Question about Kitchen Appliances - Others
Hi I purchased my Tefal quick cup in February and all has been well up until now. This morning I ran it to make my morning cuppa and alas Cold Water - clearly not happy I looked for some sort of reset button but to no avail What should I do ?
    Brigadier General:
  • 4,090 Answers
Get a replacement quick before the warranty expires
Please rate my help++++Thanks for using FIXYA
Posted on May 28, 2010
Tefal quick cup kettle water coming out in slow spurts,have changed filter but no improvement.
If you are in a hard water area you may need to descale the heater element. Try adding 1 cup vinegar to 3 cups water and run the machine should clear up the scale. Rinse thoroughly before use.
Sep 12, 2010 | Tefal Kitchen Appliances - Others
Hello tefal quick cup water is no longer hot only
we had to return our first one for the same problem Gavin. Tefal (surprise surprise) claimed that nobody else had EVER had that problem. 2 years down the track though, and i've discovered that mine turns itself on at random intervals, and floods the kitchen bench. My advice - get a refund while you still can...
Mar 03, 2010 | Tefal Kitchen Appliances - Others
Lost instructions
I have found my instructions.
You press both cold and hot button down for five seconds until blue light appears. Bingo!
Mar 13, 2009 | Kitchen Appliances - Others
Tefal quick cup
Press the Hot and Cold button for 3 seconds,
The red indicator light will start to blink,
Release the hot and cold buttons and while the red is still blinking, press the and hold the hold water button, Once the desired amount of hot water is reached release the hot water button.
Now press and hold the hot and cold water buttons simultaneously for about 3 seconds.
The red light will stop blinking to the end of the programming.
NB the RED LIGHT WILL BLINK FOR THE DURATION OF THE PROGRAMMING.
Repeat the process for the cup quanity selector for the cold water.
------------------------------------The end -------------------------------------------
Feb 28, 2009 | Tefal Kitchen Appliances - Others
Tefal Quick Cup
ALERT :- Tefal Quick Cup can TURN IT SELF ON. Tefal know about this but it is a potential fire hazard. Mine turned itself on and dispensed the water reservoir over my kitchen. Dread to think if I had been out shopping what could have happened. Tefal know about this problem but are not doing anything to advertise the fault!!
Jan 19, 2009 | Kitchen Appliances - Others
Tefal Quick Cup not heating water
press the hot button on off 5 times and on the 6th let it run a cup full. This will re set the temperature
Dec 15, 2008 | Kitchen Appliances - Others
Problem with tefal quick cup, has started to mix hot and cold water when you try to get a cup of hot water
Very strange problem for an air conditioner. I think you've posted this is the wrong category.
Jul 27, 2008 | Heating & Cooling
Tefal Quick Cup not working
This is in my opinion a design problem. The wiring connects to the spiral heating element via spring loaded contacts which only have a tiny connection surface area. These gets arcing deposits on the surfaces and will periodically require scraping clean. To get access prise off the silver top assembly which is a snap fit, unclip the circuit board and pull the plastic water pipe off the top of the plastic cylindrical tank. Then remove the two star screws from the base and prise it free. The whole internal assembly can now be carefully removed intact from the kettle housing but the circuit board at the top will need to be turned vertically and guided down the main body on the way out.
Jun 04, 2008 | Kitchen Appliances - Others
Tefal Quick Cup
As you are getting a light, then the fuse/ supply is ok .
Does it have water in it?
If not, it may be a safety cut out sensing this - and turning off.
Check the manual for any mention of a "thermostatic trip" This may be user-resettable by means of a rod or button underneath, or may need to cool down - you may even hear a click when it does.
If not - then it is likely to be a manufacturing fault within the heating element.
You should be able to return it to the shop you bought it from for a full refund.
May 31, 2008 | Kitchen Appliances - Others
Tefal quick cup - descaling problem
Push red and black for 5 seconds to lunch descale then unit resets light at end oy cycle
Hampshireman
Feb 25, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
381 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
