I don't think the washer is working properly because after the initial fill up no water is coming out of the holes on the paddles. It just rotates one direction, stops and then does it again during the wash cycle. How can rolling wet clothes around get them clean?
  • hpadilla1968 Feb 28, 2009
  • Michael Thibodeau May 11, 2010
    what brand and or model number do you have?
  • 135 Answers
If this is a fisher paykel it will rinse the clothes for a bit before it starts to agitate
Posted on Apr 12, 2008
  • 185 Answers
The water is being sucked through the cloths for better washing
Posted on Apr 08, 2008
I have an LG model LDS4821 dishwasher that quit washing clean. Top rack is the dirtiest. Water is hot and bottom drain is clean.
The most likely cause is a blocked or clogged wash arm. Many times when the wash stops the debris blocking the spray will back away. The holes in the arm are aimed to cause the arm to rotate. The clogged hole is usually an outer diameter hole which provides the force for the arm to rotate.
Some upper end washers have a blocked arm sense to alert when arm is blocked.
Careful not to deform the geometry of the hole when removing the debris. Tweezers work the best.
26281729-v4uvew3xjjdpgmn3ctj2lcyg-4-2.jpg Hope this helps?
Sep 13, 2016 | LG Dishwashers
GE Washer WBB2090F1WW will not fill and will not spin. Where do I start to troubleshoot as these seem like unrelated problems? Thank you for any assistance.
Both are initiated by the programmer unit? Is the water supply getting to the machine, has a tap/valve inadvertently been closed. i If water is getting to it then if the programmer is working correctly the pump should trandport the water? If water is not being introduced the machine will not rotate.
I think the issues are both associated with a faulty programmer probably
Jun 05, 2015 | Washing Machines
Washer fills water, drum is stuck
you may have a sock stuck in between the drums
rotate the drum when it becomes stiff you stop then take out the lower paddle by pulling it
you may now see the sock
Dec 01, 2013 | Indesit W 123 Front Load Washer
I have a model lse7806ace maytag stackable washer/dryer unit. Initially, the washer would not do anything. I replaced the lid switch and it then filled and agitated at the same time... but when it went...
Ok , when you pull out the washer knob to start it the water fills . Can you stop the filling by pushing the knob in? if so the water valve is ok.
There is a sensing tube from the tub which connects to the pressure switch. This is what causes the water level pressure switch to shut off at the correct level. I would suspect this as they replaced the pressure switch and it keeps filling. If this is the case there is a small hole which will cause the pressure switch not to turn off the fill valves.
You can check this by removing the tube and submerging it in some water then blow in the tube while blocking the other end , if you see bubbles it is leaking and needs replacing.Hope this helps
Feb 19, 2011 | Maytag LSE7806A Top Load Stacked...
Our bosch SD13J1B don t switch on. Water incom is OK. Electrisiti is too OK.
Possible that the program controller unit can be faulty if the cycle is not initiated after the water is filled into the unit. Now does the water stops after the initial filling? If not the pressure swtich must be checked. Also the door switch, the connections to the washer must be looked into to ensure that all contacts are intact to the program controler. If the washer still wont work then the Program controller is a prime suspect.
Nov 05, 2010 | Dishwashers
Water not filling.
r u using auto fill mode?if u r then try selecting high medium or low. check water pressure coming out of inlet hose, could b faulty valve not letting enough pressure thru.please reply if u need more help
Mar 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Rud4000mq0 the paddle does not spin, i'm getting water but the paddle 's not spinning
Hello. Have you actually seen the water flowing thriugh the paddle? I suggest taking the washer out of its home. Remove the arm in question. Spray a good amount of CLR on the mounting hub and through the arm Calcium does build up and cause the force of water to be less than needed to rotate the arm. Its also ok to run some CLR in the washer once a month when its empty to keep it running calcium free. Thank you , Quinn
Aug 21, 2009 | Dishwashers
Fisher Paykel washing machine not working properly
It's most likely the Lid switch (reed switch). Does it come up with a fault code or beep at all? if so there are eight LEDs reply with the lights eg 00100010 1=on 0=off cheers
Mar 24, 2009 | Fisher and Paykel GWL11 Top Load Washer
When starting the washer, it occasionally will not fill
Check the drain hose. The open end of the pipe the hose drains into must be higher than the top of the washer's tub (usually 30 inches or so off the floor, minimum) or the water can siphon right out. The drain hose should not be a sealed connection to the drain pipe. Try to extend the drain pipe up to about 36 inches off the floor level.
Jan 10, 2009 | Whirlpool Washing Machines
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
