Question about Vizio VF550M 55 in. LCD HDTV
TV won't change channels, is stuck on "Cable channel 85"
  • 10,594 Answers
Please unplug tv from wall socket for minutes or so to get it reset, replug back in and tun it On, if still does not change channels then perform Auto Tuning/ Scan as option is available in tuning menu.
Hope these info will help you.
Thanks.
Posted on May 28, 2010
  • 20 more comments
  • laszilagyi May 28, 2010
    do you mean scan for available channels?
  • Shahid Electronics
    Shahid Electronics May 28, 2010
    Yes, scan available channels.
    it's at 76% and no channels found yet. Cable company says there's nothing wrong with the box.
    scan for channels is complete; it didn't find any and all cables are connected
    OK, make sure that you select Cable in auto scan function because if antenna was selected, tv will show very limited or even no channel after scan mode completion.
    In auto scan option you will see Cable and Air Antenna option to select what tv channels to scan.
    Is it Vizio VF550M tv or any other model?
    it's scanning on cable, but not returning any channels
    it's a vizio 55"
    it's a VF551XVT
    OK, please check coax wire of cable box is plugged correctly in tv.
    It could be wither coax not plugged properly or bad tuner in tv problem
    ok, cable is plugged in correctly, tv is on channel 3, but no picture
    Is it under warranty?
    I'm thinking of bad tuner board in tv.
    still getting no signal message
    it probably is - i bought it in January
    If tv is under warranty then please call Vizio to fix it under warranty cover, I think its tuner board need to be replaced.
    Thanks - am calling them now
    vizio said it's not the tuner board since i'm using a cable box
    Thats amazing, tuner is not getting cable box signal to show cable channels.
    OK, please call cable company to send out a guy to test cable box.
    Do you have any other tv to hook that cable box to confirm that it is providing channels correctly?
    That's what i'm going to try now. Thanks again for the help. The Vizio person said if all else fails, they'll check the HDMI port on the tv. I'm getting channels on another tv in another room, so will try swapping out the cable box to see if that makes a difference.
    Shahid Electronics May 29, 2010
    Yes, swapping cable box will confirm what thing is causing problem so to fix it.
    Thanks.
  • laszilagyi May 29, 2010
    it appears to definitely be the cable box. A different box works fine with a different tv, and a different tv does NOT work with the affected box.
    OK, so tv is fine and cable box is bad.
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
May 23, 2016 | RCA TruFlat 27F520T 27" TV
Stuck on one channel
Is it the tv's remote? Change the batteries
are you on a cable box? You need to use the providers channel changer. Tv is made to stay on one channel like channel 3 and the cable box runs the different channels.
Dec 01, 2015 | Vizio L32 32 in. LCD HDTV
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
Want to run Dish network DVR 2nd TV thru cable to Sharp lc-c5255u Dish uses channel 73. It was not on my TV. I did a channel search and it did not find it. It also erased all channels and I can't...
Go into the setup menu and do a channel search again selecting digital and analog channels. Then change the input type to cable and you should get your channels back.
Aug 31, 2011 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
My remote scanned all the tv channels (Cable TV, TV, DTV and Cable DTV). The channels that do not show up now are the Cable TV channels. They are there if I type in the channel number but the remote...
U are recieving an using DTV Free AIR broadcasting tv signal wright,get a better antena like a roof or a newly design digital antena for uses.This problems dose not happen to cable or sattellite services,i know this because their broadcasting tv signal frequencies are very strong and very high ranges of a broadcasting signal output for their recieving boxes.
May 09, 2011 | LG 42LH40 LCD TV
Can't get digitall channels
I have the same problem, If anyone could help it would be appreciated.... I have the coaxial cable plugged in which on another TV had all 85 channels, and I changed the TV from analog to digital and reprogrammed it but I still only get like 4 or 5 local channels?
Jul 09, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
TV (RCA model F32705) stuck on one channel
go to setup in menu from fromt of set. do 1st time setup ...tell it you do NOT have a cable box. if it thinks you have one it deletes all channels but 3.
Jan 04, 2008 | RCA P46924 46" Rear Projection Television
Remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Oct 02, 2007 | Toshiba 20AF44 20" TV
Usually the fix for that on a RCA or GE TV is to go into the menu (the button in on the front of the TV) and find channel settings and let the TV autoprogram itself. This should fix the issue.
Apr 25, 2007 | RCA F32705 32" TV
Vizio VF550M 55 in. LCD HDTV Logo
158 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
