Question about Lenovo ThinkPad SL500 Notebook
I have tried to connect my SL500 to a digital hard drive recorder using the recorder's DVI input and the laptop's IEEE 1394 port on the left side near the front. The purpose is to record a slide show from My Pictures, or other picture folders, with music from Windows Media Player, onto an external hard drive recorder (made by LiteOn) from which I can then make a copy onto a DVD-R. However, there is no signal coming out of the IEEE 1394 port of the laptop. When I first connected everything together there was a message saying that the 1394 connection was recognized and ready for use. But still no signal. With no other external monitor connected I tried Fn + F7 to display on an external monitor but that was not allowed. I have used the same IEEE 1394 cable in the past to copy from my digital camcorder's DVI output to the DVI input of the digital hard drive recorder to make a DVD. So I know that that is not the problem.
  • 11 Answers
SOURCE: driver for IEEE 1394 BUS HOST CONTROLLER
Download Driver Detective and it will reinstall it and do updates for you.
Posted on Dec 24, 2007
SOURCE: problem connecting to tv
here is steps for how to connect external monitor to laptop.
now replace monitor with tv. i consider that steps are common for both. you many need to use fuction key F5 / F6.
Posted on Apr 05, 2008
Kwitch
  • 33 Answers
SOURCE: touch pad quit working, fn-f7 doesn'make a difference
First, ensure that the button that enables/disables the touchpad is not deactivated if your unit has one.
If the keyboard still works, and you can navigate past your log-in password and enter your windows environment, here is a quick way to check and ensure your laptop still has the correct software driver for your touchpad mouse.
1: Press and hold your windows key, and press the R key.
2: This will open a run command prompt. Type "devmgmt.msc"
3: This will bring up your device manager. It contains all of the software drivers of your unit. If your mouse has a missing driver, it should boldly stand out from the list as an expended menu, within either your mouse drivers, or unknown drivers. You should see a yellow asterisk or exclamation mark next to the damaged or missing driver.
4: If the driver is missing, you can often re-download it from the manufacturers website and have the computer automatically re-install it once you have the driver saved onto your computer.
This solution is only for a single scenario though. Why your driver would have gone missing should it in fact be missing or damaged would still be questionable. It is possible that another program, such as a malicious spyware or virus, could have modified or deleted it. If that were the case, simply re-installing it would not erase the software that is causing damage from your machine.
This is only a software related fix. If it is hardware related, such as the touchpad hardware itself is defective or damaged, then it would need to be replaced by a certified technician, most likely at a service center. I would recommend taking it to your nearest Best Buy and having a Geeksquad agent inspect it, test a usb or ps2 mouse with it, and give you a better idea of which of the two possibilities (hardware or software) the fault is really being caused by.
Hope that helps.
Posted on May 01, 2008
SOURCE: broken screen, external monitor via VGA won't
please call the tech support line 1-800-426-7378 for immediate pc repair
Posted on May 11, 2010
  • 31 Answers
SOURCE: Thinkpad X200 display problem. LCD backlight kept
try to check your video card..
Posted on Oct 17, 2010
How to connect firewires of the HD?
You just need to plug one end of the firewire (IEEE 1394) cable into the external hard drive and the other end in the slot on the computer marked IEEE 1394. Sometimes you have a IEEE 1394 slot on the front panel, and sometimes it's just on the back of the PC.
If you find you don't have a firewire (IEEE 1394) port on your PC then you will need to get adapter that will change the firewire to a usb. If you have trouble finding one of those then install a card like this in your desktop:
http://www.newegg.com/Product/Product.aspx?Item=N82E16815124002&cm_re=usb_to_IEEE_1394-_-15-124-002-_-Product
Jun 21, 2012 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
How to connect firewires?
Good Luck!
I dnt hav usb cable for my handy cam DCR-HC52E ...
Product Summary
    4-pin to 4-pin IEEE 1394 iLink FireWire Cable dv out to laptop Connect and transfer home movie from your digital camcorder to Notebook computer.
    You will need a Firewire port on your computer, also known as a DV port or IEEE 1394, to use this cable. This is NOT a USB cable.
    This DV cable will connect your laptop (notebook)
    NOTE: for some models, becuase of no DV jack on the body, this cable connects to docking station/cradle instead of connecting directly to your camcorder.
Mar 20, 2011 | Sony DCR-HC52E Mini DV Camcorder
My camcorder wont be seen by the usb connection to my windows 7 laptop?
The USB streaming driver for the Camcorder is not available for Windows 7 OS from Sony at this point. Hence it is not possible to transfer videos using USB interface. You may use i.LINK or A/V interface to transfer videos from the Camcorder to the Computer which is running on Windows 7 Operating System.
Please follow the steps to transfer video to a computer using an i.LINK connection (IEEE 1394).
IMPORTANT: Video capture software and a compatible video capture card must be installed on the computer. Depending on the computer manufacturer, various video capture cards and software (Adobe Premiere, Roxio Video Wave, Microsoft Windows Movie Maker, etc.) may be available or already installed on your computer. If necessary, contact the manufacturer of your computer for further information.
NOTE: Many Sony VAIO computers are bundled with Sony DVgate Motion or DVgate Plus software for video capturing. Some VAIO computers also include Click To DVD software that will allow video capture to the computer hard drive or directly to a DVD.
  1. Connect an i.LINK cable (also known as IEEE 1394) to the i.LINK port on the digital camcorder.
Connect the other end of the i.LINK cable to the computer.
NOTE: The computer i.LINK ports and capture cards may have either 4-pin or 6-pin connections. Sony digital camcorders use i.LINK ports with 4 pins. If your computer only has a 6-pin i.LINK port, then it will be necessary to use a 4-pin to 6-pin i.LINK cable.
  1. Turn on the digital camcorder by moving the POWER switch to the VTR position.
  2. Cue the camcorder tape to the beginning of the video footage.
  3. Turn on the computer.
  4. Start the video capture software on the computer.
  5. Begin playing the recorded video in the camcorder.
  6. Begin importing the video with the capture software.
It should now be possible to copy the video using the video capture software if the computer hardware and software are configured correctly.
Jan 26, 2011 | Sony DCR-HC19E Mini DV Digital Camcorder
I have a sony handycam dcr-hc19e. I am trying to transfer to my laptop which only has a usb connector and i have updated software still wont work - any ideas?
If you computer has Windows Vista or Windows 7 installed, then streaming over USB is not supported on those operating systems.
It is only supported on Windows XP.
At any rate, the quality of the video when streamed over USB is of considerably lower quality when compared to the video when transferred of IEEE 1394 connection.
If you don't have Windows XP, you'll have to find a computer with an IEEE 1394 connector and buy a Sony DV to IEEE 1394 cable. The DV port on the camera is right next to the USB port. Consult your local Sony retailer to find the proper cable for your camera.
Dec 30, 2010 | Sony DCR-HC19E Mini DV Digital Camcorder
How can I get Windows 7 Movie Maker to recognise input from my Sony DCR TRV18E Handycam?
On page 230 of the user manual, it describes how to transfer movies from the camera to a computer using an i.Link (IEEE 1394) cable. You will need the 4 pin i.Link cable and an IEEE 1394 connector on your computer in order to do this. You cannot use the USB cable to transfer the video from this camcorder -- you can only transfer still images using the USB cable.
You will have to buy this i.Link cable and (if you don't have a IEEE 1394 port on your computer) a IEEE 1394 adapter card for you desktop computer. If your laptop computer doesn't have a IEEE 1394 adapter, then you're pretty much out of luck.
Once you have the i.Link and 1394 issues resolved, then Movie Maker should then recognize the camera.
Dec 27, 2010 | Sony Handycam DCR-TRV18E Mini DV Digital...
WE HAVE NOT CONNECT TO PC MYSamsung VP-D371i MiniDV, Digital Camcorder
From the user manual, I've discovered that you have to use a IEEE 1394 cable (see the jacks display on page 11) to be able to download the movies from your camera. The camera does not come with a IEEE 1394 cable -- it only comes with a USB cable, so you will have to buy the cable.
Unfortunately, most PCs do not come with a IEEE 1394 connector and you have to buy an adapter card for a desktop computer. If you laptop does not have a IEEE 1394 port, then you are out of luck.
Once you have the cable and the port on the computer squared-away, check page 87 of the user manual for directions on how to retrieve the the video from the camera to the computer.
Dec 24, 2010 | Samsung SC-D363 Mini DV Digital Camcorder
Unable to get dv input / output via ieee 1394 port
try an older version of pinnacle studio or another pc if still no capture, firewire camera board failed.
Oct 24, 2009 | Panasonic AG-DVX102AE DV Digital Camcorder
SONY HANDYCAM DCR-TRV280
To download video you need Firewire port, also known as an IEEE 1394 port.
Windows XP or Vista can save your video files.
PCMCIA 2-Port IEEE 1394 FireWire Laptop Cardbus PC Card
Jun 26, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
I AM TRYING TO TURN MY JVC TV INTO A MONITOR FORMY LAPTOP BUT I CANT SEEM TO GET THE RIGHT CHANNEL. I KNOW ITS NOTHING TO DO WITH MY LAPTOP SO ITS TO DO WITH THE T.V. I THINK I NEED SOME SORT OF CHANNEL TO...
hi dear
Laptop Multimedia Ports Info
Component Video Out: Connects a TV or HDTV to your notebook so you can view high-quality, high-definition video streaming from the notebook. This three-piece connection (color-coded red, blue, and green) is the best method for sending video from your notebook to an HDTV or anything that receives component video. This connection allows the chrominance (color) and luminance (brightness) portions of a video signal to be processed separately, thus producing higher-quality video than an S-Video connection. S-Video works similarly, but component video improves color accuracy even further by splitting the chrominance signal into two portions.
Composite In/RCA: Connects a gaming console or camcorder to your notebook, for viewing video or playing games on the notebook. Color-coded red, white, and yellow, composite video input uses standard RCA-style jacks to connect your notebook to receive video and audio signals from your TV, VCR, game consoles etc.
TV Tuner/75-Ohm Coaxial: Connects a cable box, TV, or VCR to your notebook, so you can watch and record TV content on the notebook.
Sometimes called an Rf input, a 75-Ohm coaxial cable can carry video and stereo signals simultaneously. RF cable connectors (often called F-type connectors) screw onto the 75-ohm jack, are pushed onto it, or connect via a dongle that vendors usually supply.
S/Pdif/Dolby Ac3 Digital Out: Connects your notebook to speakers or a stereo receiver to play digital audio stored on the notebook. S/PDIF (Sony/Philips Digital Interface) is a standard audio-transfer file format, usually referred to as digital audio. This connection allows the transfer of audio without converting the signal to and from an analog format, which can degrade its quality. If you also have an S/PDIF In port, you can play digital music stored on an MP3 player through your notebook. The headphone jacks found on some notebooks double as S/PDIF Ports.
DVI: Connects a digital projector or LCD panel to your notebook to display in large format either video content or a PowerPoint presentation stored on the notebook. DVI (Digital Visual Interface) is a multipin connection used for passing standard-definition and high-definition digital video signals. It's found on HDTV tuners, a growing number of DVD players, HDTV-ready televisions, and some computer displays. DVI-D is the type of DVI connection found on most home video gear and carries digital-only signals. DVI-I is used with some computer video cards and can pass both digital and analog video signals. Some TVs have DVI-I inputs for greater hookup flexibility. DVI connections transfer video signals in pure digital form, which is especially beneficial if you're using a fixed-pixel display like a plasma, LCD, or DLP TV.
Firewire/ I.Link 400/ 1394: Connects a digital camcorder or external hard drive to transfer (but not display) large files, such as MPEG video, to your notebook. Also known as IEEE 1394, this is an extremely fast (commonly up to 400 megabits per second), two-way digital connection used for plugging in Your DV camera or other peripherals (such as an external hard drive or optical drive) to your notebook. It is used in digital camcorders because it is one of the few connections capable of quickly transferring full-motion video.
S-Video In: Connects a digital camcorder to your notebook to display video stored on the camera on your notebook's screen. Also, if your VCR has an S-Video Out port, you can transfer your VHS tapes to digital format. S-Video inputs use a four-pin jack to receive video signals from camcorders, gaming consoles, TV, or any device that has an S-Video out port. the S in S-Video stands for separate: S-Video connections transmit the chrominance (color) and luminance (brightness) portions of a video signal along different paths, allowing them to be processed separately, though S-Video does not produce as vivid an image as component video. This is a common way to display content from a digital camcorder or any device that has an S-Video Out port. (Firewire also transfers data files from your camcorder to your notebook, but it can't display video in real time on your notebook.)
S-Video Out: Connects a plasma or newer TV to your notebook to display video content streaming from the notebook. The most common way to connect a TV to a notebook, S-Video Out uses a four-pin jack to send signals from your notebook to your TV or anything that accepts S-Video In.
and use Fn+F5 or Fn + F4
to switch your ntbook to tv
oke
Mar 22, 2008 | Computers & Internet
Lenovo ThinkPad SL500 Notebook Logo
47 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
