Question about Roper RS22AQXKQ Side by Side Refrigerator
My ice marker will not stop making ice the arm
My ice marker will not stop making ice the arm will not go up or down to stop the ice. I have the roper side by side.
    Novelist:
  • 77 Answers
This problem is going to be the ice maker itself. The arm you are talking about is the shut-off mechanism for the ice machine. Just before the ice machine starts to make ice, the arm slowly rises. Then the arm falls down, if there is ice blocking the arm from falling all the way down it will not make ice because there is plenty! If the arm is able to fall down completely, the ice machine will make ice like normal. If your ice maker is making ice regardless of the arms position, something is wrong with the ice maker. Depending on who replaces this, it could cost anywhere from $100 to $200.
Posted on May 28, 2010
Testimonial: "thank's for the feedback i have been looing online for a new icemarker."
How do I get the ice maker to produce for the first time
Is the arm that gets pushed up by the ice cubes (in order to stop making ice when it is full) in the down position? it is able to be pushed up and locked so that the icemaker doesn't make at ice and may need to be pushed down.
Aug 27, 2014 | Maytag MSD2454G Side by Side Refrigerator
Ice maker does not make ice
there is sometimes an armature that raises when the ice tray is full.you can raise this arm is you want it to stop making ice.look said arm and lower down into on position.it will fold down into a spot near the full level of the ice tray.
Aug 20, 2014 | Refrigerators
Frigidaire FRS6LR5E ice maker won't stop making ice
Ice maker wire signal arm is being held down by some item in the freezer. Move item and release wire signal arm. Any ice cubes that are frozen together over the wire signal arm. the ice rises in the ice bucket and pushes the wire signal arm up and this is what stops ice production as ice is used then arm comes down and starts ice production all over again. if there is nothing holding arm down then you will need to replace ice maker.
Oct 07, 2013 | GE Monogram ZDI15C Automatic Icemaker
Model b198 makes one batch then stops
Check the bin arm spring you will have to disassemble the front of the ice maker to do this and check timer motor could be getting hung up. not a cleaning problem. or replace the complete head.
Oct 09, 2012 | U-Line Icemaker
My ice make bin is full but it's not dispensing ice cubes.
their is a wire like arm that is on the side of the maker this tells the maker to stop making ice till the ice goes down you will need to remove some if the ice and then reach in and pull the wire arm down not hart you will feel it click and stop and is a couple mins it will start making ice again if this is not the case the ice unit could be frozen in place and you will need to thaw it out then see if it works if it still does not then it will need to be serviced hope this helps
Aug 30, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Ice maker will not stop,even when the tray is full of cubes.. will only stop if arm is put up..
The ice tray arm is mechanical. It is pushed up by the ice cubes. Try bending the arm down so it makes contact with the ice cubes sooner and gets pushed up sooner when it reaches up posistion it should stop.
Mar 29, 2010 | GE Profile 24.7 cu. ft. Top Freezer...
Do you put the bar up or down to make ice ? and
arm up is the off position and down is on
Sep 04, 2009 | U-Line Icemaker
The ice maker suddenly stopped making ice. The "arm" is down. Should it be up?
arm down ...Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
The ice marker does not make ice. Have looked
If theres water in the line going to the fridge and the ice maker works , most of the times the water valve ( solenoid) that opens when the ice maker needs water , is leaking or doesn't work.
Aug 14, 2009 | Refrigerators
Kitchenaid superba icemaker
HI thanks for the question On the ice maker you should have an metal arm thatlifts up &down Down means you want ice Up means the ice bucket is full if that arm is not there that will cause the problem if the arm is there make sure it moves up & down ok if it does Then you need a new ice maker or save money & when the bucket gets full turn off water at back of fridge to stop water from coming in thanksfor the question THe appliance doc
Sep 03, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Roper RS22AQXKQ Side by Side Refrigerator Logo
695 people viewed this question
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Sal DeAngelo
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
