Question about Frigidare FEF336EC Stainless Steel Electric Kitchen Range
The broil and the bake elements quite working at the same time. is this temp sensor related? is there a reset somewhere i am not seeing? is it the relay panel?
  • modman847 May 28, 2010
    my wiring diagram does not show a clock sensor relay. is this the same as the eoc
    Brigadier General:
  • 4,090 Answers
There is a fuse inside the panel, Check that hasn't blown. It would be rare for the sensor to stop the elements all at the same time
If the fuse is still intact I would start looking carefully at the logic board for burn marks
Thanks for using FIXYA
Posted on May 28, 2010
  • 713 Answers
Hi,the problem with your unit is as a result of the fact that the clock-relay is bad and it needs to be replaced,this clock relay costs about 200-250 dollars.
Thanks and good luck
Maytag Oven. The bake do not heat, the broil is ok. what is the problem ?
Look at the wiring diagram... The manual reset Thermal Limiter Switch (part number 74008715), located on the lower rear insulation retainer can keep both elements from working, not one at a time... I would inspect the back of the bake relay for a burnt/failing solder joint. Swapping the BAKE and BROIL leads is an acceptable test, but if you put the bake leads on the broil and still get no heat: check the control relay. If the broil leads will not heat the bake element, you have a bad element or bad connection. Be sure to do all testing of the elements with at least one wire detached so as not to red a back circuit.
Jun 19, 2016 | Maytag Ovens
My frigidaire fef368gch was working fine and then the oven just stopped baking. It will broil but not bake. What causes this and how do I fix it?
Good Morning Shari,
I see that you are having trouble with your Frigidaire range, model# FEF368GCH, and the bake element not working while the broil element is. I suggest giving your appliance a hard reset, by shutting the power off at your home's circuit breaker, for 2-3 minutes. When power is restored, you will have to reset the clock by entering in the time and pressing start. Start a bake cycle, and if you notice that the bake element is still not working, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Apr 23, 2014 | Frigidaire FEF368GC
I have a GE double wall oven model JKP45WOA2WW and the oven will not bake or broil. Pulled one of the elemeents and it had continuity. The upper unit has not worked for some time. The lower oven just...
It is possible that there is a bad relay in the control board. This will shut off the power to your burner elements. The control board has a relay for the bake and broil element and one for the common for both. This is usually the one that goes bad. Unfortunately the board will need to be replaced or repaired. The control board will show temperature rise from the sensor but generally it doesn't show the cool down temp. This again is normal from my experience.
Mar 01, 2014 | GE Ovens
RF214LXTS 0 I have a whirlpool stove, have power on both incoming legs. the top works fine, but the bake and broil elements in the oven dont work. the saftey fuse on the back seems to ohm out good as...
The way power typically is supplied to the bake/broil elements is that directly off the terminal block 120volts ac is supplied directly to the elements at all times and when the touch pad is pushed a relay on the clock/eoc (electronic oven control) will close and supply 120vac so the element has 240vac to heat. you should be able to see the wire coming directly off the terminal block where the cord from the house wireing connects to,going directly to the elements and as stated above theother 120 vac from the relay to the elements (their is 2 relays,one for bake and one for broil)
As far as testing the oven sensor(temp probe) at room temp the ohms reading should be 1060-1100 ohms and as the tempature rise the ohms rise so to test it verify is 1060-1100 at room temp then heating it usinga blow dryer,match or cigarette lighter and the ohms should rise as it gets hotter and drop when its cooling
Good luck,i hope this helps and if it does help please give me 4 thumbs up
Gene
Jul 27, 2011 | Whirlpool Ovens
My Kenmore Elite oven will take over an hour to preheat to 350 degrees and never does get done preheating.
There's a few things that can cause this.
1. Check to see if the both that Bake and Broil elements (burners) are heating up. Check the Broil element in Broil mode.
- during pre-heat the Broil element gets cycled on and off for short time durations to speed up the heating. If the Bake element is not working, then the oven will heat, but very slowly and never reach high temperature.
2. If the elements are both working, then it's possible that you have a bad temperature sensor.
- this is a temperature dependent resistance device that should measure 1080 ohms at 70 deg F (room temp).
3. If #1 and #2 are ok, then the problem is with your oven clock/control unit. We rebuild these at fixyourboard.com.
Aug 14, 2010 | Kenmore Ovens
Screen displays error code f3e2
This code means "BAKE/BROIL range over temperature"
Problem is in either temperature sensor or the control board. Check the temp sensor and wiring from it to the control board first (connector #3, contacts 8 and 10, violet wires) . At room temperature the temp sensor resistance should be around 1080 Ohms. Also check temp sensor for short to ground. If no problems found with the sensor - replace control board.
OBTW - for the broil problem - check the fuse inline with the broil element (continuity between Conn #2, wire 1, blue and conn #4, wire 3, red). It should read several ohms. Good luck!
Oct 12, 2009 | Whirlpool RF462LXSB Electric Range
My oven's bake/broil element won't heat
It could be the stat (temp probe) or the cut outs. if these are faulty then it will not allow the elements to heat up
Sep 21, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Kenmore electric range 790. Both the broil and
Kenmore oven 790.91072601, bake & broil not working, relays are cycling but no heat... Sounds like I have the same problem but its the night before Thanksgiving and Iam in panic mode... I've orderd a new Temp Probe part # 316233902. did you ever get yours fixed
Jul 13, 2009 | Kenmore Kitchen Ranges
Whirlpool built-in single oven AKZ451/IX/01
If this is an older oven, check to see if it has a control knob or switch labeled "manual and "hold". Make sure it's set for manual. The hold setting maintains temp at about 140 degrees.
If not the case, is this gas or electric?
Nov 11, 2007 | Ovens
Frigidare FEF336EC Stainless Steel Electric Kitchen Range Logo
Top Frigidare Kitchen Ranges Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Frigidare Kitchen Range Expert? Answer questions, earn points and help others
