Question about JVC AV-48WP30 48" Rear Projection Television
How do i reset a JVC I'art PRO? my HD wont work. i get a black screen or a green screen and thats it.
Take a dump on the top and rub it in with your tongue. Should do the trick.
Posted on Jan 10, 2011
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Jvc I art pro double color pink and green
a model number and a better description might help here, like 3d looking?
Sep 03, 2012 | JVC Televison & Video
AV-65WP84 when i connect video or the antenna the screen start to blink green does anyone knows about this problem on this jvc i-art tv?
Have someone open it from the front (front grill below screen is secured on either side at back with screws) and remove inspection plate behind grill--someone needs to locate the small black block with 6 adjustments and locate the green SCREEN not the green FOCUS and turn the green slightly down.
Care needs to be taken as set must be on--do not touch anything else inside as dangerous voltages are present when set is on.
Mar 16, 2012 | JVC Televison & Video
HDMI broken on JVC HD-56G786 TV
have you ever went thru your hdmi setup procedure that jvc recommends?
Sep 07, 2009 | JVC HD-56G786 56" Rear Projection HDTV
Jvc i art pro doe not turn on
The clicking sound is the TV trying to restart itself. It generally attempts this several times before giving up. The blinking code indicates the type of error (error codes are documented in the manual for the TV). The most likely cause is a burned out bulb, but could be something else.
If it is a bulb, it is usually replaceable without a service technician, and at a cost far less than $450.
Good luck.
Jun 18, 2009 | JVC AV-56WP74 56" Rear Projection...
My screen is black but i ges sound then the red
Have you checked that the lamp is working? If the lamp hours are too high, then the television will no longer function until the lamp is replaced and the counter reset.
When you have replaced the lamp, do this process to reset the timer:
1) Press the Menu button
2) Scroll down to the LAMP TIMER RESET option, scroll right to enter
3) Confirm that it is OK to reset the lamp timer by hitting the OK button.
4) The on-screen menu should confirm the lamp was reset correctly.
Mar 05, 2009 | JVC HD-52G886 52" Rear Projection HDTV
JVC i art 32" flat screen
your tv is under shutdown state, there is a protecting circuit that prevent the tv from turning on when there is a short
Sep 10, 2008 | Televison & Video
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
Can't shut off closed caption
I have the JVC I Art 46" TV. The Close Caption was turn on accidentally by my grandson. After lots of searching for the original remote. I called JVC Customer Support. He told me to change the Close Caption settings to CC2 and T1. That fixed the CC without having the original remote.
Apr 10, 2007 | JVC AV-32F704 32" TV
JVC AV-48WP30 48" Rear Projection Television Logo
300 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
