mower?
Normally these small engines use a clock spring to retract the rope.
Remove the cover on the top and you should find the spring either broken or the tab where the spring end has broken off or jumped out of the mount.
You will need to pre-load the spring with enough tension to retract the rope.
Remove the pull handle from the rope, load the spring and then wrap the rope around the pully holding the pully and spring in the loaded position. place the end of the rope through the hole and tie up the handle. The rope should pull and retract without being installed on the engine.
Best explained here...
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jun 27, 2014 | Mtd 22" Yard Machine Push Mower
Tecumseh pull start engine on Craftsman Lawn Vac will not pull. Feels like engine is locked up.
the engine is probably not locked ! remove the plug wire, tip up and see if the blade turns. if so, try the rope again. if it wont pull, take top off mower off to investigate the pull rope problem. good-day !
Nov 07, 2011 | Garden
The rope broke and we tied it back and put things back together. Now the mower won't start and the rope wont recoil right. Help
You may need to install a new pull rope. This isn't novice work but it is common sense work. Mower may have other issues as well. A small lawnmower engine has 4 things that are crucial to its operation (besides the obvious pull or electric start system). They have to have clean motor oil (SAE 30 usually in summer). Clean air (good air filter). Fresh, clean fuel. (not over 30 days old). A strong spark from the ignition. Any thing deviating from these things inevitably causes problems.
The shroud and cover wil have to be removed to install new rope. Its not rocket science if ya'll want to attempt it Take your time and note or draw which screws go where as ya remove um. Loading the recoil spring for rope is an endeavor not too easily done but you can do it.
Jun 07, 2010 | Craftsman 55 Torque 158cc 22" Push Lawn...
I can't pull the starter rope more than a few inches. Just purchased the mower. Its a craftsman push mower
Try taking the spark plug out and pulling it. If you have a bunch of gas, oil, or water come out, and the engine turns over, you will have your problem. If you have stuff in there, you will want to pull the starter rope a bunch of times to try to push it all out, and then dry off the spark plug, put it back in, and give it a go. You may have to leave the plug out for while to let the cylinder dry out.
May 31, 2010 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Starter rope won't retract
You have to wind the spring as tight as you can before you put the rope on. Then allow the spring to unwind, pulling the rope onto the spool. Be very careful when you take it apart. Good luck...Lee
May 29, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
The pull cord willnot pull in a smooth action. It is easy to pull in the beginning and then becomes more difficult.
You might actually have a straight section on the return spring. This sometimes causes the rope to hesitate coming out, and definatly going back in.
May 19, 2010 | Craftsman 19 in Lawn Mower Mulching Blade
I have a craftsman self propelled lawn mower The clip that holds the metal bar to make it go forward broke the speeds don't change it is difficult to pull backward the wheels won't move
i have a craftsman rope start lawn mower, the rope keeps snapping back on me and sometime will not come out at all. is there a way to fix this problem
May 18, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Lawn mower troubles
You must first remove the cover assembly which houses the starter pulley. Pull the old rope completely out until it no longer moves. Hold the starter pulley and remove the old rope. Try to wind the starter pulley spring tighter if possible. DON'T LET GO. The starter rewind spring must be wound before installing the new rope. After winding the spring, thread the new rope through the cover and into the hole in the pulley. Tie a good knot in the end and let the rope wind slowly into the housing. Once you have this done, replace the cover, get the proper length of rope, thread it through the handle, tie a knot in this end and your ready to go.
May 19, 2009 | Mtd 22" Yard Machine Push Mower
When try to pull on the rope to start the mower is will not move. It feels like it is stuck. But I can move the blade around. Thank you
I thing the recoil spring is stuck it may be rusty. Its time for a complete maintenance on this mower. But you could try tapping the top of the recoil where the rope coils up into. Bang it a few times as you pull on the rope. this may free it up. Good luck DFD
Apr 20, 2009 | Garden
Garden Logo
236 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
