Question about Garden
Drive assembly stiff on Flymo roller compact 3400 is this normal
2 Suggested Answers
SOURCE: Flymo Roller Compact Heigh lever keeps dropping
I drilled a hole through the lever, and used a self tapping screw to fix it permantly in position. I cannot adjust the height without drilling another hole, but it is better than buying a new machine.
Posted on Aug 10, 2009
Flymo power compact 330
test your actuator. I see this a lot on walker machines
May 17, 2014 | Garden
Why does my flymo switch off when grass box is only half full?
sound like a bad pressure switch or sensor, try cleaning or washing the bag, inspect for broken wire.
My flymo roller compact 3400 has no power
It's quite common for a wire to break internally on the mains lead. You will need a circuit tester to ascertain whether you have continuity.These are available quite cheaply at most electrical servicing outlets or general tool centres
First, remove the plug from the mains supply. Remove the motor cowling and locate the wiring at a junction box prior to entering the motor. Undo both the phase and nuetral wires from the junction box. Connect one lead from your circuit tester to a pin on the plug and the other end to each wire individually. Ensure the operating lever is depressed at the same time. If one wire is broken the tester will not function. A break in the wire is generally near one end. If the wiring tests without a fault then there is likely to be a problem with the electric motor which is not generally serviceable, well not economically.
May 03, 2014 | Garden
Flymo instructions
OK, I checked out what youy have I have never changed the before but it looks like the whole spool is replaced by removing nuts on end of shaft. Then pull shaft out and replace with new spool. Hope this helps.
Mar 26, 2014 | Garden
My flymo 350 turbo compact isint cutting can i adjust the blade height ?
You can put spacers under the blade, a twin pack of spacers are available from Flymo part no. 513811081., from memory you are allowed to fit three spacers.
Aug 10, 2012 | Garden
How to change the brushes on the motor in a flymo 340 compact
There are no brushes available for this model, if the brushes are worn that bad the motor will be just about worn out as well, new motors are available.
Jul 21, 2012 | Electric Garden
Switch for hover mower 300mm 1250w
Hi and welcome to FixYa, I am Kelly.
Can we get a Make and model number please? I am searching for any brand of hover mower that is 1250W at the moment and there are at least 3 different brands:
This is the Flymo manual:
http://www.shop.flymo.co.uk/images/mediator/397/oipl2002_p0201018.pdf
This is the switch for the Flymo Hover mowers:
http://www.espares.co.uk/part/lawnmowers/flymo/turbo-compact-330/p/1116/283/116/402362/1136941/8a-250v-lawnmower-switch.html
This was my best mind reading guess. If this is not your brand then help us help you by responding with a make and model number please.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Garden
Flymo Roller Compact 340 - Bearing needs replacing
I guess you're referring to a bearing on the shaft to which the impeller is attached.  That's part of what's called the Drive Assembly, and unfortunately the Drive Assembly must be replaced as a complete unit.
May 04, 2009 | Garden
Apr 11, 2009 | Garden
Garden Logo
161 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
