Question about Goodman CKL24AR24 Air Conditioner
Compresor on goodman gsc130601ba doesnt start
Take the accsess cover off of the out side unit ther you will se the contactor switch you can usually push these in with a screwdriver and the compressor will come on. if it does not it is usually the 208/240/24v tarnsformer and you can chec to see if you have 24v in and 240 out and if you have these voltages then replace the contactor
Posted on May 29, 2010
High pressure reset
most dont have a high pressure safety. the compresor trips on internal drawing to many amps.
Dec 26, 2013 | Goodman CKL36AR36 Air Conditioner
Hooked up new 4 wire fan 2 condensor with a new 2 cap fan runs fine but no compresor?installed as was told with nothing runnng 2 the new cap but the brown wires but compresor isnt kicking on
The compressor could be bad there is two ways to tell with an ohm meter check each lead off the compressor and to ground for continunity or a megometer . You can always try a hard start kit. It is a super capicator that multiplies starting voltage. Have you checked all connections? There might be a low\ high Pressure switch in the referigent lines if that is bad it won't allow the unit to start. Also is it a heat pump or straight a/c the heat pumps have circut control boards in the unit that control everything
Aug 07, 2011 | Goodman CLQ36AR49 Air Conditioner
AC unit GOODMAN modelGSC130421AC was working good and today stop working the fan work but the compresor dont start
Check your circuit breakers and fuses. If it tripped breakers or blew fuses it may be because the outdoor coil is stopped up with dirt. If it is wash it out real good with a water sprayer.
May 10, 2011 | Heating & Cooling
UNIT WAS INSTALL COMPRESOR RUN FOR 2 MIN AND QUIT FAN MOTOR RUNS
could be a DOA!! but was it installed by a licenced contractor? is so he should be able to fix it othewise call the place you purchased it from
Aug 30, 2010 | Goodman CLJ48AR49 Air Conditioner
The compresor and fan not doesn't running but the relay work ok
If the contactor pulls in but nothing run check for power across it. If you have power then check the wireing for bad or burnt. Also coould be the capictor.
Aug 18, 2010 | Goodman CKL60AR60 Air Conditioner
Refrigerator tries to come on but doesnt
Probably you heard a click on and off when the compresor is trying to start , that could be the relay or the compresor went bad .Try replacing the relay (no more than $30) If the compresor doesn't start is either burned or stuck and has to be replaced.
Aug 19, 2009 | Kenmore Refrigerators
Fan running but dont hear comp. turning on
First check for burned wires in all the componnents in the condensing unit ,also the compresor terminals ,if they're all ok and if you know how and have a tester check the compresor if is not burned or grounded. After that you can replace the capacitor (is no more than $20) and if still won't start it means the compresor is either burned or stock.You can also try to put a start booster in parallel with the capacitor ,sometimes it helps it to start.
Aug 11, 2009 | Goodman CKL60AR60 Air Conditioner
Goodman A/C model ch42-1 cooling fan not working
These motors start with the capacitor,that could be the problem in most of the cases ,but sometimes even if the capacitor is new they don't start or after a while they stop by overload.First try replacing the capacitor(no more than $10) and keep an eye on it beacause if this fan at the condensing unit doesn't work it could damage the compresor.
Apr 23, 2009 | Goodman CKL42AR42 Air Conditioner
Goodman CKL24AR24 Air Conditioner Logo
354 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
