Question about Faberware FCP280 Coffee Maker
Vintage Sunbeam C50 doesn't heat enough to perk.
It seems to be in perfect condition, and gets warm, but won't "perk". By the brew/warm switch it looks like a light should come on, but it doesn't. Can we fix, or is there someone who does repair? Thanks! It is such a pretty pot I would love to be able to use it.
    Scholar:
  • 176 Answers
Hi. If you have a light on your coffee pot the model # should 122. A 12 cup older pot. I can fix it for you but you should consider the cost. I only charge for thr parts you need. Shipping both ways is about 10.00 , Max on the repair will be 15.00. My email is callahanronals@att.net Good luck. Ron
Posted on Jul 26, 2010
The urn stops perking after about three minutes - coffee is not brewed
2 points of failure
A) Heater Element - Open Circuit or Wire Broken (Corrosion at crimp(s),
B) OVER Temp Thermostat OVERLOAD.
IF the element does not get hot enough (The amount of power (measured in Watts) consumed is not close to the Nameplate rating, then the element is weakening inside.
IF it stays cold, then it is gone completely, however you indicate that after 3 minutes (the usual time??) the brewing stops.
MOST designs have a water heater fused to a "Hotplate" type warming pad.
There are two temperature sensitive valves built into the flow of water. A Low Temp that closes when the water is about 30c. A HIGH temp valve that opens at 70C. Between the two valves, the water gets heated to 90C then pumps over the drip basket.
Along the way, is an OVER TEMP that trips at 105C, and stops the heater function (After the coffee is brewed, and the reservoir is empty.)
Jun 08, 2015 | Coffee Makers & Espresso Machines
Why doesn't percolator run long enough
The thermostat in the base of the pot needs replaced...it is the little round thing pressed against the base of the pot. (You can see it after removing the base of the pot.) Pull off the leads and remove the screw holding it in and get a new one at goodmans.net ($10 including shipping...I just got one from them.)
You should take a picture before removing anything to make sure that you get the leads connected up correctly.
You have a main perk element and a keep warm element in the base of the pot. Plus a thermostat pressed against the bottom to sense temperature. Upon plugging in a cold pot, the thermostat reads zero ohms and applies 120 volts all to the perk element. Then when the thermostat senses a high enough temp, it opens and 120 volts is still applied to the perk heating element, but this time through the keep warm element (about 200 ohms or so). So now the perk element although hot is not hot enough to continue perking, just keeps your already perked coffee warm.
On a cold pot, you should read about 17 ohms looking into the pot...on a warm pot (with the thermostat opened up) you will read in the hundreds of ohms.
May 11, 2014 | Farberware FCP280 Stainless Steel...
Why won't our poly perk percolator shut off?
I just bought a Poly Perk percolator from a thrift store. If yours is the same, it's a vintage plastic, electric percolator. I found your question while searching for directions for mine. My percolator does'nt shut off either. It just continues running. I don't know if it has a shut off, but I figure I'll just unplug mine for now since it made really good coffee. If it's supposed to shut off, I suspect we're both stuck with few options. I hope you find your solution though.
Jan 18, 2012 | Regal Coffee Makers & Espresso Machines
We have a sunbeam microwave. it starts but the light doesn't work and it won't heat the food. what should we do?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;'
Sep 01, 2011 | Sunbeam SMW750 Microwave Oven
It seems to be perking correctly but stops and then starts to perk again and again, this continued until I unplugged it, and also the light to indicate it was done never came on
Your pot needs a keep warm element. the main element works ( perks and perks) The thermostat works ( it turns the main element on and off.) The pot goes on and off because the water is getting cold The problem is the keep warm element. The reason, your pot perk's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. Thanks and please ask if you need more help. Go to repairshack.com for the part. Ron
Sep 25, 2010 | Faberware 10-22 Cup Coffee Urn
The first problem we noticed is the coffee is not as hot as it used to be, but it was still strong enough. Now the unit perks for about 10 min for a full pot, the light comes on....but the coffe is weak...
Hi, The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix. Thanks and please ask if you need more help. Ron For the part go to repairshack.com
Aug 17, 2010 | Faberware 10-22 Cup Coffee Urn
Faberware FSU-122 coffee maker does not perk
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers
Oct 16, 2009 | Faberware FSU122 Coffee Maker
Continually running/heating
Coffeemakers have two heating elements: a brew element and a keep-warm element. When the water reservoir has run empty, a thermostat switches power from the brew element to the keep-warm element.
The keep-warm element will cause the thermostat to stay in this condition until more water is added [or power is cut off] which will cool it down to switch back.
However, if the keep-warm element has quit working, the thermostat may be reactivating the brew element. With no water in the reservoir, the brew element will heat up till the thermostat trips again, then cool down, etc. This cycle will repeat until power is switched off.
Mar 31, 2008 | Keurig B50 Coffee Maker
Faberware FCP280 Coffee Maker Logo
173 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Dael Escher
Level 1 Expert
Kolbrun...
richie46
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
