Question about HP OfficeJet 7110 All-In-One Thermal Printer
I'm back online
Okay -- the printer now shows up under printers and faxes. I'm going to look for "maintenance"
    Brigadier General:
  • 6,966 Answers
Understand, I'm also downloading the installation for your printer will install in my PC. That way I can simulate the exact condition and how it would appear in your computer.
Posted on Apr 08, 2008
When I receive a fax, it prints out perfectly. When I make a copy or scan to fax/email, the page has multiple black lines running down the length of the page. I have recently replaced the drum and the...
As the fax receives and prints incoming faxes ok then the print engine is working ok. the fact that the problem arises when copying or scanning indicates the problem is with the scanner or software that controls the scanner.
First clean both scanner glasses and the white area (white reference) under the doc feeder. When you are happy all is clean, follow the following instructions:
Press menu, * 2864 within 3 seconds. the display will show "Maintenance"
now press 55. The scanner will initialise and go back to "Maintenance"
now press 99 and the machine will go back to the default screen showing date and time.
Now do a copy. if you still have the lines or its all black then you will need a new contact image sensor. If all is well then that was a good cheap repair.
May 26, 2011 | Brother MFC-7340 All-In-One Laser Printer
My printer says its offline how do I reconnect? I've already done a complete power off and it's still offline.
hi
just folow the step
Step 1
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
· Step 2
Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
· Step 3
Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
Mac Instructions · Step 1
Open System Preferences by clicking on the icon in the Dock.
· Step 2
Go to the Print & Fax control panel under the Hardware category.
· Step 3
Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button.
· Step 4
Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Jul 07, 2010 | HP Deskjet 6940 InkJet Printer
The printer shows up on my computer and says it is offline and for some reason i can not turn it back online
go to my printer and faxes right click your printer and then select "make printer online" this should do it make sure you turn on your printer, hope this helps
Oct 19, 2009 | Brother MFC 490cw Color Inkjet...
Lexmark z640 wont show online
Try This :
Goto to printer and faxes from control panel Right click on t he printer icon make it online
If still it doesn't works
Click on Start >> Run >> type in CMD >> OK >> type in NET STOP SPOOLER (Refresh the page in printers and faxes) >>> again type under CMD..... NET START SPOOLER (Refresh the page in printers and faxes) .
Check what happens
Then uninstall and reinstall the entire printer driver from control panel add or remove programs
Regards Soumajit
Oct 09, 2009 | Lexmark Z640 InkJet Printer
My MAC says my HP C5550 All-In-One printer is off line
go to printer and fax and set it up as default printer
Oct 09, 2009 | HP DeskJet F380 All-In-One Printer
My HP officejet 4300 series stopped printing and shows that it is offline. How do I get it back online?
To get back online of your printer, go to Control Panel and Select Printer & Faxes then OPEN.
A list of Printer is on the browser, point the printer with your mouse then right click on your Printer HP OfficeJet to select Printer Offline and click it to go back Printer Online. Good luck!
Aug 04, 2009 | HP Officejet 4315 All-in-One Printer
HP4000 not printing LPT1
Dear sir;I believe you can try " cold reset", that's means going to clear all data from the printer memory and sets all the defaults back to the factory settings.performing a "cold reset" resets the jetDireect configuraion. to avoid making changes to yourconfiguration, remove the jetDirect card before performing a cold reset. if possible, print a configuration page prior to performing a cold reset. this will document current settings for later reference.
to perform a cold reset;
1, turn off the printer.
2, while pressing "go", turn the printer on. COLD RESET appears briefly on the display, then INITIALIZING appears.after a few seconds, RESTORING FACTORY SETTING appears on the display, followed by OFFLINE.the cold reset is complete.
3, press "go" to return the printer online "ready " appearson the display.
Little bit complicated but is easy ,hope can take care your problem, GOOD LUCK! Let me know the resolve please!
HAVE A HAPPY HOLIDAY !!!
Dec 15, 2008 | HP LaserJet 4000 Printer
Wont send fax
Error 350: Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
Try these steps...
1. Press setup, then go to TOOLS.
2. press okay on TOOLS, then look for RUN FAX TEST. then press okay.
3. It will print a fax test page. Check if everything passed.
4. If it passed everything, try to press setup again, then go to ADVANCE FAX SETUP.
5. Scroll, down and look for ECM (Error correction mode), then press okay
6. Under ECM you will have to options "ON or OFF" try to choose OFF then press OKAY.
7. Now, try sending a fax.
Please let me know if the steps that i gave resolve your issue or not. So that i can still go ahead and give you another possible solution.
Thank you so much.
adonscott
Jun 29, 2008 | HP Photosmart C7280 Printer
Printer is showing offline. How do you get is back online.
Hello, go to start, control panel, printers and faxes. Look for your printer. right click and going down you will see sharing and use printer online or offline. click that and you will be up and running
Feb 15, 2008 | Computers & Internet
Printer not receiving jobs from computers in office..HELP!
what type of connector do you use? if its network printing then check ip address, cable, and the network card of the machine if it shows light, if its usb cable check the driver or cable.
note: make sure when you press the print buttom on the machine it doesnot show offline! if it shows offline you cannot print hit go or start to make it online.
if none of this work, reset the machine by hitting 1087 twice this will take you to maintenance mode then hit 906 then start, highlight the words that come on screen by your finger then hit start, the machine will ask you to put the main power on and off, do that and you will be fine.
Best Regards
Feb 15, 2008 | Kyocera Mita KM-2050 Printer
HP OfficeJet 7110 All-In-One Thermal Printer Logo
16 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
