Question about The Learning Company Oregon Trail 5th Edition/Africa Trail (Bundle)
I want to install it on a different drive, how do I change it so it isn't using my c drive?
  • 4,924 Answers
If it is already installed you have to uninstall it completely ..and reinstall it ..and when you do that see that after you open the installer and run it ..it shows the oath for the director to install...change the director by introducing the new path or just browse for one..and after that click next ..
I hope you understood the procedure..its easy ...just delete the path to C /program files..and choose by browsing the other drive ...or if it has no browsing possibility ..insert the address(location for teh director folder ) manually . D:\new folder
please do not forget to rate me ..have a great day !
Posted on May 28, 2010
Ssd won't show up as destination drive.
I'm not sure this is your problem, as you question isn't descriptive enough. But here's a solution if I do understand your question correctly.
When I have installed new hard drives in the past, I did the physical install, turned the computer on, and they just worked. Not so with SSDs I've installed. After the physical install, the SSD does not show up in the "Computer" window with all the other drives; because it's not FORMATTED.
Solution:
Navigate through:
Start > right-click on "Computer" in the right pane > select "Manage" > in the left pane select "Disk Management"
All the drives will show up in the main window, including the SSD you just installed. If it does not show up, there's a problem. Maybe one of the cables isn't fully inserted, or there's a defective cable, or a defective SSD.
You can tell the SSD from the other drives by the Gigabyte capacity, and also by the fact that it does not have an assigned drive letter (e.g. C:). Also, it's named something like "New Edition".
To continue to formatting, navigate:
Right click the SSD > select "Format" > select "Quick Format"
A drive letter will be assigned. You are given the option to change this letter if you want. Also, you are given the option to name this drive. This name will appear with the drive listing in the "Computer" window. I simply used the name "SSD", however if you want something more discriptive or colorful, it's your computer, it's your SSD, you can name whatever you want.
The other format option is for when one is installing a used HD which may have bad sectors. That option scans for bad sectors, and takes a LOT longer to format. Not necessary for a new SSD. Plus, you can scan a drive for bad sectors anytime with the "chkdsk" command.
The SSD is now ready for use, including for use as the main drive. Windows will happily load onto this drive.
Nov 10, 2012 | Samsung 830-series Mz-7pc128n/am 128gb 2.5...
Cant get my sumsung S2 external hard drive to work..my computer does not recognise it
If you are trying to use it on a computer with Windows XP or later installed it and it isn't automatically installing the drivers and finding the drive for you then there are typically only 2 possibilities of what's wrong.
1. Your external drive is probably Dead.
2. The USB port you are using is dead. Try plugging it in to a different USB port.
Before you write the drive off as DEAD, make sure you try plugging it in to a different computer and see if it works on the that computer.
Aug 17, 2012 | Computers & Internet
Rear axle seals leaking
If the axle had a slight grouve in it,you would see or feel it
If you distort the seal on install,you would be aware of that
I would try a different brand seal & install not quite as far
in the housing, until it seats,then you will be using a different
surface on the axle
If the seal leaks on the outside of the metal shell, you need
permatex #2 or similar product, if the seal isn't rubber coated
Jun 09, 2012 | 1995 GMC Sierra
TICKING SOUND FROM UNDER THE HOOD, FIRST TIME DRIVING THIS CAR IN THE WINTER, OIL JUST CHANGED, DEALERSHIP PUT THE WRONG OIL IN 5W30 INSTEAD OF 5W20 - IS THIS WHAT THE PROBLEM IS?
Hello! 5W30 shouldn't make much of a difference ...If the ticking sound is coming from the lifters I would change the oil and filter again...The cost isn't that much...It sounds as if the vehicle isn't driven much and may be gunked up...Add a bottle of Seafoam to the gas tank when you fill up (great product) and it will clean out the gunk...Guru...saailer
Dec 15, 2011 | 2007 Mitsubishi Eclipse
Dell Inspiron 1420 laptop When I insert a disk in the CD drive, nothing comes up on the screen to ask me what I want to do with it. I have tried different disks. Recently was one that came with a router...
Two possibilities; a dead CD drive or a corrupted device driver (Windows likes to trash these so we don't get too bored).
Since it isn't operating anyhow, I would open the Control Panel, open the System folder, click on the Hardware tab, select Device Manager, find DVD/CD (ROM) drives and then delete the appropriate drive.
Reboot your system with nothing in the CD drive and watch for a dialog window telling you that Windows has found a 'new device' and is installing the software. If it does this successfully, it should finally tell you the device is ready to use although if the driver is not found on the hard drive in the library, it may ask for an installation disk. You should have either factory disks or a set you made when the system was new. If you don't, you will have to download them, best from the Dell website.
Good luck-
Jun 03, 2011 | Computers & Internet
I'm trying to format my hard disk but i cant this problem always appears "Windows Unable to complete the format" what should i do? ive done different ways to format it and nothing works please...
There are two possible reasons for this issue. 1. bad hard drive... 2. bad installer (operating system disc).
It does not completely load the needed software that's why it's showing up that certain error message. Here's my suggestion:
- Try a different installer. If you can't find a different operating system's disc, then, purchase one.
It would surely fix the problem if your hard drive isn't bad. If the hard drive is bad then you have to replace it.
I hope this helps.
Thank you for using fixya.com.
Apr 25, 2011 | Samsung Computers & Internet
It connot be install on my computer because it is demanding i get the installation softwares
It should have the software on the drive itself.
If you look in My Computer, can you see an additional drive listed? If not then one of the other drives may be using a letter that this drive needs (E and/or F).
If this is the case, you will need to reassign the drive (E and F) a different letter and then the drive will automatically install or at least detect as a drive that you can get the software from.
To do this, go to Control Panel, Admin Tools, Computer Management. Click on Disk Management and you should see the Drive there. Right Click on on whatever is using the E or F drive and click on "Change Drive Letter" and choose a different one.
Then go to your portable drive, Right Click on it and reassign to the letter you just changed from (E or F)
Hope that helps, pls rate me if this answers your question and let me know if need further assistance
Nov 15, 2010 | SimpleTech SimpleDrive 160 GB External USB...
I have mainboard Amptron ZX-I945LM4,but i can't install any varsions of windows xp.i try change settings in bios,jumpers,but still same.tahnkl you for help
try to delete all of your partitions.
Then boot from cd the bootable setup disk of windows xp.
try a working setup disk.
1. if you still cant install windows xp,try to make a new partition and add all the contents of the setup disk into that partition. boot from cd and you will be able to go to setup screen.
Pm me if problem persists.
:) thank you
Aug 10, 2009 | Computers & Internet
Problem using a drive
When installing a program, you are normally prompted with a default installation directory, if you want to install to a different location, you normally just change the drive letter/folder listed on the default install path, then the program installs to that location. Be advised, even if you install a program to D:, several files will still be written to C drive (Driver and registry files)
Jun 13, 2008 | Acer Computers & Internet
The Learning Company Oregon Trail 5th Edition/Africa Trail (Bundle) Logo
81 people viewed this question
Top The Learning Company Computers & Internet Experts
k24674
Stitch85
Level 1 Expert
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
