Question about Mastercool 67471 Evaporative Cooler Air Conditioner
I have a Mastercool Evaporative cooler and had the filter replaced two days ago. It still has a very bad odor (like a swamp!) The water was drained and replaced, as well. What I can put in the cooler, that is safe to breathe, to get rid of this odor?
Several of us add scented fabric softener at start-up each year, and later add a bar of ivory soap. I also have an in-line 'scale eliminator' and an anode inside , as well as a purge pump, which changes out all the water every 8-12 hours. These things combine to keep fresh water in the cooler, and suspend minerals. With clean pads, that should keep foul smells away.
Posted on Jul 04, 2010
I suggest putting a piece of Ivory bath soap in the water trough.(about 1/2 of the large bar.
it will float and will not clog the system. I have been doing this for years and it eliminates a considerable amount of oders and helps keep the scale build up to a minimum.
Posted on Jun 29, 2010
  • 146 Answers
Thats why we call them swamp coolers lol. i always use evap cleaner you should also pull out the pads and clean them.
Posted on May 28, 2010
Swamp coolers
Does it come back on automatically and how long does it take?
May 16, 2014 | Mastercool 67680 Evaporative Cooler Air...
New pads smell like urine. What can be done to eliminate this horrible odor?
Try some Downy fabric softener. Or replace them with Aspen pads.Thank you for choosing FixYa.com
May 18, 2011 | Mastercool 67471 Evaporative Cooler Air...
Need to find blower motor for mastercool swamp cooler mod. # mmb12b
easiest way would be to take the motor to a local Electric Motor repair or replacement shop. All mediaum to large cities have them...
Aug 20, 2010 | AdobeAir Mobile Swamp Evaporative Air...
Swamp cooler works i can hear the pumpon water is turned on but not getting cool air
just because the pump is on dose not mean its moving water. impellers can break and pump can get air lock
Aug 01, 2010 | Mastercool 67680 Evaporative Cooler Air...
How do i drain a mastercool of water manualy?
Remove drain pipe from water pan. You can usually turn it counter clockwise. When drained, clean with fresh water and replace pipe buy placing pipe dope or teflon tape to avoid leaking.
May 05, 2010 | Mastercool 67471 Evaporative Cooler Air...
My Mastercool Trio System has experience a failure od the compressor fan. ACExperts, the installer and only dealer in El Paso has gone out business.
is this not a Evaporative cooler if so there is no compressor the only two motors one for the Fan and a Sump pump. and most you spend 200 for fan motor. this is swamp cooler!
Jul 04, 2009 | Mastercool 67471 Evaporative Cooler Air...
Evaporative cooler pumps in dust
You should not have dust. Your water pump is probably shot. The hoghair might need to be replaced or the whloe unit might need a good hosing down. As far as a draft all the time? That is what you want in an evaporative cooler ain't it?
May 16, 2009 | Mastercool 67471 Evaporative Cooler Air...
Water is not going into swamp cooler
CK THE FLOAT THAT OPENS AND CLOSES THE water valve.. press down on float to see if water is available,if water flows float needs adjusting. If no water then check to seeit hasn't been turned off for the winter -good luck
May 11, 2009 | Mastercool 67471 Evaporative Cooler Air...
Mastercool swamp cooler fan doesnt come on.
Are the relays perment on the board or are they seperate from the main board? If they are mounted to the board, you will need to replace the board. Sounds like you are getting a call to the relay but none leaving so this would indicate that you have a bad relay switch.
Mar 20, 2009 | Mastercool 67680 Evaporative Cooler Air...
Replacing pads
How do I replace a rigid pad on my Mastercool swamp cooler?
May 22, 2008 | Mastercool 67680 Evaporative Cooler Air...
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
1,312 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
