Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
I replaced the lamp but the timer,lamp,temp lights
I just replaced the lamp after reading other posts as the most common problem with 6-7 yr old set but the timer,lamp,temp lights keep blinking and the set turns off and then back on with no picture or sound. PLease help?
  • 10,594 Answers
What was the symptoms in tv that you decided to replace its lamp?
Did you put back lamp cover after lamp replacement? Lamp cover is the first thing that need to be removed to access lamp so make sure lamp cover is fixed back securely in its position.
Thanks.
Posted on May 28, 2010
  • bm1528 May 28, 2010
    the tv picture went away while watching it. Over the past year, when I turned the tv on there is a winding noise. I powered down and unplugged the tv for an hour to "reset" . Whjen I turned tv back on the winding noise came on as usual and the audio temoporily came on but no picture. Oddly after about 30 seconds the tv powered off, then after another 30 seconds back on and so on. Finally the three lites would blink in unison. Researched other sites and Samsung manual and the lamp seems to be the first to go with these symptoms. I did check the door as most blogs said that was very key.
    What next?
Temp and lamp lights flashing
can you let the projector work well
if the projector projects the image,
does the projector light?
if the projector work well ,but the indicator lights flashing,that means the projector is ok ,
you only need to reset the timer of lamp and to reset the timer of the filter,
menu-setting-advance-reset-the timer of the lamp
menu-setting-advance-reset-the timer of the filter
Apr 28, 2014 | 3M S15i 165Watt 2000Hrs HSCR Projector...
I have a 6 yr old Panasonic PT 50 LC13 and I need to know how th reset the lamp. i just replaced the bulb and i cannot get the tv to turn in
To reset the lamp follow the steps below.
Press and hold "Volume down(-)" at the front panel and "TV/Video" on the remote control for more thatn 5 secs in power off condition to activate the Service mode map. You can now reset the lamp.
After that check if the symptoms still there. If yes, let me know the status of the led light(Power, Temp, Lamp) and its color to determine where the fault came from.
Jdvillanueva
Sep 08, 2011 | Panasonic PT-50LC14 50" Rear Projection...
Picture won't come on. light flashes green continually, after 3 or 4 minutes the light flashes red continually. bulb is less than 6 months old. any ideas?
Hi:
This model was notorious for fan failure. The most common failure was the lamp temp fan. Its use to keep the lamp a constant temp. Also if one of the fans fail the unit will not start, This model is also known for Ballast failure also. The ballast is use to light the lamp. The best thing you can do is have a service technician come out and diagnostic the set for a minium fee.
Nov 09, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Last week , my 6-7 yr old Samsung hln5065w dlp tv went blank. When I turned the tv back on after trying to reset it there was a winding noise but no picture. I replaced the lamp and still no picture. The...
Sounds like the old lamp blew and took out the ballast. I believe that you need a new ballast for your unit. The other possiblity would be a problem in the low voltage power supply but if the indicator lights are blinking the most likely problem is the ballast.
I have a tip at http://www.fixya.com/support/r4977572-when_change_ballast_in_dlp_tv which explains the problem, how to repair it and where to get the parts. If you need more help let me know.
Thanks for using FixYa and the generous rating.
hardrocko
May 28, 2010 | Samsung HLN5065W 50" Rear Projection...
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Green blinking light under timer
I can almost guarantee that the circuit board(s) have bad capacitors on them. I repaired one last week that had 20 bad capacitors on 4 boards.
Fixed one the week before with 15 bad caps on two boards.
A repair shop may be able to replace the boards, but it may be expensive.
- I hope my diagnosis is wrong-
Sep 11, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Set timer
You did not post model number of TV so try below method to reset lamp timer.
Turn TV ON, Press and hold Volume minus button on TV and press Split/ Play button on remote for 6 seconds, lamp reset message will appear on TV screen.
Jul 02, 2009 | Panasonic TY-LA1000 Projector Lamp for...
Mitsubishi WD-52327 52 in. Rear Projection DLP
I have a 2 year old Mitsubishi Rear Projection 52" model WD-52525. I recently experienced the same problem as you. My TV quit without any warning and the red lamp light came on. I bought a replacement lamp just like you did, did everything you did too, but it still didn't work either. Since it's past the 1 yr warranty (of course), I took it in to an authorized service center for an estimate. They determined the light engine failed and it will cost me $816.35 to repair. I already shelled out $240+ for a lamp, $48 for the repair estimate and I said "hell" no, I'm not going to fix it for another $800+ and bought a new TV. I'm writing a letter to Mitsubishi expressing my deep dissatisfaction (to put it mildly) with this faulty product and will be requesting reimbursement, which I probably won't get. I sincerely hope this is not the same problem your TV has, but if it is be prepared for a costly fix.
Aug 06, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
164 people viewed this question
Henry  Thomas
Henry Thomas
