Question about Brother MFC 420CN All-In-One InkJet Printer
WINDOW 7 DOES NOT ACCEPT DISC - Brother MFC 420CN All-In-One InkJet Printer
    President:
  • 405 Answers
The CD that came with this printer was made before windows 7 came out. Brother has not created software for this printer. You will need to use the built in drivers within windows, you will need to plug in the USB cable and it will install automaticaly, you may need to use windows update to install.
Posted on May 29, 2010
Testimonial: "thank you for your help it was very helpfull"
Tip
How to format a windows 7 computer.
<span> <p>To format your hard disk during Windows 7 <a href="http://www.whitecanyon.com/how-to-format-computer.php#">installation</a>, you'll need to start, or boot, your computer using the Windows 7 installation disc or USB flash drive.<br /> <ol> <li>Turn on your computer so that Windows starts normally, insert the Windows 7 installation disc or USB flash drive, and then shut down your computer.<br /><br /></li> <li>Restart your computer.<br /><br /></li> <li>Press any key when prompted, and then follow the instructions that appear.<br /><br /></li> <li>On the <b>Install Windows</b> page, enter your language and other preferences, and then click <b>Next</b>.<br /> <ul> <li>If the <b>Install Windows</b> page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see <a href="http://windows.microsoft.com/en-us/windows7/Start-your-computer-from-a-Windows-7-installation-disc-or-USB-flash-drive">Start your computer from a Windows 7 installation disc or US</a></li> <li><a href="http://windows.microsoft.com/en-us/windows7/Start-your-computer-from-a-Windows-7-installation-disc-or-USB-flash-drive">flash drive</a>.</li></ul></li> <li>On the <b>Please read the license terms</b> page, if you accept</li></ol> <ol> <li> the license terms, click <b>I accept the license terms</b>, and then click <b>Next</b>.<br /><br /></li> <li>On the <b>Which type of installation do you want?</b> page, click <b>Custom</b>.<br /><br /></li> <li>On the <b>Where do you want to install Windows?</b> page, click <b>Drive options (advanced)</b>.<br /><br /></li> <li>Click the partition that you want to format and click <b>Format</b>.</li> <li> <ul> <li>If you have more than one partition on this hard drive and want to get rid them to make one big drive again, then select a partition and click on the <b>Delete</b> option for each partition. Once you have deleted all of the partitions, select thepartition and click <b>Format</b>.</li> <li><br /></li></ul></li> <li>Pick the formatting option that you want.<br /><br /></li> <li>When you've finished formatting, click <b>Next</b>.<br /><br /></li> <li>Follow the instructions to finish installing Windows 7, which include naming your computer and setting up an initial user account.<br /> <ul> <li>If you do not want to reinstall Windows 7, you can cancel the installation at this point and keep your newly formatted drives.</li></ul></li></ol></span>
on Nov 23, 2010 | Computers & Internet
How to up grade window 7 starter to window 7 pro.
Sounds like you might need to do a fresh install to get to pro from starter. But you should be able to run the installer from the windows starter environment.
Insert disc.
Open
click start - open computer folder
right click on disc drive - run
follow the prompts to install.
Your old files should be in a folder Windows.old if you do not format.
Aug 10, 2011 | Microsoft Windows 7 Ultimate for PC
My Acer Aspire 6920G does not detect nor play bluray discs after switching to Windows 7. I may be missing drivers but have no clue what and where to get them. Please help.
Hi goodevening
there so so many reason why does not detect a blueray disc after you switching windows 7
1st may be your cd/dvd driver have a problem,
(solution) try to use other cd/dvd driver
2nd may be the window 7 installer you've use have a missing file.
(solution) try to re install the o.s but dont use the same cd you've use try other installer.
3rd your blueray disc is the problem
(solution) use your blue ray disc in other p.c window xp if running in xp try to use other pc using a window 7, if running in other unit may be your pc need to upgrade.
May 14, 2011 | Computers & Internet
Can i use my friend recovery disc for window 7 32-bit to recover my own window 7 32-bit when i don't have a recovery disc
Yes you can provided both your laptop and your friend's laptop are the same make and model.
Apr 19, 2011 | Computers & Internet
How to install windows 7 operating system
To Install the Windows 7 Operating System (Win 7 OS):
Instructions for a "Clean/New Windows 7 Installation:
AFTER BACKING ALL YOUR DATA THAT YOU DON"T WANT TO LOSE, Do the Following :
1) Insert your Genuine Windows 7 System Disc (Retail or OEM System Installation Disc).
2) Close down all programs and restart your computer.
3) As soon as the computer restarts, you should see a prompt that says something like this: "Press any key to boot from cd/dvd"
....So press any key!... This will boot to the installation disc and prepare for installation or repair (we are going to be installing windows, so ignore the repair options you see on the screen).
*If you don't press a key in time, you will see that the computer will attempt to boot from the hard disc drive instead... if that happens, restart the computer and press a key when prompted.
4) Depending on your particular Windows Version, you will see a prompt that says something about "Do you accept the license terms?" Click "Yes" or "I accept", etc.. and continue on...
5) Choos Custom or Advanced Settings (the other option is for an upgrade..)
6)Select the desired hard disc drive, (HDD aka Hard Drive), Select "Drive Options", and follow the onscreen instructions "Delete the partitions" (Do not Leave another windows installation on the same hard disc drive, unless you are experienced and know how to "dual-boot" properly!) Delete the Partitions.
7) Now choose to install windows (be sure to select the newly deleted empty (unformatted) partition. Windows 7 will automatically format the drive for you and will begin to install windows 7. Follow the onscreen instructions and within a half an hour or less (depending on your hardware) you will be finished, just be sure not to leave the computer unattended while performing a windows installation, since it requires your input quite often to proceed.
That's pretty much all there is to it!.. if you have any more trouble...
Google it or Bing it.... Search Engines are awesome!.... Enjoy!
*NOTE- If your windows 7 disc is a "Upgrade" disc, then you must perform an upgrade while running your previous/older windows version, since Windos Upgrade Discs aren't bootable, they simply patch the older version, replace system files, etc... to transform the previous windows installation into the target/newer version. If you want to perform a clean install, be sure you own a Windows 7 Installation / System Startup Disc.
Jul 06, 2010 | Intel Motherboard
Windows 7 cant connent my usb in asus motherboard
You cant, sorry.. There are a large number of accessories that are not supported by windows 7 including mainboards and portable drives etc.. You only recourse is to fall back to XP..
Mar 17, 2010 | Computers & Internet
I bought a new hp computer with Windows 7 os. I
Your allinone is not compatible with new OS as you have already figures out. Contact the Company..hp and see if they have an updated disc for MS7.....
If you can get your hands on a new disc for the HP AIO's they are all similar...and you can try reinstalling using it.
Go to Walmart...buy new HP AIO.....install disc..connect old AIO....take back new one with disc.....problen solved. walmart will accept all returns.
Dec 29, 2009 | HP PSC 2350 All-In-One InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
69 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
