Question about Frigidaire FDL50R1 Dehumidifier
Frigidaire dehumidifier compressor does not seem to be working
  • 36 Answers
Either you have some sort of leak and there is no freon pressure or..Your compressor wont turn on because of a swith or control isn't telling it to..Does the fan still blow?
Posted on May 28, 2010
Does antone know the freon charge level-the manfactuar will not post and this is a simple step and procedure to fix problem?
Posted on Mar 15, 2011
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Frigidaire 70-pint dehumidifier won't work after winter
No reset button on the compressor... but this tip may give you some clues as to what is or is not happening..
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 05, 2010
22yooper
  • 828 Answers
SOURCE: frigidaire MDD40WW2
Your dehumidifier may be low on refrigerant. Seems cold may not be cold enough to reach the dew point to condense moisture from the air stream.
Posted on May 11, 2008
My Frigidaire dehumidifier compressor runs constantly and will not turn off with the switch. Have to unplug the unit.. Everything seems to be working to dehumidify. Is this a bad motherboard?
Does it run after you get to the optimal humidity level?
If so, it's a bad humidity sensor switch A cheap fix is to put it on a timer. Otherwise replace the switch.
Jun 21, 2017 | Frigidaire Dehumidifiers
Why does blower wheel stop on Frigidaire dehumdifier?
Good Afternoon Desi,
I understand that the blower wheel is not spinning on your Frigidaire dehumidifier, model# FAD504DUD. I also see that the compressor will stay on unless the dehumidifier is unplugged. I suggest you contact the manufacturer for further assistance. They can possibly clarify why the compressor stays on and why the blower fan is not working. If not, they should at least be able to point you in the right direction of having your dehumidifier working. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire FAD504DUD White Energy Star 50...
When turn off. makes a humming sound. compressor seems to be running.
Have same issue with 3 year old Frigidaire dehumidifier purchased in 2012. Must unplug to stop compressor running with power switch turned off. Unit gets hot and smells. Unplugging creates arcs at outlet since unit is pulling a lot of power. Plugging back in after some hours will make it appear to run normally and again remove moisture but it will not shut off when the fan goes off (humidistat bad?) and the set-point is reached. Cannot leave plugged in due to safetty/fire/overheating concern. Have not found answer on this forum or any other so far.
Sep 15, 2013 | Frigidaire FAD704TDP Dehumidifier
I have a Frigidaire 30 pint dehumidifier, the fan is running, but I do not hear the compressor. There was a lot of dog hair inside when I bought it second hand. Did I get screwed?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Sep 04, 2011 | Frigidaire FDL50R1 Dehumidifier
Fan runs but it seems tne compressor does not cool as no condisate collects in the bucket in 24 hours
heatman101
Aug 03, 2011 | Frigidaire Dehumidifiers
My dehumidifier does not work at all anymore
I had the same problem with mine. I had it less than 2 years. The compressor seemed to kick on, but no water collected in the pan. the compressor should be covered for 5 years, but unless you have an extended warranty, there will be a service charge.
My dehumidifier was fried during a thunderstorm and nothing worked afterward, and it wasn't running at the time. I just bouught a frigidaire (45 pint) and I love it! no noise!
May 30, 2011 | Haier 45-Pint Dehumidifier
heatman101
May 04, 2010 | Frigidaire FDL60P1 Dehumidifier
Frigidaire MDD40WW2
May 09, 2008 | Frigidaire FDL45P1 Dehumidifier
Frigidaire FDL50R1 Dehumidifier Logo
1,692 people viewed this question
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
richie46
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
